Starting issues?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crux, Jan 8, 2017.
  1. Jan 8, 2017 at 6:05 AM
    crux
    crux [OP] Well-Known Member
    New Mexico
    OR
    Honeycomb composite sleeper platform.
    Noticed that the Tacoma has been having a few issues starting recently. Only have 25k on the thing and every so often it will sit there and crank over but not start. It will only start when you start feathering to flooring the gas pedal. Leads me to believe a potential fuel issue. Anyone else ever deal with this?
  2. Jan 8, 2017 at 6:31 AM
    acmccart8
    acmccart8 Well-Known Member
    NC
    2014 Limited Magnetic Grey DCSB
    I had the problem with mine at about 45k miles. The truck never failed to start, just took 2-3 times the normal amount of time to turn over. The truck also had a low rumble noise that wasn't normal at very low RPMs when the engine was cold but once the engine heated up the noise went away. I took it to the dealership and they were unable to diagnose any fuel/exhaust issue, which is what I thought it was, but they did change my spark plugs per my request and that was their best answer to what the problem is/was. I got the truck back earlier this week and haven't had the issue again, so hopefully it was just the plugs. Wish I would have known the original owner didn't change them at 30k like they were supposed to.
  3. Jan 8, 2017 at 6:36 AM
    eon_blue
    Azusa, CA
    I have the exact same issue with my 04, subbed for outcome. Every so often it will barely start and only when I give it throttle. Runs fine otherwise. I had my plugs changed about 10k miles ago and it didn't fix the issue
    Taco Addiction likes this.
  4. Jan 8, 2017 at 6:45 AM
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    The 3.4 is notorious for this exact issue.
    eon_blue[QUOTED] likes this.
  5. Jan 8, 2017 at 7:18 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Tacomas do have a common hard start every now and again. Yours sounds more extreme though.
  6. Jan 8, 2017 at 8:00 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    sounds like the problem with my 07 when new. got it fixed with this tsb...
    EG011-07 JUL 07 Engine Controls - Intermittent No Start Condition
  7. Jan 8, 2017 at 8:21 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
  8. Jan 17, 2017 at 8:17 AM
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    I've had this problem twice now in the last few weeks. Both times the engine had been running and was relatively cold (both engine and outside air temp). Got the engine started again after giving some gas but then seems like the engine is nearly flooded until it runs for a bit to clear up. Reminds me a bit of vapor lock or other carb problems who would have with older cars.
    Anybody have any other ideas from what has already been mentioned?
    Thanks.
  9. Jan 17, 2017 at 9:31 AM
    Jalockett
    Jalockett Well-Known Member
    Joshua
    Houston, TX
    '11 Prerunner V6 Sport
    Fire Department based modifications
    I had this issue at about 30k. Dealership wrote it off as sparkplug and that they needed to be changed. Apparently if it is too cold, the oem don't have a hot enough spark. When it did it again at about 70k I change the spark plugs myself and replaced the oem with a hotter spark plug. Haven't had ano issue since and I'm almost at 100k.
  10. Jan 19, 2017 at 10:37 AM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    I have this issue every so often on my 2010. I have a remote start (VIPER 5901) installed and it will attempt to start it for 8 seconds. It wont fire. If I intervene and manually start it fires right up. Its so random though, once every 30 starts but recently something like 1 in 10.
