Starting issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by Blumpkinson, Nov 22, 2009.
  1. Nov 22, 2009 at 5:57 AM
    Blumpkinson
    Blumpkinson [OP] Fuelled by plutonium and wild animals
    OR
    03 4x4 5spd
    I've seen threads about this before on here, however after searching i couldn't find them again, so i apologize for the repeat.
    When my truck sits for a while whether it really cold or hot out, when i turn the key it starts right up with no hesitation. Which i am really impressed with even in this cold weather. However, if let it sit for a little while, like when im in class. When i go to start it, the truck hesitates and takes a few cranks. It turns over, but barely and the rpm's are low. They eventually rise and everything is normal.
    I think i remember reading that there was a tsb on one of the wire harnesses, or the O2 sensor, but i can't remember for sure. Any ideas?
  2. Nov 22, 2009 at 6:38 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Since it is an 03, the TSB will not be covered since it is out of the warranty period.
  3. Nov 22, 2009 at 10:05 AM
    Blumpkinson
    OR
    03 4x4 5spd
    any idea on what they might cost me to have replaced since its well out of the warranty period?
  4. Nov 22, 2009 at 4:06 PM
    Blumpkinson
    OR
    03 4x4 5spd
    damn, did it get any worse with time or did you fix it right away?
  5. Nov 22, 2009 at 5:58 PM
    Blumpkinson
    OR
    03 4x4 5spd
    Thanks for the help, i found a full detail pdf file on custom tacos about redoing the harness. However i cant find a price for parts for either, i'm gonna check out liberty toyotas to see if they can give me an estimate.
