Starting Issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Moxman6, May 27, 2025.
  1. May 27, 2025 at 10:55 AM
    Moxman6
    Moxman6 [OP] Member
    Will
    2009 Black Tacoma TRD
    Hello
    I have quite a weird issue going on, it doesnt affect me much as its fairly avoidable, but i would like to try and get some suggestions on where to start looking or if its something that is normal.
    So my truck has trouble starting if i stop and sit with key in ignition, not running, but just sitting with the key turned off, or to acc. When i go to turn it back on, it will start and immediately die.
    An example of what im talking about
    Yesterday i took my wife to an appointment and didnt go inside, i stayed in my truck and turned it off since it was nice outside. I left the key in the ignition, but never opened the door or got out. She came back on 30 min later and when i go to start, it would start and die immediately. To get it to start i have to start it while pushing on the gas pedal and revving high. Usually i have to do that a few times as it will die the first couple times.
    It has no issues starting any other time.
    HondaGM likes this.
  2. May 27, 2025 at 12:27 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Check the battery with a proper load test and clean the throttle body
    O'DubhGhaill, HondaGM and Dm93 like this.
  3. May 27, 2025 at 12:54 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Yea sounds like the classic weak battery and dirty throttle body, battery voltage drops low enough during cranking to reset the ECM and make it forget it's idle.
  4. May 27, 2025 at 3:38 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Second to clean the throttle plate, and the MAF sensor. Check plugs for fouling.
    O'DubhGhaill likes this.
  5. May 29, 2025 at 10:53 AM
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    I vote for MAF sensor.
  6. May 29, 2025 at 12:16 PM
    Moxman6
    Moxman6 [OP] Member
    Will
    When i get some free time, ill grab what i need to clean MAF and throttle body. Ill also get battery tested, although it is brand new. Will report back
  7. May 30, 2025 at 5:58 PM
    O'DubhGhaill
    O'DubhGhaill Well-Known Member
    2008 Tacoma TRD Sport Access Cab 4.0L V6 VVT-i6spd manual
    FWIW, CRC makes a MAF cleaner and throttle cleaner. I use each one on each part. GTG.
  8. May 30, 2025 at 9:23 PM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    But it starts then dies. Wouldn't that be the alternator?
  9. May 30, 2025 at 9:57 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    No that wouldn't cause a start/stall.
  10. May 30, 2025 at 10:27 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Just for fun next time before cranking the engine cycle the key to on then off, pausing in on for a couple seconds to see if it makes a difference
