Starting Problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by jb22384, Jan 18, 2012.
  1. Jan 18, 2012 at 11:28 AM
    jb22384
    jb22384 [OP] Member
    Georgia
    97 4WD V6 Ext. Cab
    My truck is having problems starting sometimes (approx 50% of the time). I replaced the batter several weeks ago. But now when I turn the ignition it does absolutely nothing. Doesn't make any clicking sounds or anything. I think it's probably a bad connection or wire. Is there any way to determine which wire or connection it would be? I'd appreciate any suggestions or advice. Thanks.
  2. Jan 18, 2012 at 11:29 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I would start by cleaning the battery terminals, and connections.
  3. Jan 18, 2012 at 11:34 AM
    Jonyd182
    Jonyd182 What do you mean I can't go up there...Watch this!
    Jonathan
    Columbia, SC
    '99 Mini Tank
    Rock Crawler
    I had a similar problem on my '99 last year after I replaced the battery. It was better for a few days then had to turn the key "just right" in order for it to start.
    Turned out to be a bad starter and had to be replaced.
    Hopefully yours is just a connection issue.
  4. Jan 18, 2012 at 11:38 AM
    dirty dangler
    dirty dangler GFO DMC LBR
    adam
    simi valley,ca
    86 4runner bone stock
    wiper blades and a new battery
    no click...sounds like the starter solenoid
  5. Jan 19, 2012 at 10:25 PM
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    you can actually repair those by yourself pretty cheap. remove the starter and take the cap off the end of the solenoid there will be two copper contacts there, you used to be able to buy them at the dealer for less than $20 if i remember correctly. remove and replace, good to go! or make em out of a penny if you're really cheap.....
  6. Jan 23, 2012 at 4:56 PM
    darrylt
    darrylt Active Member
    Darryl
    Chesapeake, Va
    12 PreRunner
    Had the truck for a couple weeks. now everytime I go to start it, it clicks and has a hard time turning over. Sometimes taking a while to finally get started. Only has 20k miles on it. Haven't paid for it yet. Should I take it back? Thanks
  7. Jan 23, 2012 at 5:23 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Check your grounds
  8. Jan 23, 2012 at 5:31 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    This is what I was thinking too. I've read quite a few threads on here where the 1st gens have starting problems due to a bad ground.
  9. Jan 23, 2012 at 5:35 PM
    99PreRunner.
    99PreRunner. ^ I no longer have a Tacoma
    Alex
    Mobile, AL
    2008 GMC 3500 Duramax 4x4 - CCLB
    Sounds like the starter.. If is does nothing when turning the key, tap the starter at the same time as someone turns the key.
