Starting problem =(
Discussion in '1st Gen. Tacomas (1995-2004)' started by Wildcat1991, Jul 9, 2014.
  1. Jul 9, 2014 at 3:03 PM
    Wildcat1991
    Wildcat1991 [OP] Member
    Before I had made a post my truck would keep loosing battery and would take a boost, then few days later it wouldnt take a boost, roll start, or anything.. when it did run you could turn on the radio or it would kill out, headlights or anything eletrical same problem would happen.. now i changed a fuse in it and its starting to crank but it just wont start! :( please help!
  2. Jul 9, 2014 at 3:09 PM
    TejasYOTA
    TejasYOTA Countinuous improvement
    Nathan
    Country of TEXAS!
    "WOOKIE" 01 Tacoma DC TRD Limited 4WD
    Check the TTORA Garage Section....
    Check all other connections...alternator, engine ground, body ground...see if they are loose,or broken or corrosion.
    If possible head to the auto parts store to have them hook it up to their charging system analyzer.
    How old is the battery?... It may need water or replacement.
  3. Jul 9, 2014 at 3:24 PM
    Wildcat1991
    The battery is just a four months old just bought it when i started having problems with the truck, took it down there the other day to get it tested they said it was a good battery and charged it back up. rebuilt the alternator also. ive had about 5 people tell me its a ground but im not sure where all the grounds are on the truck to check them, i took the alternator off and put it back on myself and im not a mechanic at all so ill go check the alternator right now and let you know if that helps, thanks for advice
  4. Jul 10, 2014 at 4:37 PM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    If you get the truck started and disconnect the battery it should run if the alternator is good. (No radio,lights on.) That would rule out alternator. Just disconnect the ground when you do it. Also is the belt tension right?
  5. Jul 12, 2014 at 7:46 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    Andy, this was the accepted testing practice for alternators prior to electronics be using in vehicles. Now the practice is to leave the battery connected to filter and stabilize the poly phase voltage produced by the alternator. By disconnecting the battery, excessive voltage (>16 VDC) could easily destroy any electronics (emissions control computer, audio systems, etc.) and lighting. In other words, the battery acts like a large electrolytic capacitor to filter the DC voltage. Alternators can be tested by measuring the DC voltage, AC voltage (ripple) and DC current outputs to determine its health.
  6. Jul 13, 2014 at 6:19 AM
    Andy.G
    Andy
    Virginia
    Okay, appreciate your advice. Although I did do this on my 95.5 without ill effects Shadetree. Not questioning,just saying. Definitely not trying to give bad advice though, so thanks.
