starting problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by sypher651, Mar 13, 2016.
  1. Mar 13, 2016 at 8:26 PM
    sypher651
    sypher651 [OP] Nothin' but trail lovin'!!
    Groveland, California
    1996 Tacoma 4x4 3rz
    So I am having a semi frequent, more on the frequent side now, problem. When my truck is cold it starts fine, but when I go to start it hot, it sometimes has trouble starting. Now it doesn't sound like the starter, It wants to start, but struggles. Any ideas? Wish I could record the sound and upload it.
  2. Mar 14, 2016 at 9:47 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Does the starter motor turn over when it wants to start? Or does it turn the engine slowly? Or does it grind when you try to start it? Need a bit more info. Exactly what kind of trouble are you having?
  3. Mar 28, 2016 at 5:57 PM
    sypher651
    1996 Tacoma 4x4 3rz
    sorry it took so long. It makes a sound similar to the battery dying, but that is only on a hot start. Everything is fine with the batter I have had it tested. I should also say that probably 60% of the time on a hot start it is fine. I have also been thrown suggestions about it being a relay.
  4. Mar 28, 2016 at 6:02 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You have bad injectors. The hard, hot start is the smoking gun.
  5. Mar 28, 2016 at 6:06 PM
    sypher651
    1996 Tacoma 4x4 3rz
    So be honest if I were to watch a few movies on youtube could this be done by me or should I have this done my a mechanic?
  6. Mar 28, 2016 at 6:30 PM
    koditten
    Kirk
    Central Michigan
    You can do it. I got faith in you.
  7. Mar 28, 2016 at 6:32 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    There are more than one cause of a hard warm start. Start diagnosing before you throw parts at it.
  8. Mar 28, 2016 at 6:35 PM
    sypher651
    1996 Tacoma 4x4 3rz
    Well it doesn't sound like the started because you can hear it wants to turn over. should I just go have it tested with a volt meter. I am not sure who has one would autozone do that kinda thing?
