Starting Problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by VCDA Texas, Aug 9, 2016.
  1. Aug 9, 2016 at 11:15 PM
    VCDA Texas
    VCDA Texas [OP] New Member
    2012 Tacoma TSS
    I have 2012 Tacoma that will not start. Here is what happened the day the problem arose.
    Woke up for an early morning fishing trip, truck started without issue (normal start), backed the truck into the garage for loading, approximately fifteen minutes later, NOTHING - zero clicking, headlights will not work.
    Several dash icons will appear when trying to turn on followed by dash light flashing on and off.
    I then jumped it and drove around town for a good fifteen minutes thinking it was a battery issue. Got home, turned it off, tried to start it - NOTHING again.
    Checked the battery terminals- both were snug and secure. There was slight corrosion, that was cleaned - no start. Battery cables are in good condition.
    Pulled the battery and had it checked - good battery. Pulled the alternator and had it checked - good alternator.
    Checked the fuses - fuses are fine.
    I'm thinking it may be the starter or some kind of switch. Any advice would be greatly appreciated.
  2. Aug 10, 2016 at 3:38 AM
    jmich2001
    jmich2001 Well-Known Member
    Toms River, NJ
    12 Access Cab TRD OR
    Yellow Fog Lamps, Ham Radio
    check all body grounds and ground connections to the engine
  3. Aug 10, 2016 at 4:04 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Bang the starter with a rubber mallet
  4. Aug 10, 2016 at 7:59 AM
    VCDA Texas
    2012 Tacoma TSS
    I've been hearing from folks to do that. What am I looking for or sounding for when doing that?
  5. Aug 10, 2016 at 8:00 AM
    VCDA Texas
    2012 Tacoma TSS
    Good suggestion, thank you.
  6. Aug 10, 2016 at 8:08 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Starter solenoid engagement which will thrn crank your engine over. If it does that, your starter contacts are most likely corroded or dirty. Pull starter and inspect and clean as necessary.
  7. Aug 10, 2016 at 9:52 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    "Starter solenoid" is what U really want to hit not the starter it self.
    12TRDT gave you excellent advise.
    12TRDTacoma[QUOTED] likes this.
  8. Aug 10, 2016 at 9:57 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    did you load test the battery? Sometimes it will have good charge but one of the cells are bad and when you put a load on it, it wont start.
  9. Aug 10, 2016 at 8:16 PM
    TexasWhiteIce
    Texas
    Well, if anything is bad or not working, just bang on it with a rubber hammer....Goes for cars, appliances, electronics, kids...
  10. Aug 10, 2016 at 8:23 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Don't think it is the starter, if the headlights don't work.
    Probably battery.
  11. Aug 10, 2016 at 8:27 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    If it will start with a jump, it's not the starter, it's the battery.
  12. Aug 11, 2016 at 10:13 AM
    RogueSailor
    RogueSailor IG: RogueCoastie
    Jake
    Sacramento, California
    2013 Silver Streak Mica DCSB Tacoma TRD Offroad
    Tailgate anti-theft mod Front and Rear mud flaps removed Stage 4 Icon w/Tubular UCAs 17" Method NV's 33" BF Goodrich KO2 Debadged Rago bed stiffners Rago rock sliders All Pro high clearance rear bumper
    Had this same issue with my 2013 about a year ago. Troubleshooting led me to battery. Went an bought a Optima Red Top. Haven't had an issue since I installed the new battery. Not sure what's up with the stock batteries other then maybe poor quality?
  13. Aug 11, 2016 at 10:29 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Battery. I had a battery that I had check and voltage came back good, put a load on it and failed.
  14. Aug 11, 2016 at 3:53 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
    Battery, mine did the same thing last year.
