starting problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by VTDave, Jul 29, 2009.
  1. Jul 29, 2009 at 6:59 AM
    VTDave
    VTDave [OP] Well-Known Member
    Vermont, USA
    05 Access Cab 4x4 Base 5sp Man, 16 DCSB 4x4 Sport 6sp Man
    Help me figure out what I did to my truck. On Sunday I hauled some firewood a few hundred yards in the woods, washed the truck thoroughly, and repainted the frame with Rustoleum black to keep the rust off this winter (spray paint).
    This morning I get back in the truck for the first time since Sunday. I turn the key and nothing happens. No cranking. I ASSume it's the battery and hook-up a booster. Still no cranking. All the accessories (lights, stereo, blower fan) work as normal. Guess it's not the battery.
    I had to run (literally run, not drive) to work today and didn't have time to get further into the diagnostics. When I get home tonight, where should I start looking?
    A couple of theories/questions:
    1. Are there any sensors I could have accidentally gotten wet when washing the underbody or gotten a little spray paint on that would kill the start process?
    2. Obviously, I'll check connections to the starter
    3. What sensors are required to report to the ECU/PCM before cranking can begin?
    Thanks,
    Dave
  2. Jul 29, 2009 at 7:04 AM
    98tacoma27
    Ben
    Not Beech Creek
    Did you try jumping it with another vehicle? Boostpaks don't always work. Try charging the battery.
  3. Jul 29, 2009 at 7:08 AM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    I wouldnt assume that its the battery as all his other electronics are working, I would look over everything that got painted and make sure there wasnt anything that shouldnt have been. Also try tapping the starter with something to c if it makes it start, it could be going defective, but I havent heard of that happening to anyone yet.
  4. Jul 29, 2009 at 7:19 AM
    98tacoma27
    Ben
    Not Beech Creek
    The electronics can still function on a low battery. It may also be a fuse.
  5. Jul 29, 2009 at 7:20 AM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    yeah thats true but usually you would hear a tick when trying to start it wouldnt you? Im not the best person to be giving advise i guess lol Im usually the one asking for it.
  6. Jul 29, 2009 at 7:21 AM
    VTDave
    Vermont, USA
    I'll try that when my wife gets home with her car. The Boosterpak worked the 1 time I needed it, so once again I ASSumed it was working this morning. Always good to check, though.
  7. Jul 29, 2009 at 7:24 AM
    98tacoma27
    Ben
    Not Beech Creek
    Sometimes you have a "tick", sometimes you don't. It all depends on the battery's charge.
    I recently had the same issue on my pontiac. Everything electrical worked (no tick when starting) but the battery was low. It wouldn't even start with the charger set to the 100 amp start setting. I had to jump it with the Tundy.
  8. Jul 29, 2009 at 7:26 AM
    VTDave
    Vermont, USA
    So, what stuff could I have accidentally sprayed with paint that would prevent starting? Example: let's say I got some overspray on an 02 sensor. That wouldn't prevent starting. Maybe it would throw a code.
  9. Jul 29, 2009 at 7:29 AM
    98tacoma27
    Ben
    Not Beech Creek
    That wouldn't do anything. The sensor part is inside the exhaust. They are well sealed sensors. I don't think anything you could have sprayed with paint on the frame would effect starting.
    How did you clean the frame? Spray it with a hose?
  10. Jul 29, 2009 at 7:33 AM
    VTDave
    Vermont, USA
    I scrubbed the frame by hand with soap and water, and then used a hose sprayer for rinsing.
    Everyone may be right that it's just the battery (I'll found out tonight), but the fact that it came right after the rinsing and painting got me thinking it could be more complicated. So, I wanted to be prepared to think about other causes in addition to the battery.
  11. Jul 29, 2009 at 7:35 AM
    98tacoma27
    Ben
    Not Beech Creek
    Check the fuses also. You may have shorted the IGN when you rinsed close to the starter.
  12. Jul 29, 2009 at 7:39 AM
    97Blk_one
    97Blk_one Well-Known Member
    Memfrica
    not so low
    A whole lot,But not satify
    what's year is your truck? If every accessories are working,and you have the juice(light up,head light,stereo)are working normal
    Here the bad news:
    1/ it's could be your distributor(won't spark up)
    2/ Your ECU is fried.
    It's happens to me a while back,everything working fine.I pulled in the Garage. I need to get out to get some stuff couldn't start. Battery still good. Haul it to the Stealer(Don't do what I did) It's was the ECU, cost me about 2 weeks of my paycheck. I hope your is not that serious.Good luck
  13. Jul 29, 2009 at 7:40 AM
    98tacoma27
    Ben
    Not Beech Creek
    It's an 05. It has coil packs, no distributor.
  14. Jul 29, 2009 at 7:41 AM
    97Blk_one
    Memfrica
    not so low
    Ok,my bad. I got 97:)
  15. Jul 29, 2009 at 7:46 AM
    WoadWunner
    WoadWunner Well-Known Member
    Peter
    Bridgetown, Nova Scotia
    17 Accesscab TRD Offroad Inferno
    Tonneau Cover, Devils Horns on the way, Blackened Grill, LED Low beams and Fogs, weathertecs
    When you painted your frame, you may have painted over the ground. To check, when you boost you truck, use the battery for a ground. If it starts, your ground is good. If is does not start, switch the ground to the engine or frame. If it starts now, you ground is dirty.
    Good luck
  16. Jul 29, 2009 at 7:56 AM
    VTDave
    Vermont, USA
    Thanks everyone. When I get home, I will try:
    1. Jump start with a car
    2. Check fuses
    3. Check grounds
    4. Hope the list is done by #3.
    I'll report back.
  17. Jul 29, 2009 at 8:20 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Mine clicked last night as well. I really don't get how all my problems appear on here from someone else right as I have them! At least it started on second try, no problems since.
    I will second one thing though, the MOST LIKELY is your starter, its always subject to the weather. If it doesn't start, bang the starter with a hammer or maul, something big, try it twice at least. Sometimes you'll knock some shit loose and allow the brushes to make better contact.
    Do your lights dim when you turn this key? If they do, your starter is working :thumbsup: Find the problem somewhere else, probably the battery.
  18. Jul 29, 2009 at 8:22 AM
    98tacoma27
    Ben
    Not Beech Creek
    It's your u-bolts. They need torqued to 75#.
  19. Jul 29, 2009 at 8:45 AM
    brian
    Elizabeth City, NC
    haha, I believe it very possibly could be my muffler bearing too. ;)
  20. Jul 29, 2009 at 8:51 AM
    bobwilson1977
    bobwilson1977 Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    Check the battery voltage first. Then go from there.
