Starting Problems and HVAC odor??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PPower05, May 29, 2011.
  1. May 29, 2011 at 6:44 AM
    PPower05
    PPower05 [OP] Well-Known Member
    Perry
    Ranson, WV
    2010 SR5
    Hey guys,
    Got 2 problems today that I would like to run by the masses. I got a 2010 DC TRD Off Road with about 23,800 miles on it, bought it new approx. 1 year ago... My first issue is when starting the truck.... It does not happen all the time, but sometimes it is taking more than a few extra cranks to turn over... Just when you think the truck has turned over, you release the key only to find that the truck is not running.... I didnt think much of it when it was 20 degrees outside, however, with weather being in the 90's, I don't see why this should be happening.... I have tried fuel system cleaners, I replace the air filter about every 12,000 or when it is dirty, and change my oil every 5000 with Mobil 1. I did not notice this when I first purchased my truck, it is a problem that appears to be getting worse.... Any ideas?
    My second is my HVAC system. There is a smell coming from it that I can not seem to get rid of.... Anyone have any experance in cleaning the HVAC system in their car?? I replaced my cabin air filter with the air filter mod that I found on the fourm... It appears to be clean, however, I will replace it... Dealership wanted 140 to do a "HVAC system deodorizing"...
    Thanks!
  2. May 29, 2011 at 7:03 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
  3. May 29, 2011 at 7:12 AM
    AnotherSilverTaco
    AnotherSilverTaco Well-Known Member
    South Texas
    2006 Double Cab 4x4
    CBI trailrider rear bumper, CBI Front Receiver, Warn M8000 Receiver Winch in Warn Multi-mount cradle
    Do you have any ememies? Could someone have tampered with your truck? I have heard of people pooring noxious things like ground shrimp/fish juice into the cowl vents. Seems odd that you are having 2 issues at once to me. I will say I did have a few times when my truck wouldn't startimmediately like that around the same odometer reading. It worked itself out and never had the problem again in 77k. Check to see you aren't using a large keyring, hanging the keyring over top of the rubber part of the key, or have a dirty key. I would suspect the anti-theft system or key.
  4. May 29, 2011 at 8:27 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    03 F250 CCSB
    Gibson stainless headers, custom free-flow Y-pipe, Magnaflow muffler, 285/75R16 KBro2's
    There is a TSB about a computer caused no-start condition. If it doesn't start, then you turn it fully off, and successfully start it the second time, then you have the TSB issue. I don't recall the number off-hand, but there is a TSB list sticky on this forum.
  5. May 29, 2011 at 8:43 AM
    2011toy
    2011toy Member
    Jim
    TRD
    The 2011 owners manual suggests that the fresh air damper on the A/C be left open (not on recirc) when the truck is not running. This must help those odors to vent out over night.
  6. May 29, 2011 at 10:52 AM
    PPower05
    Perry
    Ranson, WV
    2010 SR5
    The HVAC problem is not that big of an issue... It was just noticed by the dealership.... It doesn't smell horrible, however, I can smell it... I was just wondering what people are doing to correct the problem... I have heard spray anything from lysol to scrubbing bubbles into the cowl vent... The starting issue is my most pressing issue..... This worries me, as the truck is still pretty damn new...
  7. May 29, 2011 at 11:15 AM
    Maticuno
    03 F250 CCSB
    Found the TSB number:
    EG011-07 JUL 07 Engine Controls - Intermittent No Start Condition
  8. May 29, 2011 at 11:48 AM
    redezman
    redezman Well-Known Member
    Charles
    Raleigh N.C
    2012 4Runner SR5 4x4
    All Factory for now, LOVE it that way
    MT Madman [​IMG]
    what he said, i do the same.
    never has a issue with any of my cars or trucks doing this.
  9. May 29, 2011 at 2:09 PM
    joes06tacoma
    Joe
    Central Coast, CA
    This. Mine's only done it one time, but it sure made my heart jump sitting in the middle of nowhere with no cell signal.
    What does your HVAC smell like? Mine has an intermittent smell also. It smells like gear oil. First time it happened I had just recently had the transmission serviced and thought it might be residual oil somewhere. But it's continued to be an intermittent issue. Only smells inside the truck, and usually after a half hour drive on the freeway or longer.
  10. May 29, 2011 at 6:44 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Ac problem is caused by bacterial/fungus growth from moisture and organic material. Kill it with lysol, or similar disinfectant aerosol. BG Frigi-Fresh works well too.
