Starting problems Rough idle?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jocoma, May 15, 2015.
  1. May 15, 2015 at 8:48 AM
    Jocoma
    Jocoma [OP] Well-Known Member
    Jo-mama
    Olympia,WA
    08 Prerunner SR5 Rugged Trail
    Home made satochi trd grill BFG AT 265 75 16 Dipped badges TRD stub antenna More to follow : spindle lift,Halo lights, Kicker sound sytem ,Slotted rotors TRD Seat covers When the cash starts flowing
    Idk why seems like every other month that my Tacoma doesn't fire up right away.
    I noticed after it rained it always has this problem. So I decided to add some reet
    to the gas to take any moisture out and an new gas cap. It has 79 xxx and
    I did a recent tune up sparks oil regular stuff filter.
    Yesterday seems like the truck didn't want to fire up and was idling rough is it time for the timing to be checked ? Anyone know what needs to be changed or checked at this point in the trucks like? Is it worth the Toyota maint check up for a multi point inspection
    Thanks TW
  2. May 15, 2015 at 8:54 AM
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    Rough Idle is most often a vacuum leak. Check your lines for cracks.
    Often when changing the #6 plug, drivers side towards firewall, the vacuum line above it gets pulled for clearance, I would check that first.
  3. May 15, 2015 at 9:30 AM
    Jocoma
    Jo-mama
    Olympia,WA
    ok sure thing I will check it out thanks
