starting prolems
Discussion in '1st Gen. Tacomas (1995-2004)' started by jon4x4tacoma, Apr 26, 2016.
  1. Apr 26, 2016 at 5:07 PM
    jon4x4tacoma
    jon4x4tacoma [OP] Member
    hello I have a 1999 Toyota Tacoma 2.7 4x4 and have problem with it starting when it heats up and I shut it off. I have replaced the starter and the starter relay still have the same problem. please someone let me know what is wrong or what u think. I have owned the truck for the last 40000 miles and just this last warm spring have had this problem. i turn the key and the starter relay clicks does not crank the funny thing is it doesn't do it all the time just when it wants to. all it takes is time for it to cool down a lil like 10 to 15 min then it will always start.
  2. Apr 27, 2016 at 5:08 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    "... problem with it ... " is not descriptive enough.
    - Turn key and complete silence ?
    - Turn key and something clicks ?
    - Turn key and motor 'cranks' but doesn't fire at all ?
    - Turn key and motor 'cranks' and sputters?
  3. Apr 27, 2016 at 6:25 PM
    jon4x4tacoma
    oh sorry about that the starter relay clicks I think. does not turn over
  4. Apr 27, 2016 at 11:04 PM
    tan4x4
    Rick
    Folsom, CA
    My money would be on the copper contacts in the starter solenoid.
    If you have a an original factory starter, its better to re-build it for $20 than get a new aftermarket starter.
  5. Apr 27, 2016 at 11:14 PM
    jon4x4tacoma
    you think so It didn't take long after I put the new one in and drove it shut it off and clicked once when I turned the key same problem so then I put a starter relay in still same problem I'm betting its not the starter. any other thoughts
  6. Apr 27, 2016 at 11:15 PM
    jon4x4tacoma
    but I could be wrong been know to be once or twice.
  7. Apr 28, 2016 at 8:09 AM
    tan4x4
    Rick
    Folsom, CA
    Sorry, I didn't catch that you replaced the starter motor in your first post, I just saw 'starter relay'.
    So, the relay clicks, but the starter motor does not attempt to engage and rotate the flywheel ?
    When this happens, do the headlights work OK ?
  8. Apr 28, 2016 at 3:19 PM
    jon4x4tacoma
    I think I got it figured out all let u know thanks I think its was the battery. It couldn't be that easy will see. laugh out loud
  9. Apr 28, 2016 at 3:25 PM
    jon4x4tacoma
    doesn't engage starter the power goes dead in cab, when I turn the key, never happened in the dark. Im sure the headlights do too. I'm gunna check the battery I cant believe I didn't think of that. it seemed fine will see
  10. Apr 28, 2016 at 10:28 PM
    tan4x4
    Rick
    Folsom, CA
    could also be dirty cable clamps, or cable internally corroded.
