Starting question
Discussion in 'Technical Chat' started by Major Dad, Nov 12, 2008.
  1. Nov 12, 2008 at 7:17 AM
    Major Dad
    Major Dad [OP] Member
    Minnesota
    1997 Tacoma SR5
    I have a starting question. I have a 1997 Tacoma with a 3.4. Is it normal for it to crank for 5-8 (guessing) seconds before it fires, longer when it’s cold. I have only had this truck for 4 months so I’m not too familiar with its starting.
    Comparing it to one of my other vehicles, 1999 Grand Am you can't let go of the key fast enough and it's started
    I have good fuel pressure, though my spark is not right away when cranking, it comes just before it fires.
    Is it possible that my cam or crank sensor is getting bad?
    Any ideas would be great.
    Thanks
  2. Nov 12, 2008 at 7:21 AM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    My 02 does the same thing. I have driving lights hard-wired to the battery, when I crank they really dim. Haynes manual says if the battery is weak it can cause hard starting. Figure that's what's going on with mine, soon as I start getting paychecks in again I'm gonna replace it with something kick-a$$.
  3. Nov 12, 2008 at 7:34 AM
    Major Dad
    Minnesota
    1997 Tacoma SR5
    I just replaced the battery with a 675CCA no different. the original one was 550 CCA
  4. Nov 12, 2008 at 7:42 AM
    lakewoodbilly
    lakewoodbilly Well-Known Member
    Bill
    Lakewood, CO
    White 08 DC V6 SR5 4WD TRD Sport
    Factory DRL's, Underhood Flood LED's, Underbody Multi-color LEDS, Red Line Tuning Elite Hood Struts, Anytime Fog Lights, PIAA 4100 Intense White, Luminics JDM Yellow H10 Fog Lights, OBX Sport Pedals, Sill Protectors, Bed Net, Front Bed Tie Downs, iPod and Aux Factory HU Interface, Sirius Sportster 5, Satellite Antenna through third brake light
    what is (was) the current ambient temperature?
    My old '91 toyota would take a little longer to start when it was cold, like the 5-8 seconds you are experiencing. When it was warmer, it would take 2-4 seconds.
    I had one experience where I hadn't driven it in a month because I was moving from CO to NC and it was parked at about 6500 feet elevation. When I went to pick it up, it was -10 degrees and it took us about 5 minutes to get the thing to start.
  5. Nov 12, 2008 at 8:07 AM
    Major Dad
    Minnesota
    1997 Tacoma SR5
    temp doesn't seem to make a differnece. it has been warm and cold.
  6. Nov 12, 2008 at 9:09 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Change the battery out. Winter is starting rear its ugly head and I'd rather be safe than sorry. Although it's gonna be in the 90s by the end of the week here in SoCal.
  7. Nov 30, 2008 at 9:11 PM
    URBAN ASSAULT VEHICLE
    URBAN ASSAULT VEHICLE New Member
    Toronto Canada
    97 TACO
    Fiberglass Bed, 4-runner hood and fenders, 3-inch lift, 33's, brakes
    I'm having a similar problem with my 97, except the problem gets better when it's cold. It's as if the choke is on all the time. In the summer it takes 3-5 seconds, or in the winter when its warm. However, go out in the morning on a cold day (I live in Toronto so that's like -15) and it starts better than a brand new 09. Can anyone help?
  8. Dec 1, 2008 at 4:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The ECU wont send a spark signal until the oil psi. is up to a set point. Many first gen Tacomas have this "issue".
  9. Dec 1, 2008 at 5:10 PM
    HerNameIsLucy
    RIP Lucy.
    damn Chris...just with little things like this you've helped me understand what's going on...thanks!
  10. Dec 1, 2008 at 8:07 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    i might say change out the battery but i'd listen to Chris:D
    about the grand am american car makers always tend to over-engineer their starters
  11. Dec 3, 2008 at 4:38 AM
    Major Dad
    Minnesota
    1997 Tacoma SR5
    Hey Chris is their a fix for this Issiue or do I have to live with it?
    Thanks
  12. Dec 3, 2008 at 4:44 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You could could change out you oil psi sneding unit. Drop the oil pan and make sure the pick up is clear, but I think thats about it. Maybe run an engine flush. Its a normal condition for the 3.4. I was thinking about it yesterday, and if, indeed, its takeing 8 sec. to crank, that IS a little on the long side.
  13. Dec 3, 2008 at 4:48 AM
    Major Dad
    Minnesota
    1997 Tacoma SR5
    I have notice that it does take longer for it to start when it is colder out. But when its warm it pops right off. Would you u still change the oil sensor for cold starting problems?
    Thanks
  14. Dec 3, 2008 at 4:56 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What kind of oil are you useing?
  15. Dec 3, 2008 at 4:57 AM
    Major Dad
    Minnesota
    1997 Tacoma SR5
    Chevron 5W40 synethic
  16. Dec 3, 2008 at 5:05 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Can you time it with a stop watch and let me know exatly how long it is takeing? Maybe switching to a 5w-30 will be a good idea.
  17. Dec 3, 2008 at 5:36 AM
    Major Dad
    Minnesota
    1997 Tacoma SR5
    I will check it tomorrow morning. Would you consider changing the oil sensor anyway?
    And is there only one on it?
  18. Dec 3, 2008 at 8:11 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    Why are you using 5w40 in the first place? It might be too thick for the climate you're in.
  19. Dec 3, 2008 at 12:45 PM
    Major Dad
    Minnesota
    1997 Tacoma SR5
    I've been using it for the past 3-4 years in multiply vehicles and have had no problems with starting issues. But if you think changing to a 5w30 would make a difference I'm willing to try it. Remember this tacoma is new to me and i just picked it up this past summer with 300,000 miles on it.
  20. Dec 3, 2008 at 3:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im still looking into this. I dont know of anyone who has run 5w-40 in their Tacoma. Manual calls for a 5w-30 in your climate. Have you timed how long it cranks yet?
