Starting Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Major Dad, Nov 12, 2008.
  1. Nov 12, 2008 at 4:34 PM
    Major Dad
    Major Dad [OP] Member
    Minnesota
    1997 Tacoma SR5
    I have a starting question. I have a 1997 Tacoma with a 3.4. Is it normal for it to crank for 5-8 (guessing) seconds before it fires, longer when it’s cold. I have only had this truck for 4 months so I’m not too familiar with its starting.
    Comparing it to one of my other vehicles, 1999 Grand Am you can't let go of the key fast enough and it's started
    I have good fuel pressure, though my spark is not right away when cranking, it comes just before it fires.
    Is it possible that my cam or crank sensor is getting bad?
    Any ideas would be great.
    Thanks
  2. Nov 12, 2008 at 4:37 PM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    My 99 taco did that around 140,000 try fuel cleaner and higher octane gas if that does not work put a new starter in it that worked for me!!!
  3. Nov 13, 2008 at 10:59 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    I have a similar problem with mine. I'm thinking it's either battery, starter, or (possibly? ) alternator.
  4. Nov 13, 2008 at 11:12 AM
    Major Dad
    Minnesota
    1997 Tacoma SR5
    I changed out the battery still the same, I don't know how or why the statter would cause this problem.
    2cents
  5. Nov 13, 2008 at 11:15 AM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    well if the starter is warn out and losing cranking power it will take longer to crank... how many miles you got??
  6. Nov 13, 2008 at 11:20 AM
    Major Dad
    Minnesota
    1997 Tacoma SR5
    302345 miles It cranks over really fast, if it would be the starter, I could see it causing the problem if its drawing alot of amps causing less to go to the ignition.
