Starting the engine after it is already running
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2015WhiteOR, Jan 19, 2025.
  1. Jan 19, 2025 at 4:11 PM
    2015WhiteOR
    2015WhiteOR [OP] Well-Known Member
    Gainesville TX
    Did it the 2nd time today since I've owned the truck since new.
    Never a good sound or feeling when it makes that harsh metallic scrape. :mad:
    I know these trucks obviously don't have anything built in to prevent it from happening (like some luxury cars have such a feature), but was the engine supposed to cut out when it happened? (had to cycle the key to off and then crank it back on)
    I feel like the first time I did it, the engine kept running.
  2. Jan 19, 2025 at 6:26 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    I could see it stalling the engine if the starter gear hits the fly wheel just wrong.
    Your not the first or last who has done this. Just try not to do it again and honestly your truck is probably gonna be just fine.
    2015WhiteOR[OP] likes this.
  3. Jan 19, 2025 at 6:33 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    You'll ruin the starter before you hurt the engine.
  4. Jan 19, 2025 at 7:00 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Mine hasn’t stalled when I did it…….:anonymous:
    I just got an awful grinding sound, and a sick stomach……:eek:
  5. Jan 19, 2025 at 7:50 PM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    I've also done this once on my Tacoma. When I changed the clutch, I removed the flywheel and starter and the gears on both looked like new, no visible damage at all.
