starting to feel like a new one...
Discussion in '1st Gen. Tacomas (1995-2004)' started by hubcapsc, May 29, 2019.
  1. May 29, 2019 at 7:07 AM
    hubcapsc
    hubcapsc [OP] Un-Known Stranger
    Upstate South Carolina
    2002 6cyl 4x4 manual
    I'm sitting at the Anderson SC Toyota dealer now... They did some work on
    my truck last week, flushed the hydraulics and radiator, new gas filter,
    valve cover gasket, timing belt...
    There's a small leak from the upper radiator hose now, I think they're going to just put
    a "regular" hose clamp on it, I know timmy-the-toolman likes the OEM kind better.
    Anywho... I got my truck a little over a year ago now... it was pretty functional then,
    but had 150k miles on it. The inside is good, the outside is good (even though it is
    the boring lunar mist color :) ) but the most important stuff is the stuff you can't
    see.
    The frame is good.
    I've changed all kinds of little things myself that were worn or bad, such as changing
    out the loud-air-box with an OEM setup I got on eBay, and the gasket around the driver's
    door other little things like that.
    One of the first things that was done is to change out a couple of sensors to fix the CEL.
    That made it run a lot better (open loop)... and it might be a bit better running after changing out
    the gacky gas filter.
    What really makes it roll down the road like a new one, though is the new wheels/tires
    sourced from a 2018 Tacoma with 20 miles on it, plus all new steering and front suspension stuff
    that has accumulated under there over the course of a year...
    The only disappointment there is that I went after $200 worth of lca bushings and
    expected $200 or so of labor and got new lca's in$tead...
    There's Deaver J59's on the back, and kings for back there have been "in the works"
    for a couple of months... they're supposed to show up tomorrow, I hope they fit... the
    first set was OEM length (too short) and the reservoir hose outlet was situated in
    the same orientation as the shock mount eyelet (won't fit up in there where it needs to go)...
    I wish I had a well-lit plush concrete floored garage to work in, I like working on stuff,
    but most of the work on my truck has been done at one of three shops in my area...
    More good than bad at all of them, I think I kind of like this dealer... skilled mechanics
    with all the tools and lifts and experience can do a better job of stuff than me learning
    on my own truck working in the dirt, even with timmy-the-toolman videos for guidance...
    my 97 Valkyrie with 100,000 miles on it goes pretty much like a new one, and I do all
    the work on it...
    They don't make little trucks anymore, and they're just "things", but mine makes
    me smile when I go down the road now...
    -Mike
    Ridgerunner, GQ7227, Wsidr1 and 3 others like this.
  2. May 29, 2019 at 8:43 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    That fresh high end suspension is soooo tempting just to have a nice comfy plush ride. Looks good. Can tell you value your taco, that's a good thing
    GQ7227 likes this.
  3. May 29, 2019 at 10:07 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Well done Mike! I envy you your ability and means to work on stuff like that. I'm 58 now and have a permanent vascular disability but when I was younger I did it all-from simple oil changes and tune-ups to rebuilding the engine in my '68 Cutlass and even an engine/trans swap in my '73 Delta 88.
    I remember that feeling of accomplishment and pure contentment you express here. And I miss it.
