Starting to question safety...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dave91, Apr 28, 2015.
  1. Apr 28, 2015 at 3:32 PM
    dave91
    dave91 [OP] Well-Known Member
    dave
    quebec
    I have a 2007 tacoma with a 3" lift and just recently put on my summer tires which are 275/65r16. Since i switched my tires, i find that every bump i hit, my truck swerves a lot. The worst is when on the highway. i'm now avoiding going beside 18wheelers because if they're beside me when i hit a bump, i might hit them.
    Is this something i need to learn to put up with because of bigger tires??
  2. Apr 28, 2015 at 3:50 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Sounds like it's time for new shocks and maybe some front end work, too.
  3. Apr 28, 2015 at 3:50 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    the extra width will tend to grab more imperfections in the road.
    But with the proper amount of caster you should be good to track straight.
  4. Apr 28, 2015 at 3:55 PM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    Do you have aftermarket upper control arms on? If you don't then I think that's the reason for the wandering. Your caster must be very low.
  5. Apr 28, 2015 at 4:04 PM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    Definitely. +1
    Unless they are LT tires, in which case the pressure should be significantly higher than the stock P tire pressure. Between 40 and 45 psi for a LT tire around that size (the Baja/Pro actually list 46 psi on the placard for their LT tires).
  6. Apr 28, 2015 at 4:05 PM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    Could be more than a few things.Alignment,tire pressure,tire width,shocks,UCA's.
  7. Apr 28, 2015 at 4:50 PM
    dave91
    dave
    quebec
    they are LT and they were put at 60 psi.
    Before being at 60, they were around 25 and it was as bad.
  8. Apr 28, 2015 at 4:53 PM
    dave91
    dave
    quebec
    i'm actually not even sure. i got it with the lift so not sure what previous owner did to it...
    I wasnt swerving with smaller tires, is it only with bigger tires that i need to worry about the upper control arms?
    Can anything bad happen...?
  9. Apr 28, 2015 at 4:59 PM
    DVexile
    Ken
    OK, well 60 is definitely too much. (And yes 25 way, way too low for an LT on road) An over inflated tire will in fact cause you to wander all over the road - essentially the wheel bounces too much so you are losing traction all the time. Since you are losing traction after bumps that matches up well with the cause being tire over inflation. So that could be part of your problem if not all of your problem.
    Again, for an LT tire around that size you should be around 45 PSI. Manufacturer specifies 46 PSI for an LT tire of about that size, for both front and rear.
    As others said alignment can play a big role too, but for starters lower the tire pressure to the manufacturer's specification and see how it behaves.
  10. Apr 28, 2015 at 5:02 PM
    dave91
    dave
    quebec
    Great! thanks for your help!
    Sorry for my ignorance but is there any way to tell is my UCA's are stock?
  11. Apr 28, 2015 at 5:03 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    You can post a photo.
  12. Apr 28, 2015 at 5:09 PM
    Rotnik
    Rotnik Well-Known Member
    Connecticut
    13' TRD OR AC V6 6MT - In spruce
    If you can't tell throw a picture up....you'll be surprised how fast one of these guys will answer your question for ya
  13. Apr 28, 2015 at 5:12 PM
    MGtaco2.7
    MGtaco2.7 MEMBER
    NW Ohio
    18 DCSB 4X4 SR5 Silver Sky Metallic V6 AT
    Also, have you re-torqued your lugs?
  14. Apr 28, 2015 at 5:15 PM
    dave91
    dave
    quebec
  15. Apr 28, 2015 at 5:17 PM
    Pigpen
    Dan
    Northwest Montana
    My truck does the same thing when I have my aftermarket wheels (with backspace) on - same size tires, just wider stance and it tries to wander constantly. I'm lifted on stock UCAs, so I'm caster-impaired. No wander on stock wheels.
  16. Apr 28, 2015 at 5:18 PM
    Pigpen
    Dan
    Northwest Montana
    Those are stock
  17. Apr 28, 2015 at 5:20 PM
    dave91
    dave
    quebec
    so what are my options?
    is it a bad thing?
  18. Apr 28, 2015 at 5:32 PM
    DVexile
    Ken
    Well the options I think come down to:
    - Install aftermarket UCAs. Head over to the suspension section for lots of posts to search regarding that.
    - Adjust the lift down to 2" instead of 3" which will get you in better alignment range for the stock UCAs.
    - Live with the current setup after driving with tires at proper inflation.
    In general 2" of lift is worry free. At 3" of lift a lot of little things start to add up to potential problems (poor alignment, CV boots rubbing and wearing through, driver side bearing vibrating). Plenty of people run 3" with stock stuff and don't have significant issues, but many people also run into a lot of issues and start having to swap out components.
  19. Apr 28, 2015 at 5:33 PM
    Bman4X5
    Bman4X5 There is no substitute for square inches.
    Bruce
    Upland CA
    '15 AC/OR
    Bilstein, Dakar/Icon, Prinsu, CBI, Pelfreybilt, Tepui
    Take it in for an alignment. If they can't get the caster higher than 2.2 or so, you probably need after market UCAs. Light Racing UCAs are affordable.
  20. Apr 28, 2015 at 5:33 PM
    Pigpen
    Dan
    Northwest Montana
    Your best option is to put on UCAs. Maybe get someone's stock take offs from craigslist to see if that makes a difference. You live where there's winter, so running 2 sets isn't a bad idea anyway.
    First things first, though. get your tire pressure to around 40 and see how much that helps. Both 25 and 60 are going to cause wander for opposite reasons. I'd get the lift down to 2.5 or lower if you don't do UCAs
