Starting trouble
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Eds321, Jan 15, 2022.
  1. Jan 15, 2022 at 7:47 PM
    Eds321
    Eds321 [OP] Member
    Ares
    Tacoma TSS 4X4
    None...yet =D
    Truck struggles to turn on. Sounds like it doesn’t want to but then it does. I checked the battery and terminals all good there. Any idea what it could be? Starter?
  2. Jan 15, 2022 at 7:49 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Did you do a load test on the battery or just checked voltage with a multimeter?
  3. Jan 15, 2022 at 7:51 PM
    Eds321
    Eds321 [OP] Member
    Ares
    Tacoma TSS 4X4
    None...yet =D
    Just with multimeter, I’ll do a load test. Thank you
    shakerhood and Captqc like this.
  4. Jan 15, 2022 at 7:53 PM
    eurowner
    eurowner Duke Sky
    Scoty
    What year is the truck? How old is the battery? Is there any corrosion under the battery positive terminal cover?
    did you install any electrical mods?
    Skydvrr likes this.
  5. Jan 15, 2022 at 7:57 PM
    Eds321
    Eds321 [OP] Member
    Ares
    Tacoma TSS 4X4
    None...yet =D
    2019 Tacoma, battery is 3 years old, I installed some fog lights. Other than nothing else
    tacotoe and eurowner like this.
  6. Jan 15, 2022 at 7:57 PM
    Eds321
    Eds321 [OP] Member
    Ares
    Tacoma TSS 4X4
    None...yet =D
    There is no corrosion
  7. Jan 15, 2022 at 8:02 PM
    Bishop84
    Bishop84 Well-Known Member
    Likely a battery. 1 month or 7 years, it really doesnt matter, they can always fail.
    Local part stores test them on site.
    tacotoe, Eds321[OP], Skydvrr and 2 others like this.
  8. Jan 15, 2022 at 8:03 PM
    Just_A_Guy
    Just_A_Guy Rain is a good thing
    On the hunt
    A truck
    Sounds like the battery might be bad, even if it tests as being ok.
  9. Jan 15, 2022 at 8:10 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    If you are still under warranty, see if Toyota will give you a free battery. I got a new free battery at 33 months into my warranty. No electrical mods on my truck so hopefully Toyota does not try to blame your fog lights.
    tacotoe and Eds321[OP] like this.
  10. Jan 15, 2022 at 8:52 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Seems like the OEM battery average lifespan is 3 years.
  11. Jan 15, 2022 at 10:32 PM
    TA2016
    Oregon
    Going on 40 months on my Toyota replacement battery. My Daughter's Scion battery is coming up on 7 years. I was going replace it because of age, but it fires right up even after sitting in freezing temps for a week. I guess Toyota batteries are hit or miss.
  12. Jan 15, 2022 at 10:51 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I tend to see a lot of them fail for people who don't do longer trips. My truck is still on the stock battery from late 2016. But I also drive 90 miles per day for work.
  13. Jan 15, 2022 at 10:55 PM
    Little Lion
    Little Lion Well-Known Member
    2018 Barcelonian Sport MT
    were you in any extreme cold? after driving car around for an hour does it start again fine? if you try boosting battery does it start fast without hesitation?
    Eds321[OP] likes this.
  14. Jan 16, 2022 at 5:20 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    You can try turning your headlights on with the truck off. With a mult-meter measure the voltage after a couple minutes of this. If its lower than 11.7 volts the battery is weak, and needs replacing.
    Eds321[QUOTED][OP] likes this.
  15. Jan 16, 2022 at 5:32 AM
    Eds321
    Eds321 [OP] Member
    Ares
    Tacoma TSS 4X4
    None...yet =D
    I did this and it was 11.6v then it slowly climbed up. New battery it is! Thank you!
    Steves104x4 and Captqc like this.
  16. Jan 16, 2022 at 7:13 AM
    Eds321
    Eds321 [OP] Member
    Ares
    Tacoma TSS 4X4
    None...yet =D
    Thank you everyone who helped me. I was overthinking everything lol. Y’all are good people thanks again!
    eurowner likes this.
  17. Jan 16, 2022 at 7:19 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    I totally misread the title of this thread. I thought the OP meant he was starting trouble :)
    OP, glad a new battery did the trick. Yes we are good people but we love making people spend money on stuff they never realized they needed :) :)
  18. Jan 16, 2022 at 7:25 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Walmart Everstart battery is the best bang for the buck
