Starting with 5100's - where to go from here?
Discussion in 'Suspension' started by dziner, Dec 29, 2016.
  1. Dec 29, 2016 at 9:57 AM
    dziner
    dziner [OP] Well-Known Member
    Jonathan
    Harrisburg, Pennsylvania
    2014 Toyota Tacoma TRD Off-Road
    Bilstein 5100 (front) | OME 885 springs | Bilstein 5160 (rear) | OME Dakar medium leafpack | JBA UCA | Cooper S/T Maxx 265/75 R16 | ARE Z-Series topper | Renogy 100W solar panel | SnoMaster TR42 fridge | sleeping platform | Mobtown sliders | Custom Car Grills grill insert
    Here's the situation. I have a 2014 TRD OR DCSB. Daily driver and I enjoy dirt forest roads and some off-road exploring. Not a rock crawler. I'd like a suspension lift for clearance and to make those back roads more comfortable. I'd like somewhere between 2.5-3" of lift and leveled out. No heavy front or rear bumpers in the plans. Trying to stay under $1500 if possible.
    The bed of my truck has a Leer cap, 200lb of sand (hey, someone said it's a good idea for the Winter), my sleeping platform, camping gear, and tools. I'm estimating about 500lb in the bed of my truck right now.
    A friend gave me a set of rear Bilstein 5100's to start with. So I'm going to start my suspension lift from those. Now how do I build out the rest of my lift?
    Here's my thoughts as of now. I've done some price shopping and offer links to Wheeler's Off-Road (cc: @YotaDan)
    FRONT:
    REAR:
    • - $412.30
    • - $29.95
    • - $12.35
    • - $15.69
    • - $60.00
    This comes to $1504.24.
    Are my choices legit? Compatible? Capable? Does anyone have any other recommendations for any of my choices?
    YotaDan and 14TacoSC like this.
  2. Dec 29, 2016 at 10:04 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    That would be a great setup. Although with the weight you have in the rear it would probably be a good idea to add in the extra leaf for the Dakars.
    dziner[OP] likes this.
  3. Dec 29, 2016 at 10:06 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I'd agree with Dan.. the AAL is cheap ($50 or so) and you'll likely see a benefit from that setup.
  4. Dec 29, 2016 at 10:08 AM
    dziner
    Jonathan
    @YotaDan There you go busting my budget already! lol
    YotaDan likes this.
  5. Dec 29, 2016 at 10:11 AM
    T4RFTMFW
    You could save $134 buy not having them assembled. ;)
    Even with the AAL, you'd be saving $80.
  6. Dec 29, 2016 at 10:14 AM
    dziner
    Jonathan
    True, but they have to get assembled somewhere. Whether I find a place around here (which takes time and driving), or have them do it before they even ship to me. It's kind of a wash?
    YotaDan likes this.
  7. Dec 29, 2016 at 10:15 AM
    T4RFTMFW
    RedRed, frejil, TacoJova and 2 others like this.
  8. Dec 29, 2016 at 10:16 AM
    dziner
    Jonathan
    So you think the full Dakar pack PLUS OME AAL for the back? Will this be too much for when I take the sand out, reducing the weight by 200lbs?
    Will the front strut and spring work together? When I clicked on the 5100's, the only springs that came up with it were the OME springs which don't look like they add enough lift.
  9. Dec 29, 2016 at 10:19 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    A lot of time you are money and time ahead if we do it. Shops will usually charge more, and they will be re-using your stock top-plates, coil isolators and sometimes the bushings and washers. The $134.00 Assembly Charge includes New Top-Plates, Coil Isolators, Bushings & Washers and they will be marked Driver and Passenger ready to bolt on.
    Also for the rear we can pre-assemble the AAL set in the packs for a labor charge of $30.00 which the majority of the time is actually much cheaper than additional shipping of the AAL set shipping as an extra package.
  10. Dec 29, 2016 at 10:20 AM
    T4RFTMFW
    IIRC it adds somewhere between .5-.75 inches.
    That said, I didn't catch the sand part (just the 500 lbs mention..). I'd omit the AAL and go with a full Dakar pack instead.
    My truck has a 240 lb constant load (+/-) and I don't use the AAL. I have OME coils up front that are around 2.5-2.75" of lift, and I still have a bit of rake.
  11. Dec 29, 2016 at 10:22 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Yep, if the sand is not going to back there all the time, then you may not need the additional leaf.
  12. Dec 29, 2016 at 10:27 AM
    dziner
    Jonathan
  13. Dec 29, 2016 at 10:28 AM
    T4RFTMFW
    It's really simple and straight forward. I'd definitely recommend that method if you have the floor jack or can get one. Certainly a money saver.
  14. Dec 30, 2016 at 7:26 AM
    dziner
    Jonathan
    @YotaDan Just emailed you this morning regarding a Wheeler's Off Road purchase. I know it's Friday before a big Holiday weekend. Just want to make sure I have everything in order and correct before purchasing. No hurry though either. We can always wait until the new year.
  15. Dec 30, 2016 at 7:37 AM
    ericd
    ericd Stuff
    Eric
    las vegas
    2013 DCSB 4x4 OR
    You probably don't need the sand in addition to the cap, gear and tools. One or the other is enough to add some weight in the bed to increase traction in snow and ice.
  16. Dec 30, 2016 at 7:42 AM
    dziner
    Jonathan
    I was pondering that. This is my truck as it sits this morning. It's at an angle.
    REDdawn6 likes this.
  17. Dec 30, 2016 at 9:02 AM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Have you considered doing the bilsteins set 1.75"? Could get away without doing the Upper A-arms and springs. Either way Yota Dan will take good care of you.
  18. Dec 30, 2016 at 9:05 AM
    dziner
    Jonathan
    I'm kinda pondering the Wheeler's 2" AAL instead of the Dakar leaf pack since I won't be lugging around 200lb of salt in the back all the time. And switching the front springs to OME 885.
  19. Dec 30, 2016 at 10:09 AM
    JWL
    JWL Well-Known Member
    Jeff
    Greenville, SC
    08 DCSB 4x4 TRDOR
    OME 885, Bilstein 5100, JBA UCAs, 2" Single AAL
    My single 1.5" AAL installation wasn't bad at all. 885s are a good choice and will get you 2.5" up front. I bet with the shell and other weight in the back you'll get that level look you are seeking. FWIW, I've had my wheeler's 1.5" AAL and 884s for about 7 months now and they haven't lost any height since I measured hub to fender 2 weeks after I installed.
  20. Dec 30, 2016 at 11:05 AM
    dziner
    Jonathan
    Can I possibly go with the instead of the Dakar leaf pack?
