Starting year long project!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Diablo929, Aug 23, 2018.
  1. Aug 24, 2018 at 10:09 PM
    Diablo929
    Diablo929 [OP] Well-Known Member
    2018 TRD SPORT
    So I guess my problem is that I want an all purpose vehicle to tackle those rocks and mud and sand and snow. Is that possible with a different suspension and armor. Or am I going to have to choose on what terrain I hurdle?
  2. Aug 25, 2018 at 5:47 AM
    Red Baron
    Red Baron Let's call it livabetes, no more die
    Aaron
    Lost on a roundabout
    07 Radiant Red DCSB
    Things with metal, dog hair, more metal and lights
    Na man that's easy as your rig can do all of those areas now with out after market parts. Tires will get you the height to clear obstacles and traction to go over them. The lift allows for more articulation of the direction and to fit bigger tires. Armor protects the trucks organs, gets you better approach angles, mounting points for even more recovery items and gives more courage to hit the harder stuff.
    I've wheeled in CO, AZ, UT, WY, NC in all seasons of the year all on the standard old man emu lift and I'm still using it 3 years later
  3. Sep 3, 2018 at 6:32 AM
    mattylmbr
    mattylmbr Well-Known Member
    2018 Tacoma TRD Sport
    How are you liking the Icon stage 2 lift? Any issues? And - did you do the any type of carrier bearing drop?
    Just bought the identical truck and you have the exact stance I want to go for.
    Thanks in advance for any feedback - and good luck with your project!
  4. Sep 3, 2018 at 6:41 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    Welcome to TW and enjoy your new truck!
  5. May 25, 2020 at 7:07 PM
    Diablo929
    2018 TRD SPORT
    Oh god this is so reminiscent of the project I’m still doing. Long story short a friend of mine discouraged me from doing this for whatever reason I listened even though my passion never left. Also, got engaged and had countless travels to other countries. However, here I am again the truck is getting now a Icon stage 8 and I am upgrading the tires to 285/70/R17 with that CMC . I’ll post upgraded pictures for you all. I’m again debating on the bumpers front and rear which I think will be next if not electrical. Victory 4X4 is definitely who I want to go through on the front and I’m loving the CBI Offroad High clearance for the rear. But I’m unsure if it’s better to order all Victory for possible discount. Any thoughts and sorry for the long time away?
  6. May 25, 2020 at 7:14 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Sounds like your first upgrade should be a locker (Probably both while you’re at it), since you don’t have one on the sport.
  7. May 25, 2020 at 7:25 PM
    Diablo929
    2018 TRD SPORT
    With the locker won’t I need the air compressor and won’t that need to run off the power supply that I’ll need to upgrade.... just asking ?
  8. May 25, 2020 at 7:34 PM
    mutely
    That depends. Air lockers are most common, but the air they need is minuscule. Even with bigger automotive air compressor there is absolutely no need for extra battery when using air compressor while the engine is running, or adding lights as stated earlier. If you are using more power than your alternator can supply, another battery really won’t help. Only need extra battery for camping, Ie running shit with engine off so you don’t drain your starter battery. or potentially using a winch at idle, since they are real power hogs but you only use them for short periods of time.
  9. May 25, 2020 at 7:39 PM
    Diablo929
    2018 TRD SPORT
    Would your recommend ARB front and rear and what about Nitro 4.88 ?
  10. May 25, 2020 at 8:06 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    What’s your budget? You’re way past $10k already.
  11. May 25, 2020 at 8:09 PM
    mutely
    ARB seems to be the choice for Tacoma. as for gears, I personally wouldn’t go up any tire size without gears on the Tacoma since it has no low end torque, but that’s probably more a personal thing with your driving habits as plenty do go up tire sizes and seem happy without gears.
  12. May 25, 2020 at 8:10 PM
    Diablo929
    2018 TRD SPORT
    Lol that must be a joke .... the labor alone has been enough . With the fuel beast rims that I customized and tires and now Icon stage 8 with the labor we are definitely past the 10k mark and I did an after market exhaust just for the sound
  13. May 25, 2020 at 8:11 PM
    Sharpish
    Brian
    Locking the front is not necessary unless you’re taking it to the extreme. If you get a lunchbox locker for the rear it’s automatic and doesn’t need air or electrical.
    If you’re sticking with 33” tires or smaller you don’t even need the regear although the extra torque is nice, but is it $3000 nice? Not in my opinion.
  14. May 25, 2020 at 8:26 PM
    Diablo929
    2018 TRD SPORT
    If you do change gears would it still be viable to utilize the shift sense pro?
  15. May 25, 2020 at 9:08 PM
    #35
    Sharpish
    Brian
    I think the SSP is obsolete since OVtune came out. SSP is spoofing the system and OVtune reprograms the system. I’m no expert but I would choose OVtune.
  16. May 25, 2020 at 10:04 PM
    #36
    Diablo929
    2018 TRD SPORT
    Kinda think I should do ARB , Air compression , Gears and then go armor and power afterward
  17. May 25, 2020 at 10:17 PM
    #37
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    Sounds like that money is burning a hole in your pocket.
    Subbed for pics.
  18. May 25, 2020 at 11:16 PM
    #38
    Diablo929
    2018 TRD SPORT
    Lol the icon stage 8 . The new tires . The spare tire and spare rim. Labor . About 8 grand so far . Let’s keep chugging along . Work on those 3 should be done June 11. I’ll update with photos once that work is done . Just trying to figure the next 10g to spend on
  19. May 26, 2020 at 7:40 AM
    #39
    Sharpish
    Brian
    OVtune and a Powertrax lunchbox locker as well as sliders and a high clearance rear bumper would result in a fun to drive, lightweight, nearly unstoppable machine off road that is reliable and still gets good gas mileage.
    That’s a good $4k to start. If you’re going to fully Armor the belly and get a front bumper and winch and upgrade to 35’s then you’re going down the rabbit hole of regearing.
  20. May 26, 2020 at 10:17 AM
    #40
    Diablo929
    2018 TRD SPORT
    Yeah eventually I am going to go full armor and front bumper as well so I’m thinking of regearing with a locker at the same time .... but after this suspension gotta save for a bit then next set of upgrades to make
