starting
Discussion in '1st Gen. Tacomas (1995-2004)' started by thunder walk, Mar 5, 2024.
  1. Mar 5, 2024 at 1:18 PM
    thunder walk
    thunder walk [OP] Member
    2000 taco
    I have been having trouble with it starting even though it cranks and it's not all the time. I can eventually get it to start if I just keep cranking on it.
    Most of the time it starts like a Toyota where you get in, turn the key and it starts without pumping the gas or anything.
    So many things.....camshaft position sensor, crankshaft position sensor or something else like ???
    When this happens there is no fault code.
    Does anyone have a direction for me?
  2. Mar 5, 2024 at 4:53 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Start with the easy stuff. Pull your spark plugs and see how they look. If you aren't sure what to look for, post up a pic and we'll help.
    How many miles on the plugs and plug wires? If you aren't sure, it's likely time to replace them.
  3. Mar 5, 2024 at 8:18 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Hot No Start describes your issue?
  4. Mar 6, 2024 at 5:06 PM
    thunder walk
    2000 taco
    Thanks for the response! The plugs have about 10k and still look almost new, the plug wires and coil packs are a little more than 30k. I have the 2.7l engine. What would be my next step?
