Starts and dies shortly after
Discussion in '1st Gen. Tacomas (1995-2004)' started by jayydddz, Nov 6, 2024.
  1. Nov 6, 2024 at 9:47 PM
    jayydddz
    jayydddz [OP] New Member
    1995 coma 2.7
    Aloha,
    I have a 95’ Tacoma with an 03’ motor 2.7 4x4. When I turn key, it starts and dies 5 seconds later. When I try to give it gas, it hesitates, sounds like when I press gas can’t hear my intake pulling air into engine. After a week of sitting my new battery is dead. Don’t know what it could be I’m thinking engine harness? Any input would helpful at this point
    things I’ve changed:
    -Fuel pump/filter/injectors
    -Spark plugs/coil packs
    -maf/crankshaft/camshaft/throttle position sensors
    -new throttle body
    -All new vacuum lines
    -idle air control valve/PCV
    -starter relay/open circuit relay
    -fuses (engine bay/interior)
    -3 different ECU
    -clutch
  2. Nov 7, 2024 at 6:53 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Codes?
    I had similar issue
    Replaced coolant temp sensor
    Replaced 7months B4
    The new CTS fixed the issue
  3. Nov 7, 2024 at 7:32 PM
    jayydddz
    1995 coma 2.7
    Not sure, the previous owner did the motor swap and converted the original 95’ harness to a 03’ harness & OBD port doesn’t work. Replaced coolant temp sensor on the back of the engine. Still same. Just about everything sensor wise under the hood was switched out.
  4. Nov 8, 2024 at 5:00 AM
    NC Gazzer
    NC Gazzer Well-Known Member
    Durham, NC
    1996 Tacoma 4wd 2.7 + 2023 TRD Sport
