Starts and immediately stalls but does not turn off
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Yampi2319, Dec 12, 2022.
  1. Dec 12, 2022 at 10:17 PM
    Yampi2319
    Yampi2319 [OP] Member
    Josh
    3016 toyota tacoma limited
    Stock
    Ok, so my 2019 tacoma on the first sart of the day when cold starts fine but it will immediately stall as if it wants to shut off but somehow manages to stay running then it wont do it again until it is sitting for hours off or the next day. We scanned for misfires and nothing came up, we checked battery, altenator, starter and anything that we think may cause this but everything comes out ok. Has anyone gone through this or know what ma be causing this?
  2. Dec 12, 2022 at 10:25 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    How old are the spark plugs?
    shakerhood likes this.
  3. Dec 12, 2022 at 10:34 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Had the fuel pump recall done?
  4. Dec 16, 2022 at 6:03 PM
    Yampi2319
    Josh
    Stock
    60k 2019 6 cil. Spark plugs are stock.
  5. Dec 16, 2022 at 6:03 PM
    Yampi2319
    Josh
    Stock
    No.
    shakerhood[QUOTED] likes this.
  6. Dec 16, 2022 at 6:12 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Once the engine starts, it runs fine otherwise?
  7. Dec 16, 2022 at 6:24 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I’m unfamiliar with the 3016 model year
    GL
  8. Dec 16, 2022 at 6:35 PM
    Yampi2319
    Josh
    Stock
    2019 model 60k miles. Yes once it starts and runs it will not stall or indicate misfires at all until it is cold again usually the next morning.
  9. Dec 16, 2022 at 7:16 PM
    Chuy
    Lakeside, CA
    Silver Taco
    Interesting, to me that kinda rules out a bad fuel pump. I would suspect a clogged fuel filter, but our trucks don't have a serviceable filter. You shouldn't have a dirty throttle plate or MAF sensor but you can check them to rule them out. You probably have a new air filter. A vacuum leak could also explain your symptom. Check around the brake booster and vacuum lines. Borrow a vacuum gauge if you can.
  10. Dec 16, 2022 at 7:21 PM
    Yampi2319
    Josh
    Stock
    Ill be checking MAF tomorrow just to rule out. Also for any leaks. Thanks for advice ill keep posted for updates. This is strange one. Weve checked almost everywhere, scanned, no chrck engine light, it runs fine afterwards no stalls or rough idling whatsoever. Its just at that first start. Thank alot
  11. Dec 16, 2022 at 7:23 PM
    RadoTaco
    RadoTaco Well-Known Member
    Justin
    18' Tacoma DCSB TRD OR White
    Following, my truck does this lately.
  12. Dec 16, 2022 at 7:25 PM
    Chuy
    Lakeside, CA
    Silver Taco
    If you have a rodent problem, check the air filter air duct for a rodent nest. The South Main Auto dude cleared a squirrel nest out of a Tacoma air duct. Truck also had some wiring damage.
  13. Dec 17, 2022 at 2:55 PM
    Yampi2319
    Josh
    Stock
    Checked MAF, vacuum leaks and everything pulled fine.
    We are really scarrching our heads here. Not to brag but the engine and maintenance on my truck is on point. Wirings and all. The onlye thing lsft to check would be fuel pump, filter and pressure if that makes sense?!?!? Not sure.
  14. Dec 17, 2022 at 3:07 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Bad fuel?
  15. Dec 17, 2022 at 3:13 PM
    shakerhood
    Southern Ohio
    You can put your VlN# Iin at Toyota to see if the Fuel Pump Recall applies to your truck.
