Starts then stalls
Discussion in '1st Gen. Tacomas (1995-2004)' started by Splitter, Oct 30, 2023.
  1. Oct 30, 2023 at 1:01 PM
    Splitter
    Splitter [OP] New Member
    04 tacoma sr5 trd 3.4L
    Hello,
    I recently purchased a tacoma sr5 tdr 3.4l. The thing ran great. Then I got it to the shop. Changed out the stock stereo and installed new speakers. Had some trouble getting it started. It would start and then stall in 3 seconds . Couldn't hear the fuel pump so i replaced it. Still same thing. So i went threw cleaned sll the grounds up. It finally fired up. Took it down the road and on way back it died and I was right back to square one. It threw codes for the cam and crank sensor. So I've replaced them along with the tps ,throttle body ,maf,ignitor, coil packs with plugs and wires. Still the same result. Truck fires up then dies . Is it a security issue? The ecm? This is killing me. I'm pretty good w a wrench I always can get things running . Any suggestions? Thanks
  2. Oct 30, 2023 at 4:28 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    If it happened right after the shop it could be a security issue. Do you have the security package? Personally I would've taken it back to that shop as soon as that happened.
  3. Oct 31, 2023 at 12:30 PM
    Glamisman
    Glamisman Well-Known Member
    Could be many things… my go to is the grounds on the intake manifold. D/S on the upper intake there are 6 or 8 brown wires crimped on ring terminals that ground the PCM and the sensors on the engine. The wires break internally so if you think it is OK because the insulation is good you could be wrong.
  4. Oct 31, 2023 at 1:33 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Having fired the Parts Canon the problem is now far worse then when you started .
    All the parts you removed were tested and were found to have failed?
    Now the truck still stalls but all the codes have been cleared and have not returned??
    Some place you have a poor connection broken wire or failed new part out of the box.
    One circuit at a time. Having the EWD for your truck will make this easier.
    Good Luck.
  5. Oct 31, 2023 at 2:22 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Really shot yourself in the foot with all that work. You had one problem, one way to wind it back, and now you are firmly in no mans land.
    ASSUMING all the new stuff you installed is good. What happens if you take out the new head unit? Your '04 may have had an RS3000 module from the factory- do you use that, or did you have an after market alarm system installed?
    Bivouac likes this.
  6. Nov 1, 2023 at 4:12 PM
    Potomus Pete
    Potomus Pete Love my little truck
    Hippy
    Sarasota Florida The Great Place To Live.
    1999 Prerunner single cab. With a BO7A rear end
    All kinds 3 inch body lift/2 1/2 suspension lift. 31/11 1/2/15 tires All work done by myself for years. The only work performed by mechanic was fuel pumps. I also have a 90 Mustang 350 hp and I can never understand how come my Tacoma gets more respect Just got a 99 Jeep TJ that I rebuilt, and painted in the garage
    Your situation stinks. Too bad.
