Startup Clatter
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TRDRed, Jan 9, 2023.
  1. Jan 9, 2023 at 9:07 PM
    TRDRed
    TRDRed [OP] Well-Known Member
    Pacific Northwest Playground
    2020 TRD OR DC SB OTT Tune
    Just bought a new to me 2020 TRD Off Road CC. Has about 42K on the clock. Joins our family that includes a Tundra and a RAV4. Lost count of how many Toyotas I’ve had but I haven’t run into this with any of them before. Did a search and found some mentions of the clatter at startup after sitting for a week or more, but then only for a second or two. Didn’t find anything that addresses it exactly.
    Starts up fine but when it’s cold there’s a distinct clatter on the passenger side of the engine. It lasts for about 10 or 15 seconds until the engine suddenly changes RPM, makes some kind of audible adjustment and then it goes away immediately and sounds and runs normally. But when if first starts up it sounds like it’s starved for oil and/or something like bad lifters or rockers. It’s pretty loud and again only on the passenger side. I'd expect a tiny bit before the oil gets circulated on a cold start, but this lasts longer than it should IMO, and odd that it's only on the passenger side.
    It happened at the dealership when I first looked at it, but it was cold and I chalked it up to sitting for a while. However it does it when I first start it up every morning.
    The wife's 2010 RAV4 V6 with 80K does not do this at all.
    Otherwise it runs great and I’m happy with it. But if this is a known issue I still have a few days to return it no questions asked ($250 return fee, but worth it if there's going to be an ongoing issue.
    I'll try to take a video and post a YT link tomorrow.
    Welcome the advice if the experts here.
    TIA!
  2. Jan 10, 2023 at 6:42 AM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    Injectors cleaning cycle. Normal.
  3. Jan 10, 2023 at 7:01 AM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    On start up ?
    Junkhead and TRDRed[OP] like this.
  4. Jan 10, 2023 at 7:01 AM
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    there is a noisy, mechanical (cam/roller) high pressure fuel pump on the passenger side. it radiates from its body and fuel rails, both of which have some minimal
    sound damping material. i'm not saying it is involved, but maybe and something to keep in mind.
    Edit: ...and welcome!
    related/funny: when i was having some warranty work done, i was given a loaner. It was not a tacoma but some sort of new toyota sedan. the guy handing me the keys told me it was running and I said "I know, i can hear it rattling". He tried real hard to conceal his laugher but could not. some things just make noise.
    TRDRed[OP] likes this.
  5. Jan 10, 2023 at 7:22 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    The cleaning cycle doesn't happen on cold start on
  6. Jan 10, 2023 at 7:44 AM
    23TacoSR
    23TacoSR Well-Known Member
    Bad VVT solenoid?
  7. Jan 10, 2023 at 8:00 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Possible...
    I'd borescope cylinders #5 and #6(pass. center & rear)
  8. Jan 10, 2023 at 8:01 AM
    fourfourone
    I Think we should hear the noise before we all jump on the speculation train.
  9. Jan 10, 2023 at 8:05 AM
    23TacoSR
    Naw, let's just start throwing parts at it :spending:
  10. Jan 10, 2023 at 8:12 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Timing chain tensioners are "controlled" by oil and sitting a while I recon the pressure could be bleeding off. The most I've let my truck sit was like 4 days, but it never has made that noise. Anti-drainback for the oil is built into the engine/oil filter housing (not sure which on this engine), so could possibly be an issue there.
    We did have a 2015 Camry with the 4 cylinder that did that clatter on every startup, but that was normal for those engines.
    Now we have a Subaru, and that thing makes all kinds of weird noises cold :laugh:
  11. Jan 10, 2023 at 9:23 AM
    erok81
    erok81 Well-Known Member
    Imposter
    Mine has had that noise since pretty much day one. Has 50k now and hasn’t changed volume levels.
    MountainManGuy, t2c and TRDRed[OP] like this.
  12. Jan 10, 2023 at 10:37 AM
    TRDRed
    Wow! You guys rock! Thanks so much for the terrific feedback and welcome, much appreciated. Here's a video I made this morning. Cold start after sitting for about 8 hours. The clatter isn't quite as loud on the video as it seems in person. This time it lasted a little longer than "normal". You can hear it stop at about the 25 second mark and then it sounds fine. I hope it's somewhat normal because I really like this truck but if it means repairs, downtime and all that goes with it, there are plenty more out there.
    Welcome any more thoughts and thanks again!
    Irons likes this.
  13. Jan 10, 2023 at 10:44 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    That's the injectors making that noise. Might be a cold start procedure, I've never payed attention to that before. Now I'm gonna have to go start mine... :laugh:
    EDIT: Started mine up and same noise and duration. Hadn't been run in 24 hours.
  14. Jan 10, 2023 at 10:48 AM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Mine sounds like that everyday (83k), the trick is to not open the hood. :)
  15. Jan 10, 2023 at 11:04 AM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    it has port and direct injection, depending on the load its under it will switch
  16. Jan 10, 2023 at 11:11 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Normal operation... carry on.
    That is the injector solenoids clicking. You will also heard them occasionally when you come to a stop in traffic. The sound will bounce off other vehicles at a light and be noticeable with the windows done. That is normal.
  17. Jan 10, 2023 at 11:14 AM
    TRDRed
    All good news. Phew!
    Welcome any other thoughts of course, but I will put the panic button away and enjoy my new ride if all are in agreement.
    Truly appreciate the awesome responses and help. :thumbsup:
  18. Jan 10, 2023 at 11:47 AM
    Mas Olas
    Woody
    So I was partially right?
    TRDRed[OP] and Speedfreak like this.
  19. Jan 10, 2023 at 12:39 PM
    Blak Shinobi
    taco
    n/a
    basically it can be louder in cleaning cycle , still a lil rowdy though
  20. Jan 10, 2023 at 12:55 PM
    Clearwater Bill
    Billy
    Largo Florida
    If it has rockers, return it. :D
