Startup problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Georgiatacoma18, Feb 3, 2016.
  1. Feb 3, 2016 at 10:30 AM
    Georgiatacoma18
    Georgiatacoma18 [OP] Well-Known Member
    Josh
    Cumming, Georgia
    2013 Black PreRunner
    265/65/17 michelin ltx ms2 tires
    I've got a 2013 prerunner and every once in awhile it has trouble starting up but eventually gets there. I know this is a problem in colder months but even recently it was 65°and this still happened. Do I need a new battery or what would there problem be?
  2. Feb 3, 2016 at 11:13 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Same thing happens to me. 2015 Tacoma. I'm not to worried and it doesn't seem to be a battery issue... I'd say 19/20 times it starts first try. 1/20 times it hesitates or takes two tries. Weird.
  3. Feb 3, 2016 at 11:32 AM
    PrisonerOfDoom
    PrisonerOfDoom Active Member
    Dustin
    Thornton, CO
    2015 Tacoma Sport
    Same here.
  4. Feb 3, 2016 at 12:14 PM
    2013Yoda
    2013Yoda Member
    Dan
    2013 Gray Tacoma Limited
    Rear View Mirror Raised, 4" Nerf Bars, LED Bed Lights, Swing Boxes, K&N Air Filter
    Same thing happens to me on my 2013 Limited. It's almost like it's missing or I don't hold the key long enough to start
  5. Feb 3, 2016 at 12:21 PM
    Nighthawk
    Nighthawk 'streme spoats
    Levi
    Casper Wyoming
    2008 Red TRD OR AC V6
    Bilstein 5100's w/ Eibach coil overs in front (set at 3" of lift). Front diff drop kit. Extended Bilstein 5100's in the rear. Deaver 2" AAL in rear w/ axle shims. 285 x 75 r 16 Goodyear Duratracks. Wheelers steelies type B, AFE cold air intake. Sway bar delete. All Pro Apex front bumper (rattle canned Rustoleum primer + flat black). Plasti-dipped emblems. Mud flaps removed.
    Mine does this too, maybe 1/40 starts. I believe its normal.
  6. Feb 3, 2016 at 4:37 PM
    Georgiatacoma18
    Josh
    Cumming, Georgia
    Not sure why that would be normal but okay... Just a little embarrassing when you go in to start a pretty new car and all you here is the starter screeching
  7. Feb 3, 2016 at 6:56 PM
    Albross66
    Albross66 Well-Known Member
    Alabama
    2007 DCSB PreRunner TRD Sport
    This happened on my 07 a few weeks ago. First time I've ever had a problem getting my Tacoma started. It took 4 or 5 tries before it cranked. Other than that one time mine always starts on the 1st or 2nd try.
  8. Feb 3, 2016 at 7:04 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    So, when this happens, you hear the starter spin up but the bendix doesn't engage the flywheel and it makes a higher pitched whine noise? The engine doesn't turn over at all?
