Static feedback when pressing gas
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jayandersen5, Oct 16, 2017.
  1. Oct 16, 2017 at 5:18 AM
    jayandersen5
    jayandersen5 [OP] Well-Known Member
    Jay
    South Carolina
    2017 TRD Pro
    OTT Tuned Yukon 5.29s 35x12.50r17 Yokohama MTs RRW RR7-H Wheels Dobinsons MRRs RRW hybrid front bumper ATH rear swing out high clearance bumper Alucab Explorer Canopy iKamper skycamp 2.0 Diode Dynamics SS3 (x4) and SSC2 SOS Sliders C4 full skids Smittybilt X20 Gen3 10k winch Prinsu Cabrack Expedition Essentials 3TPAM Caliraised 40" light bar ExtremeLED 30" light bar Total Chaos spindle/cam tab gussets and bed stiffeners Switch Pro SP9100 Power Tray
    Not sure if anyone else is having this problem but I will do my best to explain. Basically, whenever I hit the gas and the truck begins to move, there is a static feedback noise coming from the front passenger door/firewall area. At first I thought it was the passenger speaker but after having my fiancee drive it around so I could listen it seems that it could be coming from the firewall area under the glovebox.
    I have taken my truck to the dealership for this issue 3 times now but with no luck. One guy in the service dept even told me this is how all 2017 Tacoma's are built which I have a hard time believing considering my 2004 Explorer was great even after heavy stereo and lighting modifications.
    This has been an ongoing issue since the day I bought the truck. And recently, I installed the Morimoto HID Elite system and the Morimoto XB LED fog lights - and honestly I think the issue got slightly worse. Has anyone else experienced this issue on their 3rd gen tacoma?
  2. Oct 16, 2017 at 5:31 AM
    98tacoma27
    Ben
    Not Beech Creek
    That might be the high pressure fuel pump you are hearing.
    over60 likes this.
  3. Oct 16, 2017 at 9:44 AM
    tacomaalen
    tacomaalen Well-Known Member
    Alen
    2017 Toyota Tacoma
    I have the same problem, its only when I use the accelerator. i made sure because ill tap the accelerator gently and i can hear it come on immediately
  4. Oct 16, 2017 at 12:11 PM
    jayandersen5
    Jay
    South Carolina
    2017 TRD Pro
    Yes it is only when the accelerator is engaged when I hear the static feedback. Not sure how to fix this issue since the service department can't seem to figure it out. I'll look up the high pressure fuel pump to see if this could be the issue.
  5. Oct 18, 2017 at 1:01 PM
    jayandersen5
    Jay
    South Carolina
    2017 TRD Pro
    After doing some research on the high pressure fuel pump, I am still not sure if this is the issue. Based on what I've found, the engine would be making a squeaking or chirping sound if the fuel pump was bad and I am not hearing anything similar to that from the engine. The issue is only when the accelerator is engaged - there is a static feedback sound coming from the front passenger area and immediately turns off once you let off the gas. Part of me still thinks the static feedback is coming from the front passenger door speaker but I'm not 100% sure...what would cause this? Any advice is greatly appreciated!
    tacomaalen likes this.
  6. Nov 28, 2017 at 6:50 PM
    jayandersen5
    Jay
    South Carolina
    2017 TRD Pro
  7. Nov 29, 2017 at 5:27 AM
    Bubbafl
    Bubbafl Well-Known Member
    2017 tacoma trd sport 4x4 inferno
    I have it too, altho it comes and goes. My 2015 taco had it also.
  8. Nov 29, 2017 at 5:37 AM
    jayandersen5
    Jay
    South Carolina
    2017 TRD Pro
    I am taking my taco in for its 5000 mile service today and plan on mentioning it to the service department again.
  9. Nov 29, 2017 at 6:01 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    According to the service manual, the alternator is suspect if noise is present through the speakers while gas is depressed.
    For shits and grins; how's the negative battery terminal look? Clean and tight?
  10. Nov 29, 2017 at 6:43 AM
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    Mine does it too but I don't think it's static feedback. Mine is a very high frequency rattle coming from the passenger door speaker while accelerating. It does sound very much like static though.
    Mine usually stops after I've been driving for a while but not always. I just assume that something is loose and rattling in that general area. Unfortunately I can't push and pull on things while driving to isolate it and my wife is of no help since she's deaf. I've been meaning to take a buddy for a ride to help me isolate it but I never think about it unless I'm driving.
  11. Nov 30, 2017 at 3:54 PM
    jayandersen5
    Jay
    South Carolina
    2017 TRD Pro
    The negative battery terminal is perfectly clean - no problem there as the truck is only a few months old. Has been making this sound ever since I bought it and the dealership cant seem to figure it out.
  12. Nov 30, 2017 at 3:57 PM
    jayandersen5
    Jay
    South Carolina
    2017 TRD Pro
    I've had the truck looked at 3 times now at the dealership and they either 1) can't hear it or 2) don't know what it is or how to fix it. Mine makes that high frequency rattle/noise every time the accelerator is engaged. The service department has even tied all wires down with extra zip ties thinking it was something rattling but I still hear it everyday.
