Static in audio system
Discussion in 'Audio & Video' started by rkilgore76, Nov 8, 2017.
  1. Nov 8, 2017 at 5:40 PM
    rkilgore76
    rkilgore76 [OP] Well-Known Member
    Richard Kilgore
    beaufort,sc
    2011 toyota tacoma
    Focal 165a component,Focal 165 coax,Avic930bt,Fosgate amp 75x4.Box by Mr.Marv,10 inch Pioneer shallow mount,Rockford amp.
    Hello!Thank you for any help.My system has been playing great but for the last month i noticed static coming from the front speakers,Not both at once,It can be the left side one day and the right on another day,It's not constant but happens almost everyday that i listen to it.First i thought it was my Bluetooth,I turned the Bluetooth and wifi off from my phone and head unit and still heard static,I tried turning my phone and ipod off,That did not work,I tried a CD and at first all was well then it started with static again,Only the front speakers do this because they are amped and the back are running of the head unit.Now I'm thinking the RCA's?Or ground issue?I looked at the RCA'S and i did run them on the same side as power wire which was not smart of me but never picked up engine noise,I was thinking of removing the head unit and taking the ground out of the harness and grounding the radio to metal and moving the RCA'S to the other side of the truck.I'm just not sure after all this time,I would start getting static noise in the system.My head unit is the pioneer X5800BHS and the amps are JL,Speakers are Hertz Hi Energies,RCA'S I'm using are stinger 6000 series with NVX 4 Gauge Power and Ground.Thank you!
  2. Nov 28, 2017 at 8:02 PM
    rkilgore76
    Richard Kilgore
    beaufort,sc
    2011 toyota tacoma
    I tried new RCA cables on the other side of my truck,I checked amp ground,Its bolted down,I cut the ground out of the radio harness and grounded it separately .I was listening to a CD in the truck and waited on the static noise,I turned the radio off and unplugged the RCA's from the amp and turned the radio back to CD and still heard it.I even turned my dash camera off to see if there was any interference..lol It seems like it mostly comes from the left side front more than both front speakers lately,Does not happen all the time but it starts about 5 or 10min min into the music list...This problem happens on all sources...Could it be the pioneer outputs for the amp going bad or be defective?
  3. Nov 29, 2017 at 4:56 AM
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    Maybe. Sounds like it could be the amp too. Keep working to isolate the problem. You can just use something like a phone for amp inputs (just make sure you go into airplane mode first). Maybe that will let you listen long enough to pin down the culprit.
  4. Nov 29, 2017 at 9:46 AM
    rkilgore76
    Richard Kilgore
    beaufort,sc
    2011 toyota tacoma
    Thank you!Im going to try that today...If I unplugged the amp and still heard the static it still could be the amp?
  5. Nov 29, 2017 at 4:44 PM
    rob feature
    rob feature Tacos!
    Colorado
    With no input and you're still getting the noise, seeing how it's the last thing in the signal chain, I'd be looking pretty hard at the amp. Which JL amp? Do you note any level changes when this happens? Anything else accompany the noise?
    Err, wait, what do you mean you unplugged the amp? You mean cut the power to it or just the inputs?
  6. Nov 29, 2017 at 6:16 PM
    rkilgore76
    Richard Kilgore
    beaufort,sc
    2011 toyota tacoma
    No just unplugged the rca's from the amp....Yes!I do notice something!It seems like before it happens it gets a little louder in audio before it happens....It plays normal lets say at volume 20 then i can hear a slight difference in volume before it happens.The amp is a 400/4 jl audio.
  7. Nov 29, 2017 at 6:24 PM
    rob feature
    rob feature Tacos!
    Colorado
    So an XD 400/4? RD? JX? Just trying to get an idea of age.
    rkilgore76[OP] likes this.
  8. Nov 29, 2017 at 6:26 PM
    rkilgore76
    Richard Kilgore
    beaufort,sc
    2011 toyota tacoma
    Sorry! It's a JX
  9. Nov 29, 2017 at 6:35 PM
    rob feature
    rob feature Tacos!
    Colorado
    I dunno man. If all your connections are in order & your voltage is good, might be time to toss in the backup. Amps are just there to do one thing - amplify. If it's making noises on its own, especially new stuff, it probably needs some parts.
  10. Nov 29, 2017 at 6:38 PM
    rkilgore76
    Richard Kilgore
    beaufort,sc
    2011 toyota tacoma
    Im going outside to try my phone now...Ill check voltage too...If it is the amp,Im not sure if i want another one of them..lol
  11. Nov 29, 2017 at 6:41 PM
    rob feature
    rob feature Tacos!
    Colorado
    If you haven't checked all your power, speaker & ground connections, that can maybe do this. Bad grounds can do all sorts of weird stuff.
  12. Nov 29, 2017 at 7:12 PM
    rkilgore76
    Richard Kilgore
    beaufort,sc
    2011 toyota tacoma
    Ok i went out and unplugged the rca's from the amp and plugged in my phone to the rca's and played some music on Amazon,After 4 songs i heard the static coming back on the left side again,I made sure i had wifi and bluetooth turned off.
  13. Nov 30, 2017 at 11:07 AM
    jv_74
    jv_74 Well-Known Member
    Jesse
    Filthadelphia
    2015 DCSB Silver Sky Metallic
    I spent DAYS chasing a static noise when I did my install. Installed a new amp and it was gone. Nothing can fix a crappy amp.
  14. Nov 30, 2017 at 3:21 PM
    rkilgore76
    Richard Kilgore
    beaufort,sc
    2011 toyota tacoma
    Was it doing the same thing as im going through now??
  15. Dec 1, 2017 at 6:31 AM
    jv_74
    Jesse
    Filthadelphia
    Roughly. I was just getting static noise throughout. I spent days swapping out RCAs, playing with the positioning of where I ran my wires, messing with grounds, etc. Nothing helped until I got rid of the cheap shitty Dual amp. Hooked up a kicker and problem was immediately gone. I even had the RCA's running next to the power wire and didn't get any feedback at all.
  16. Dec 3, 2017 at 7:11 PM
    rkilgore76
    Richard Kilgore
    beaufort,sc
    2011 toyota tacoma
    Got my amp from sonic electronix,Calling them monday to see if i can get a new one.
  17. Dec 12, 2017 at 5:44 PM
    rkilgore76
    Richard Kilgore
    beaufort,sc
    2011 toyota tacoma
    Sonic is sending me a new amp under warranty..I'm glad of that..lol,I was looking into adding a passive radiator sub with my jl 10 slim,Will that give more bass?Never tried one was not sure if it was worth it.
  18. Apr 28, 2019 at 8:00 AM
    BlackSabbathTacoma
    BlackSabbathTacoma Well-Known Member
    2016 TRD OFF ROAD - BLACK
    I know this is an old post but I had the same issue twice with the same model amp. It’s moisture getting into the amp. Doesn’t take much. Just for future reference...
  19. Apr 28, 2019 at 7:25 PM
    rkilgore76
    Richard Kilgore
    beaufort,sc
    2011 toyota tacoma
    Thank you for answering!!
