Statistics of front timing cover leak?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gfenza89, Jun 13, 2023.
  1. Jun 13, 2023 at 12:45 PM
    Gfenza89
    Gfenza89 [OP] Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Anyone know the statistics of the front timing cover leak? The chances of it actually happening? I have a 2023 sr5 v6. Hoping mine doesn’t ever leak there. When I bought the truck I sprayed a liquid gasket maker all down the right side of the timing cover up and behind the power steering pump. Hoping this works in preventing it ever from leaking there.
  2. Jun 13, 2023 at 12:48 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I’d think any statistics here would be made up booshit, except for the few dealer techs, they could probably give you a fairly decent estimate of what they see. I would consider model years in those results though.
    I wouldn’t stress on the what if? here, and go enjoy life.
    Junkhead, Jeffch, plurpimpin and 3 others like this.
  3. Jun 13, 2023 at 12:55 PM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    No one knows expect for Toyota.
    Applying gasket maker over the timing cover wasn't the best idea. Sounds like a perfect way for Toyota to deny a warranty claim if you do end up with a timing cover leak.
    Also gasket maker typically only works when trying to seal two mating surfaces together. Just applying it to a bare metal surface doesn't really do anything.
  4. Jun 13, 2023 at 12:58 PM
    Gfenza89
    This product is designed to go on the outside to seal oil leaks. I don’t think it would void warranty it doesn’t do anything beside dry clear and create a gasket,
  5. Jun 13, 2023 at 1:00 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Do the math!!!!
    X divided by Y x 100 = % timing covers failures
    X = number of timing covers replaced
    Y = total number of 3rd Gen Tacos produced
    Junkhead, Chew and Gfenza89[OP] like this.
  6. Jun 13, 2023 at 1:01 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Yes, just enjoy your truck. Luck of the draw on the timing cover leak. I think there are over 1.5 million of these 3rd gen's on the road. Hasn't' been a big issue AFAIK. Being informed is great but spending too much time agonizing on some of these issues here it's not healthy.
  7. Jun 13, 2023 at 1:01 PM
    fourfourone
    What product did you use?
    Toyota looks for reasons to deny a warranty claim. If I was the dealer and saw some sort of sealant around the timing cover, I would automatically assume someone was in their trying to create a cheap fix.
    I would scrape it all off and enjoy the truck.
    ToyoTaco25 likes this.
  8. Jun 13, 2023 at 1:03 PM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    What are you going to do with this statistic anyways?
    Junkhead and Chew like this.
  9. Jun 13, 2023 at 1:03 PM
    Gfenza89
    Made by permetex. I just figured it was a good idea to apply it in hopes of saving myself hassle with having my engine removed and dealing with dealerships and possible sloppy work
  10. Jun 13, 2023 at 1:05 PM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    A sealant works on the mating surface, not plastered over the seam.
    BJK1280, ToyoTaco25 and fourfourone like this.
  11. Jun 13, 2023 at 1:06 PM
    fourfourone
    What you "sprayed" won't help if it's going to leak.
    Canadian Caber and ToyoTaco25 like this.
  12. Jun 13, 2023 at 1:07 PM
    ToyoTaco25
    North Carolina
    Also qualifies as "sloppy work" in my book lol.
    fourfourone[QUOTED] likes this.
  13. Jun 13, 2023 at 1:10 PM
    fourfourone
    OP is worried about his timing cover leak but just voided his warranty on it.
    I would remove the stuff (if possible) asap and just drive the truck.
  14. Jun 13, 2023 at 1:15 PM
    Gfenza89
    How do you know it would void the warranty?
  15. Jun 13, 2023 at 1:17 PM
    ToyoTaco25
    North Carolina
    True that. OP said "I just figured it was a good idea to apply it in hopes of saving myself hassle with having my engine removed and dealing with dealerships and possible sloppy work"
    That's why I commented that spraying the stuff on there was "sloppy work" in my book lol.
  16. Jun 13, 2023 at 1:21 PM
    fourfourone
    I'm not saying it 100% will, but if you ever have an oil leak and the tech sees gasket maker all over the outside of the timing cover, they will automatically think someone already attempted a crappy repair. Thus denying the claim. Toyota 1000% will deny a claim if they think someone else has attempted a repair on said issue already.
    Sometimes Toyota will even require pictures before they approve high dollar warranty work (like a timing cover reseal).
    Toyota doesn't like to approve expensive warranty work and they look for every way to deny. All auto manufacturers do this.
    Gfenza89[QUOTED][OP] likes this.
  17. Jun 13, 2023 at 1:27 PM
    Gfenza89
    Well if it ever starts leaking I’ll just clean it all off then.
  18. Jun 13, 2023 at 1:28 PM
    Gfenza89
    The product has a 5 star review
  19. Jun 13, 2023 at 1:28 PM
    fourfourone
    Yea for the correct application... What Permatex product did you use?
  20. Jun 13, 2023 at 1:29 PM
    Gfenza89
    It’s made to be sprayed on the outside of leaking low pressure joints. Such as timing covers, oil pans etc.
