Stealership charged $1K for 150,000 mile service -- ripoff?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kONArIPPER, Apr 21, 2014.
  1. Apr 21, 2014 at 10:00 AM
    kONArIPPER
    kONArIPPER [OP] Active Member
    HI
    06 TRD OR DCSB
    5100's, 285 Duratracs, Spidertrax
    I brought my '06 DCSB TRB OR in for it's 150,000 service. The bill came to $1100. Basically they did all the same shit they do during any other multiple of 30,000 mile interval. Oil, filters, plugs, rotated tires, lubed U joints, flushed tranny and diff fluids, inspected a bunch of crap, etc, etc. How badly did I get bent over and given the shaft? I bought the truck used 40,000 miles ago, and this is the first time I've had it serviced since I bought it so I justified that I would put the money into the maint just to rest assured that it's all peachy.
    For those of you who aren't grease monkeys, how do you get your trucks serviced in a way that's cheaper than the stealership? I don't have a reputable small mechanic shop in my area.
  2. Apr 21, 2014 at 10:02 AM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    i don’t about where your are but around here they charge like $600. so yeah you got ripped of pretty bad. could also do it your self for close to 200 maybe 300 at the most if you already have the tools.
  3. Apr 21, 2014 at 10:03 AM
    nextfriday
    nextfriday Well-Known Member
    Indianapolis, IN
    13 SR5 Double Cab
    5100s@2.5", 2" aal Leer 100 XR w/ Yakima rails and towers 18x9 Pro Comp Rockwells Cooper Discoverer AT3 275 65 18
    Are you mechanically inclined and have tools? There are Do it yourself threads all over this forum. These are not difficult tasks.
  4. Apr 21, 2014 at 10:04 AM
    SoutheastTaco
    SoutheastTaco Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
    I would have not flushed the tranny..
  5. Apr 21, 2014 at 10:06 AM
    kONArIPPER
    HI
    06 TRD OR DCSB
    I'm tech savvy with bikes but that's about where it ends. I've never really gotten under the hood of a vehicle. Even if I had all the tools, I could see all this kind of stuff taking an entire weekend, which I don't have many of to spare.
  6. Apr 21, 2014 at 10:06 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    ouch
    out of all that the hardest thing to do is the plugs, which really isnt all that hard.
  7. Apr 21, 2014 at 10:07 AM
    kONArIPPER
    HI
    06 TRD OR DCSB
    ANy particular reason other than it not being necessary? Is it harmful to the tranny?
  8. Apr 21, 2014 at 10:07 AM
    rme
    rme Well-Known Member
    Savannah
    Green TACOMA
    XM, Panasonic Stereo, Headlights,Electric Ant,Toyota Deluxe Wheels, Rhino Lining, Cargo Rails
    Are you sure they didn't change out the timing belt? It looks that way from the price.
  9. Apr 21, 2014 at 10:08 AM
    jeremy_283
    jeremy_283 Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    I would have... my transmission got flushed at around 80k and probably will again around 160k.
    Transmission flush is the only service I don't do myself due to some of the equipment that should be used.
  10. Apr 21, 2014 at 10:08 AM
    TacoCat
    Johnny-5
    Chantilly, VA
    2nd gen has a chain.
  11. Apr 21, 2014 at 10:09 AM
    nomad_archer
    nomad_archer Well-Known Member
    Trevor
    Brickerville (Lititz), PA
    08 DC Tacoma V6 SR5
    I didnt see a tranny flush in the service manual for my '08. I hardly ever tow and don't have a LSD so the diff drain and flush really isn't on my radar and not required service.
    The rest of the things you had them done you could have done for much less if you have the tools.
  12. Apr 21, 2014 at 10:09 AM
    samiam
    samiam Always here, never there
    Sam
    Stinky Vegas
    2008 TRD OR DCSB 4.0 6MT 1E7 Alu Cab
    Workin' on Workin' on it
    Did they itemize your bill?
  13. Apr 21, 2014 at 10:16 AM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    ^This, List out the details from itemized
  14. Apr 21, 2014 at 10:19 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Trannys should be flushed regularly. I will never go more than 60k on mine.
    Rear diff drain/fill takes all of 5 minutes. Not doing it because you "think" it's ok is not good. It really takes 5 minutes. Anyone not keeping up on their rear is asking for trouble. I do mine every 15k.
  15. Apr 21, 2014 at 10:20 AM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    WOW......sounds quite steep. I'd like to see the itemized service write up.
  16. Apr 21, 2014 at 10:21 AM
    jeremy_283
    At around 90k I just recently:
    Replaced spark plugs
    Two valve cover gaskets
    Front Differential Fluid
    Transfer Case Fluid
    Rear Differential Fluid
    Spark Plugs
    Air Filter
    Cabin Air Filter
    Antifreeze Change
    Oil & Oil Filter Change
    I estimate it cost me about $275 and it took me two days to complete. I used a torque wrench on EVERY fastener which may be why it takes me a little longer.
  17. Apr 21, 2014 at 10:21 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Without knowing exactly what they did it is very difficult to determine if you got screwed. Needless to say shop labor is at least $100/hr at a dealership plus the fact you bought it used and didn't know the service history I would say $1,100 is a fair price.
  18. Apr 21, 2014 at 10:24 AM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    You paid alot in labor. Dealership will ALWAYS be high on labor cost. Parts are marked up at those prices probably 100%.
  19. Apr 21, 2014 at 10:43 AM
    kONArIPPER
    HI
    06 TRD OR DCSB
    Yeah, I was thinking I'll post up the itemized bill. I don't have it handy but will post it up this afternoon. I hate getting screwed by stealerships. Time to learn to turn wrenches myself.
  20. Apr 21, 2014 at 10:51 AM
    jeremy_283
    I personally also have the additional satisfaction knowing everything was torqued to spec :p and I also know the individual responsible for the work had a great attention to detail and took care in worked performed (me :D)
    Oh, and money saved. That's a good one too.
