Stealership Oil Change...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bmw2Taco, Mar 25, 2024.
  1. Mar 26, 2024 at 5:55 AM
    #81
    RetGoalie
    RetGoalie Well-Known Member
    Tom
    2023 DCSB Sport
    I actually remove the access plate myself before I drop off for oil change and I tell the service person please do not remove the skid plate. Way too many stories of over torqued bolts and stripped screws. I can tell it’s done as I see some oil spillage on the plate which is fine with me. I respect all the do it yourself guys but I’m 61 and just don’t want to get on my back and do it anymore myself
    abou824 likes this.
  2. Mar 26, 2024 at 7:22 AM
    #82
    chasecmc
    chasecmc Well-Known Member
    Chase
    2017 DCSB TRD OR
    GFC
    I use a torque wrench for plenty of things, but not for an oil change. Still a good thing to have on hand for most jobs.
  3. Mar 26, 2024 at 7:25 AM
    #83
    myn75
    myn75 Well-Known Member
    Nor Cal
    2021 TRD Off-Road 4x4 DCSB, 1996 4runner SR5 V6 4x4 auto
    ARB OME BP-51 2”, TJM sliders, AT3Ws, Diode Dynamics SS42"
    Yup terrible service. Only used that useless toyotacare for one service interval and that was the 10k they left the damn oil cap off and I didn’t notice until 2 months after since i dont drive the truck often
  4. Mar 26, 2024 at 7:33 AM
    #84
    Bmw2Taco
    Bmw2Taco [OP] Well-Known Member
    2018 Blue 4x4 TRD Sport Premium
    Last night I bought a Fumoto valve and filter removal tool. DiY from here on out. Today I plan on picking up an OEM filter from a local dealership. I'll be sure to post pictures of my currently installed filter once I pull it out.
    abou824 likes this.
  5. Mar 26, 2024 at 7:38 AM
    #85
    MK212MX
    MK212MX Well-Known Member
    2022 Tacoma TRD Sport
    I have my 20K last free oil change next week and plan on doing it myself after this. Where did you get the tool?
  6. Mar 26, 2024 at 7:41 AM
    #86
    Bmw2Taco
  7. Mar 26, 2024 at 7:41 AM
    #87
    abou824
    abou824 Well-Known Member
    Aidan
    Central PA
    '21 TRDOR Army Green 6MT, '13 Lexus RX350
    TRD Lift (Toyota 5100's) LT265/75 AT4W Method MR305 16x8 Bronze ARB Diff Breather Subaru Tweeters Garmin Dash Cam Clutch accumulator delete plate Vibration dampers on MT driveshaft shield
    Do you have enough clearance with the TRD skidplate drain plug hole to use the valve? Have a fumoto on my Mazda weekend car and love it, would be great to make oil changes on my taco even easier.
  8. Mar 26, 2024 at 7:48 AM
    #88
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
  9. Mar 26, 2024 at 7:49 AM
    #89
    Bmw2Taco
    abou824[QUOTED] likes this.
  10. Mar 26, 2024 at 7:50 AM
    #90
    abou824
    Aidan
    Central PA
  11. Mar 26, 2024 at 7:51 AM
    #91
    Bmw2Taco
    FML...I actually have the metal filter cap in my Amazon cart as a future "upgrade". The torque spec is 18 ft lbs so unless it was really over tightened by the dealership I shouldn't have an issue.
  12. Mar 26, 2024 at 8:06 AM
    #92
    bfonic
    bfonic Well-Known Member
    2023tacoma
    I'm due for my first "free" service in june. I changed the oil at 1k mi already because I figure they won't and I'll just take it in when they let me know about the axle bolt check. : )
    Jakerou and faawrenchbndr like this.
  13. Mar 26, 2024 at 8:07 AM
    #93
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Be sure you get the Toyota part and not Dorman or another knockoff
    The MotivX tool is MUCH better than the one you had linked. I had one of those in the beginning, I threw it in the trash after two uses
    CrazyCrewChief likes this.
  14. Mar 26, 2024 at 8:10 AM
    #94
    Bmw2Taco
    https://www.amazon.com/dp/B008BHP68A
    Here is the MotivX tool if anyone is interested.
    https://www.amazon.com/dp/B00XTAGHU0
    faawrenchbndr[QUOTED] likes this.
  15. Mar 26, 2024 at 8:22 AM
    #95
    chasecmc
    Chase
    2017 DCSB TRD OR
    GFC
    Another recommendation for the motivx tool
    also, a heads up for anyone doing their first oil change on this truck. When you pull the drain plug the oil comes out with extreme force. Maybe it’s that the truck is higher, I don’t know. But let’s just say I had issues I did not have on other oil changes in the sense of the pan not being able to contain it.
    have a deep large oil pan or something to absorb so it doesn’t splatter.
    Now I have the Fumotovalve so controlling the flow is much easier
  16. Mar 26, 2024 at 8:24 AM
    #96
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    faawrenchbndr and CrazyCrewChief like this.
  17. Mar 26, 2024 at 8:24 AM
    #97
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    a torque wrench was mentioned several times but if you are an experienced tugger you really don't need it.
    having said that, about 10 years ago i needed one to install some head bolts on and engine i was working on so i checked out harbor freight click type Pittsburg brand.
    they have 3 sizes, all costing about $8 or $9 on sale at that time. a quick look and they are about double that now but not on sale. i don't know if they run those sales anymore.
    when i got it home i checked its accuracy VERY carefully with known weights and angles etc. i was surprised it was very accurate for the price. if it had been off i simply would have returned it but i was able to get the job done without spending hundreds of dollars for a pro wrench. i liked it so much i bought its little sister so i now have two of these things for relatively little money and i know they are accurate since i checked them.
    just fyi in case anyone thinking about getting a torque wrench. it is a good thing to have around but not really necessary for the thread's purpose. i use it though, since i have it.
    killthehippies likes this.
  18. Mar 26, 2024 at 8:38 AM
    #98
    jmneill
    SE
    ^ I have not experienced that one. :rofl:
    A pro tip, however.
    If equipped, make sure the air bleeder is open on the oil drain pan before pulling the drain plug on the truck, or the pan won't be able to consume the oil quickly enough do to the back pressure.
    chasecmc[QUOTED] likes this.
  19. Mar 26, 2024 at 9:00 AM
    #99
    onemorecast
    onemorecast Member
    When it comes to these dealership oil changers, it is not a training problem as some have suggested. These guys know to change the filter, they know to tighten the drain plug, they know to rotate the tires, but choose not to. The problem is the job does not pay enough to get an adult to do the job. Young men and women remain children on into their 30's these days, and that is about all you can get to work for less than $20.00 per hour. Most of them are only working because their parents force them to. The fast lube places are no different. No one really want to pay what it takes to get a real Technician to change your oil. All mechanics have to start somewhere, but most of your oil changers have very little interest in become a real technician.
    bgavin, CrazyCrewChief and 69 Jim like this.
  20. Mar 26, 2024 at 9:17 AM
    #100
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    I disagree. Cross threaded bolts and over torquing with air tools is a training and supervision issue in my opinion. Also allowing anyone to remain "children on into there (their?) 30's" is just enabling and pampering.
    petethemeat and Kodiak420 like this.
