Stealership Oil Change...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bmw2Taco, Mar 25, 2024.
  1. Apr 9, 2024 at 4:13 AM
    #141
    Bmw2Taco
    Bmw2Taco [OP] Well-Known Member
    2018 Blue 4x4 TRD Sport Premium
    You called it!
  2. Apr 9, 2024 at 4:16 AM
    #142
    Bmw2Taco
    The engine was warm when I worked on it yesterday. Sat for 20 minutes after driving. Didn't help. I have everything in route to get this thing off later this week. Wish me luck. A bit ridiculous...
  3. Apr 9, 2024 at 4:22 AM
    #143
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    It will come off easier when engine is COLD
    The poly/plastic filter canister expands at a faster rate than the aluminum boss casting
    Barsoom likes this.
  4. Apr 9, 2024 at 5:13 AM
    #144
    Bmw2Taco
    That makes sense. Shrinkage...lol. A lot of contradictory advice on this thread. Thank you.
  5. Apr 9, 2024 at 6:35 AM
    #145
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Shrinkage……:rofl:
    I switched to the alloy Toyota canister. It installs and removes MUCH easier.
    Toyota Oil Filter Cap - 15620-31060
    bgavin and Barsoom like this.
  6. Apr 9, 2024 at 7:05 AM
    #146
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    O-ring does the sealing on this filters, extra torque is not needed. Not looking to doing oil change on my Taco, after the last oil change by the dealer. But they all over do.
  7. Apr 9, 2024 at 7:07 AM
    #147
    Barsoom
    NW GA OTP
    I switched wife's RAV to Toyota's OEM aluminum canister, and will change Taco's canister at the next oil change. Helps that both cars use the same filter element, and I buy filters in cases of 10 from the dealer. Comes out to $4-ish a filter.
    petethemeat and bgavin like this.
  8. Apr 9, 2024 at 7:15 AM
    #148
    bgavin
    bgavin Well-Known Member
    Orangevale, CA
    2023 Tacoma Access Cab, V6, 4WD, A/T, OTT Medium/Spicy
    CURT Mfg front receiver, anti-theft cages around cats
    Please post the part number for the alloy version made by Toyota.
    Not interested in the aftermarket types.
  9. Apr 9, 2024 at 7:19 AM
    #149
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    If you can F-up a plastic filter housing, you can really F-up a metal one.
    Equipment solutions to operator problems are nearly always going to be suboptimal.
    JmsWms, Vlady, AZ Pete and 1 other person like this.
  10. Apr 9, 2024 at 7:25 AM
    #150
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
  11. Apr 9, 2024 at 7:30 AM
    #151
    bgavin
    Orangevale, CA
    Thanks.
    Appreciate that.
  12. Apr 9, 2024 at 9:41 AM
    #152
    Barsoom
    NW GA OTP
    15620-31060
    https://www.amazon.com/gp/product/B008BHP68A
    or
    https://www.*****************.com/oem-parts/toyota-engine-oil-filter-housing-1562031060
    Need to reuse the metal filter drain plug from the plastic housing in either case.
    Edit, do not know why BAM wholesale was replaced with ****** in the second link.
  13. Apr 9, 2024 at 10:00 AM
    #153
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    You’re quite welcome, kind Sir
  14. Apr 9, 2024 at 5:19 PM
    #154
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    When it's that far off being properly tightened, I honestly don't think cold or warm will matter much based on others on this forum who went through a similar thing. Either way, good thing you have a replacement on the way. Plastic will be toast after you get through with it. Good luck man. This is definitely a 2-3 beer job.
    Barsoom likes this.
  15. Apr 9, 2024 at 5:59 PM
    #155
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    Motiv socket for oil filter
    24 mm 1/2 drive socket deep
    1/2 inch breaker bar
    Steady even pressure and make sure your in a good leverage spot .
    It will come off
    The plastic housing is fine if tightened correctly
  16. Apr 9, 2024 at 6:15 PM
    #156
    bgavin
    Orangevale, CA
    We also have a 2016 RAV4.
    Q: is the part number the same for both of yours?
  17. Apr 9, 2024 at 6:28 PM
    #157
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    The first page of any thread sheds light on any topic…this one being near/dear to my heart because I’ve done the oil change myself and see no difficulty in completing this task.
  18. Apr 9, 2024 at 7:51 PM
    #158
    Barsoom
    NW GA OTP
    Yes, same. Ours is a 2014 RAV4. Toyota uses the same housing even for taller filters, just changes the center tube to the taller one. In our case it was a direct fit, since both Taco and Rav use the same smaller filter.
    bgavin[QUOTED] likes this.
  19. Apr 10, 2024 at 8:14 AM
    #159
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    Did my first OC - with the old fashioned oil filter wrench with no problems but I did notice it didn't fit exactly correctly and seemed stuck although I could wiggle it a bit to get it off. The Motivx wrench looks like a better tool so I think I will get one. But my question is about the filter drain on the bottom of the oil filter housing. That is a first for me - what is it's purpose ? And can I just remove the filter housing and empty it and replace the filter without taking that little plug on the bottom off before taking the housing off to replace the filter - it's a PITA since I have a skid plate with an access put it is not all that big.
  20. Apr 10, 2024 at 8:18 AM
    #160
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Reduce spillage and create positive memories of routine oil change..
    Barsoom likes this.
