Stealth Custom Series F5 * Photo thread *
Discussion in 'Wheels & Tires' started by ChadsPride, Jul 25, 2017.
  1. Dec 9, 2020 at 5:28 AM
    #2841
    Anthony 82
    Anthony 82 Active Member
    2015 grey tacoma
    I have my F5 on the way! After a bit of looking the 6 bolt selection with 4.5" backspace is going to be as close as close to stock in this rim.
    I believe the stock backspace is 4.9" so not much difference there. I have 265 70 16" on my 2015 SR5 4X4 and only noticed a bit of rubbing on the front mud flaps after installing some 1" wheel spacers.
    I believe my 16" stock rims have a slight + offset.
    If you aren't putting on wheel spacers (to give the truck a wider stance appearance) and stick with the above tire size you should be okay in terms of rubbing.
    Hope that helps?
  2. Dec 9, 2020 at 9:30 AM
    #2842
    TheeNorthStar
    TheeNorthStar ok, dis taco
    2021 TRD OFF ROAD MGM DBL CAB AT 4WD
    For sure, Thank you!
  3. Dec 11, 2020 at 11:55 AM
    #2843
    09TRDSport4x4
    09TRDSport4x4 OCD Approved!
    Nick
    Southwest Ohio
    Finally got them mounted!
    Before and After (ignore the wood ramps):
  4. Dec 12, 2020 at 9:07 AM
    #2844
    Hockeyjay09
    Hockeyjay09 New Member
    2002 trd tacoma
    300,000+ Miles
    Looking to get some F5’s just not sure about the sizing/BS was thinking about 17” 8.5 but see a lot of folks running 16” in various BS options just wanting to know why you would choose a 16” over 17” and Vice verse. My tacoma is a 2018 off-road I am going to be installing a toytech boss 2.5 plus OME add a leaf with SPC upper control arms. I fully plan on doing some chopping to avoid rub not sure about CMC or relocate will cross that bridge when I get there if needed. Also planning on 285/75/17 tires or equal in a 16”. Any advice would be appreciated also a side view picture of a cement tacoma with black F5’s 17” 8.5
    ChadsPride[OP] likes this.
  5. Dec 12, 2020 at 10:46 AM
    #2845
    Anthony 82
    2015 grey tacoma
    Got my wheels! I went 16" because I like the look of more rubber without having to CMC as I'm going with a 265 75 16 (only one size up) but I went -25 offset so we will see. What I have to do. Install on Tuesday!!
  6. Dec 12, 2020 at 12:39 PM
    #2846
    ChadsPride
    ChadsPride [OP] Tacoma Owner & Enthusiast
    Sponsored by TacomaWorld.com
    :drool: :militarypress:
    :headbang::headbang:
    Heck yes :woot:
  7. Dec 15, 2020 at 11:56 PM
    #2847
    Jukeboxx13
    Jukeboxx13 Well-Known Member
    California
    2017 TRD OR DCSB 4x4
    I love these wheels
  8. Dec 17, 2020 at 7:50 AM
    #2848
    Midship909
    Midship909 Well-Known Member
    SocaL
    13 MGM 4x4 OR 6speed
    waiting on that restock for 16x8 -25!!!
  9. Dec 17, 2020 at 9:06 AM
    #2849
    black_cukui
    black_cukui Well-Known Member
    Patrick
    Riverside, ca
    2010 T4R SR5
    waiting on 17X9's myself..... :spending:
  10. Dec 18, 2020 at 6:14 AM
    #2850
    6xchamps
    6xchamps Well-Known Member
    Fuquay Varina NC
    2015 AC
    I have only slightly modified my vehicle height. Just went with a set of 5100's to level the truck out. I would like to get a set of 16" bronze f5s, but I see that they are sold out. I am a bit concerned about the tires rubbing. I like the Stealth6 too. 16x8 -25mm 6x139.7. Would that work with a set of 245/75/16s without needing to cut/have any adapters?
    Thanks
  11. Dec 18, 2020 at 4:24 PM
    #2851
    tacowiz
    tacowiz Well-Known Member
    Wing
    Central Valley
    2021 Tacoma OR DCLB Army Green
    PrinsuDesignsStudio Cascadia Vehicle Tents Method Wheels (704) Falken WildPeaks
    SOS!! Can you peeps that have 16x8 -25 offset post a pic of your CMCs! Im going to run GEOLANDERS MT 285/75/16. I am getting a CMC done tomorrow and I need some reference to go off of on trimming the plastics. I have a 2.5 lift rn as well Thanks in advance!
  12. Dec 18, 2020 at 11:11 PM
    #2852
    Beef Nachos
    Beef Nachos Here for a good time, not a long time
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
    Cut it as far back as possible and don’t let the bushings catch fire. This is all I could get for you right now
    1C49F77A-573F-4AF3-88A6-46E8C6825D96.jpg EF9B4393-EDB8-4617-9F69-C9DDC3D2AAA0.jpg
    ChadsPride[OP] and Nickkk like this.
  13. Dec 20, 2020 at 6:49 PM
    #2853
    Sreppep
    Sreppep Well-Known Member
    Philip
    Fort Worth, TX
    2001 SR5 4x4 V6 5spd 264k - 2005 T4R V8 4x4 139k
    5100/Toytec, F5s/w KO2 285s, ARB, 4x skids/sliders
  14. Jan 2, 2021 at 6:22 AM
    #2854
    Anthony 82
    2015 grey tacoma
    Finally got my wheels mounted!
    If interested set up:
    265 75 16 duratrac
    2020 TRD pro front shocks with RC leveling kit
    Rear two inch lift block (stock shocks stretched to the max and getting beat to hell but I like the look and am broke lol)
    Shaved badges
    Powder coated stock running boards and.left plastic steps off
  15. Jan 2, 2021 at 7:32 AM
    #2855
    ChadsPride
    Niiiiiiiice :thumbsup:
  16. Jan 4, 2021 at 12:28 PM
    #2856
    WrongWD
    WrongWD Member
    Jon
    2006 Access Cab OR
    This looks fantastic! Any rubbing to report?
  17. Jan 4, 2021 at 3:13 PM
    #2857
    Anthony 82
    2015 grey tacoma
    Removed both mud flaps and haven't had an issue since! Minus the rock flingin
    Edit: thank you!
    WrongWD[QUOTED] likes this.
  18. Jan 4, 2021 at 3:32 PM
    #2858
    WrongWD
    WrongWD Member
    Jon
    2006 Access Cab OR
    Awesome, thanks for the feedback! I've got the -25 wheels here already and I'm waiting for the rest of my suspension refresh goodies before I buy a set of 265/75R16s.
  19. Jan 6, 2021 at 3:45 PM
    #2859
    Anthony 82
    2015 grey tacoma
    Sweet liKe that colour wheel! what colour is your truck?
    I would recommend removing those mini front mud flaps before installation I ended up ripping a bit of the well liner out when I was reversing at about half lock on my way back from the shop. You may be able to get away with leaving the bigger set on and mitigate some paint damage due to rock slinging
  20. Jan 6, 2021 at 3:51 PM
    #2860
    WrongWD
    WrongWD Member
    Jon
    2006 Access Cab OR
    The truck is Silver Streak Mica - got the silver spoke stickers to tie in with the truck. The sides of the truck are all scratched up from trail pinstripes, so the rock chips will blend right in
    Anthony 82[QUOTED] likes this.
