Stealth Custom Series F5 * Photo thread *
Discussion in 'Wheels & Tires' started by ChadsPride, Jul 25, 2017.
  1. Dec 28, 2023 at 10:10 AM
    #3281
    2k2
    2k2 Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
    Which one is new? The front? Looks a shade or 2 darker.
  2. Dec 28, 2023 at 2:07 PM
    #3282
    1dayKapaa
    1dayKapaa Well-Known Member
    Northern VA
    2019 Tacoma DCLB
    Man, I love that cap!
    Nickkk[QUOTED] and 2k2 like this.
  3. Dec 28, 2023 at 2:33 PM
    #3283
    1dayKapaa
    Northern VA
    2019 Tacoma DCLB
    I bought 5 blems. They all were good with very minor defects. Do you noticed a big difference in the shades when the sun hits?
  4. Dec 28, 2023 at 5:39 PM
    #3284
    Nickkk
    Nickkk Well-Known Member
    Long Beach, CA
    2018 Tacoma TRD Sport DCLB
    The rear is the new one. The front and other side are darker/ more brown. Rear is lighter/ more gold. Much more matte as well.
  5. Dec 28, 2023 at 5:43 PM
    #3285
    Nickkk
    Long Beach, CA
    They definitely change a lot of colors when the sun hits. The new one is just noticeably lighter and more matte to me.
  6. Jan 1, 2024 at 8:17 AM
    #3286
    TacoTrigger16
    TacoTrigger16 Well-Known Member
    Central Valley California
    2022 TRD OR 4x4 DCSB Super White
    Armor: RCI Plated 20 Degree Sliders RCI Full Skid Plates Steel RCI Fuel Skid RCI Rear Diff Skid SNS Designs ABS Guards Front Bumper: C4 Overlander with Full Hoops C4 Front Bumper Frame Support Brackets Bed: Total Chaos Bed Stiffeners Cali Raised Bed Light Kit Toyota Bed Mat Alu-Cab Contour Canopy Blue Sea 5025ST Fuse Block Blue Sea 4363 Switch Panel Victory 4x4 Front Bed Molle Panel Mountain Hatch Tailgate Table 3.0 Fire Extinguisher Shovel Axe Fatmax Extreme Lighting and Electrical: PowerTrays Essentially BantamX Spod Bantam X w/ Touchscreen Baja Designs 30” S8 Light Bar Driving Combo Baja Design Squadron Sport Diving Combo Baja Design Squadron SAE Fleece All Lights On Engine: K&N Drop In Air Filter Mishimoto Intake Hose Toyota Air Accelerator Toyota TRD Oil Cap Toyota TRD Radiator Cap ECGS Bushing SDHQ Terminal Kit Fumoto Engine Oil Drain Valve AC Drain Mod Exterior: De-Badged Black Tacoma Tailgate Letters Heritage Badge In Black/Grey/White AVS Rain Guards AVS Aeroskin Hood Protector Lftd Customs Taco Sauce Gas Cap Holder Tacoma License Plate Frame Black Sylvania License Plate LED Lights R4T Bumper Caps Meso Customs Headlight Trim Plate Meso Customs V5 Ultimate Turn Signals SDHQ Ditch Light Mount Rago Fab Antenna Mount Interior: Desert Does It Seat Jackers & MMP K&N In Cabin Air Filter Matte Black Steering Wheel Emblem Meso Customs Red Push To Start Meso Customs Vent Rings SW Meso Customs Climate Control Rings SW Meso Customs Interior Chrome Delete SW Meso Custom Minimalist Key Fob V2 SW Meso Customs Extended Fuse Cover AJT Designs Door Handle Covers Z Precisions Cup Holder Midland MXT275VP4 Yodaverse Interior LED Kit Yodaverse Center Console Organizer TacoMods Radio Knobs w/ Backlighting Headrest Paracord Grab Handles SOG Rapid Rescue Dongar Technology Mirror Adapter Garmin Dash Cam Mini 2 Baby Toyoda Square Center Console Insert WeatherTech FloorLiner HP Grey Expedition Essentials 3TPAM Ram Mount Accessories GoGettaGrip Shifter Knob Magnetic Mic Patches Suspension Lift: DuroBumps Front Bump Stops Icon Billet UCA’s Delta Joint All-Pro Sway Bar End Links Marlin Crawler HD LCA Frame Brace Bison Offroad Cam Stop Kit Total Chaos Cam Tab Gussets Total Chaos Cab Mount Chop Plates Total Chaos Spindle Gussets W/ Sway Bar Accutune Fox 2.5 DSC Front Shocks Accutune Fox Tundra 2.5 DSC Rear Shocks Accutune 2.5” Bump Stop & U Bolt Flip Deavers U402 Stage 1 Yota Mafia Rear Extended Brake Lines 24” ARB Carrier Bearing Drop Kit FK29 Archive Garage Hammer Hangers Archive Garage 3.6 Shackles Archive Garage High Clearance Cross Tube Wheels and Tires: SCS F5 16x8 -25 Offset 3.5 BS Gunmetal Mickey Thompson Baja Boss M/T 285/75R16 Gorilla M12x1.5 Lug Nuts ET Liftd Customs Leashed Valve Stem Caps Winch: Warn VR Evo 10-S Warn Wireless Hub Factor 55 1” Fairlead Factor 55 Rope Guard Factor 55 UltraHook Gray Tandem Offroad Control Box Mount LambTek Innovation Switch Bracket Kit Blue Sea Switch Recovery: Factory 55 HitchLink 2.0 Warn Epic Shackle x2 ARB Tree Saver 16’ Special Thanks to: Sibi Built for the lift installation. Tiny Rig Co for the Alu-Cab and installation. Accutune for the Fox Shocks with Adventure Tune. Baja Designs for lighting. C4 Fab for the front bumper. RCI for sliders and skids.
    I do not believe you can powder coat these rims. I think they must be painted. Due to the tolerances around the hub.
  7. Jan 1, 2024 at 12:10 PM
    #3287
    Nickkk
    Long Beach, CA
    Interesting. I’ve seen powder coated ones for sale here before. Maybe that’s why they were selling?
  8. Jan 1, 2024 at 7:40 PM
    #3288
    Thegrassisalwaysgreener
    Thegrassisalwaysgreener Well-Known Member
    Manitoba
    I would think a good powder coat place could properly mask all those surfaces no?
    TacoTrigger16[QUOTED] likes this.
  9. Jan 1, 2024 at 7:47 PM
    #3289
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Wrapped some new meat on my F5's
  10. Jan 21, 2024 at 12:25 PM
    #3290
    barch88
    barch88 Well-Known Member
    Michigan, USA
    2022 Tacoma SR utility package
    Hey, want to pick these up
    Is the 0 offset best for these if you're in stock form, or +10? Stock wheels I have are +30 (Steelies). I'm a totally stock 2022 SR, but in the future, I wouldn't mind doing a 2" leveling kit. I wouldn't mind extra poke, if the -25 fit completely stock.
    What size tire should I run with these, 265/75/16?
    Guess what I'm asking is. Would 265/75/16 and 16x8 -25 fit STOCK, or would I rub? If they don't fit, would +0 offset be the best option, would that fit? Thank you.
  11. Jan 21, 2024 at 5:09 PM
    #3291
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    I have 265/75/16 with -25mm offset f5s on a stock suspension 2020 SR... When I had wildpeaks my front driver's side tire rubbed the front bumper ever so slightly when in reverse at 3/4 lock. My current tires are just a bit skinnier (still 265/75/16), and I have no rubbing. I go off pavement sometimes, but if your looking at going off-road a lot then I would go with -12 or 0... My son has -12 ray 10s and 265/75/16 with no issues at all.
    barch88[QUOTED] likes this.
  12. Jan 21, 2024 at 5:22 PM
    #3292
    barch88
    Michigan, USA
    Thanks man! I’ll probably go with 0 if I go with the F5’s then. I really like the Ray10’s too, and if I go that route I’ll do the -10. Exactly the reply I needed. The size I plan to run is 265/75/16.
  13. Jan 21, 2024 at 5:25 PM
    #3293
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    Cool. Like I said... The rubbing I had was minor enough and rare enough not to trim anything, but then again I'm not off-road and flexing all that much ... So not sure what issues I might have with -25 offset if I was.
  14. Jan 21, 2024 at 5:32 PM
    #3294
    barch88
    Michigan, USA
    Yeah I plan to run some really aggressive tires. Thinking k02 or Toyo R/T Trails. I would love to go -25 just for the look alone. Everything clears fine, where does it slightly rub?
  15. Jan 21, 2024 at 6:05 PM
    #3295
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    Right now it doesn't. Im running Gt radial Adventuro ATX tires.
    When I had fallen wildpeaks It rubbed on the front corner of the front bumper on the driver's side (underneath) when the wheel was turned almost to full lock in REVERSE . It only rubbed when I had a passenger in the truck.
    So the rubbing really only happened when me and someone else were reversing out of a parking space and cutting the wheel hard. It wasn't often, but it was repeatable. I could have trimmed it, but it happened so infrequently that I decided not to.
    In my experience every Tacoma is a little different, so you could get the same setup and have no issues, or you could rub worse, or you could rub the cab mount. The bottom line is that -25mm offset with 265/75/16 aggressive AT tires could potentially cause some scrub radius rubbing in multiple areas... It's tight in some areas. I run the plasticolor mud flaps and I had to modify them so they didn't rub the tires. I have lots of info in my build thread if you want to check it out.
    https://www.tacomaworld.com/threads/baller-on-a-budget-under-30k-build.775717/#post-27724583.
    I have some links on there to the adjustments I had to make.
    PondScum likes this.
  16. Jan 21, 2024 at 9:02 PM
    #3296
    barch88
    Michigan, USA
    Thank you so much for the link my dude. It looks like the offset doesn't really have a difference in the concave of the wheel, usually the more aggressive the offset, the more deep-dish the wheel is. So it looks like this fit, you just had to trim some of the plastic wheel liner, is that right? I really appreciate this because my SR is like yours, doesn't have the fender flares, so it helps me get an idea how they actually look. I think the -25 is a little too much poke for me, your post helped me decide though. I'll likely go with the SCS Ray10's in -12 offset, from the sounds of it, should fit 265/75r16 tires with no problems too.
    Now I'm torn between black and gunmetal (white truck). Had Bronze on my WRX, but want to change it up. White and Bronze is so popular now.
  17. Jan 22, 2024 at 3:21 AM
    #3297
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    No trimming of anything... I did use a heat gun in the fender liner to mold a couple areas.
  18. Feb 16, 2024 at 5:25 PM
    #3298
    MastaZ9
    MastaZ9 Well-Known Member
    Zack
    Silver & Black TRD DCLB
    Y'all think worrying about the ~3/4 of a lb difference between the F5 & the new FA16 (17x8.5) is being to anal about my rotational weight?? :confused::rofl:
    Can't be noticeable right?...I'm diggin' that new machined lip, bullet hole design of the 16
    :headbang::101010::ohsnap:
  19. Feb 16, 2024 at 6:06 PM
    #3299
    barch88
    Michigan, USA
    no
    MastaZ9[QUOTED] likes this.
  20. Feb 27, 2024 at 11:18 AM
    #3300
    N64_Wallmaster
    N64_Wallmaster Carolina Cajun
    Raleigh, NC
    2017 LTD 4WD
    - Bilstein 5100 Shocks - Icon AAL - Old Man Emu 2885 Springs - 16" TRD Bead lock style alloys - bronze - Falken Wildpeak AT3W 285/75 r16 - IFS Skid Plate; Bare Aluminum - Body Armor 4x4 Revo Rock Sliders - Diode Dynamics SS3 Fog Lights w/ Amber Accent Lights - Tacoma Lifestyle Side View Mirror Sequential Turn Signals - Cali Raised LED Bed Channel Supports; added self-adhesive rubber edge trim - AFE Magnum Pro Dry S Filter - LEER 100R Camper Top - Weathertech Window Deflectors - Bulletpoint Mounting Solutions Dash Mount - TRD Pro Grille with Raptor Lights - Headlight H11 to H9 DIY bulb conversion - Diode Dynamics interior and license plate LED bulbs - FBC license plate light DIR - Replaced chrome LTD mirror covers with oe black - Replaced chrome LTD fog light bezel with oe black trim - Meso Customs map and dome lights - Hot Shot Offroad All Lights On - Metal replacement Toyota oil filter housing - VIOFO A119 Mini 2 dash cam
    Thanks for putting this together. Bronze F5's are the best looking wheels in my opinion.
