Stealth HD Tacoma U-Bolt Flip kit 2005-2023 2nd 3rd gen - Archive Garage
Discussion in 'Archive Garage' started by ARCHIVE, Oct 13, 2018.
  1. Mar 5, 2020 at 3:51 PM
    #41
    ARCHIVE
    ARCHIVE [OP] Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    Yeah, if you have a thin leaf pack like stock, I recommend trimming ubolts so there is only 1/2" of thread above nuts
    eyemajeenyus[QUOTED] likes this.
  2. Mar 11, 2020 at 12:15 PM
    #42
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    Hey Eric, so is your new bump stop better than the super bump ones? I'm THIS close to pulling the trigger! lol
  3. Mar 11, 2020 at 12:23 PM
    #43
    ARCHIVE
    Eric
    Yes, in a few ways
  4. Mar 15, 2020 at 2:47 PM
    #44
    urbanplanner
    urbanplanner Well-Known Member
    washington state
    Hey Eric, I’m looking at the option 3 for medium Dakar packs. PM for the discount code?
  5. Mar 15, 2020 at 4:15 PM
    #45
    ARCHIVE
    Eric
    Please start a conversation
  6. Mar 15, 2020 at 5:33 PM
    #46
    ARCHIVE
    Eric
    Did some testing with the new Option 3 Archive Speed bumps, very happy with the performance.
    Testing conditions were my 2000 1st gen Tundra AC, with over 1000lbs of steel at back of bed, Fox 2.0x12 (non adj), light leaf pack, to make sure the bumps were really getting fully tested. I have a seasonal road I do suspension testing on, it has all kinds of heaving and a little kicker bump that helps you use a lot of suspension travel. It landed so smooth, it makes you want to go faster.
    Design of the Speed bumps achieves a soft engagement while slowing weight down over a greater distance, and maintaining as much bump travel as possible, critical for moderate speed capabilities on 2nd/3rd gen Tacoma and 1g Tundra.
    Installed pics are with truck loaded down w/ 1000+lbs
    Yodastacotruck and cubie like this.
  7. Mar 28, 2020 at 8:54 AM
    #47
    ARCHIVE
    Eric
    I have a customer with TC bump kit, and his is landing right in middle just outboard of spring pin hole.
    Can you post more pics showing brackets?
  8. Mar 28, 2020 at 11:56 AM
    #48
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    This looks like a good kit. Any recs for the front?
  9. Mar 28, 2020 at 1:52 PM
    #49
    ARCHIVE
    Eric
    Thanks for pics. I think you are worried because is doesn't look lined up at normal ride height, but the axle moves forward after spring goes flat
  10. Apr 20, 2020 at 1:17 PM
    #50
    Fohu
    Fohu Well-Known Member
    Glade park Colorado
    2019 trd or access cab
    Hey @ARCHIVE about to pull the trigger on the bolt flip kit for 2019 Tacoma
    I just want to make sure that my rear ads piggyback reservoir won’t have issues interfering with the plate. ?
  11. Apr 20, 2020 at 1:38 PM
    #51
    ARCHIVE
    Eric
    Those are pretty. I think as long as the piggyback resi is pointed away from axle, there should be no issues. So driver side, resi towards rear bumper, and passenger side, resi towards front bumper, but I am no ADS to say that works for those shocks.
    How long are those compressed?
  12. Apr 20, 2020 at 5:33 PM
    #52
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    Might as well throw these pics up in here too. Thanks @ARCHIVE for an excellent product!
    Anton338 and ARCHIVE[OP] like this.
  13. Apr 20, 2020 at 5:50 PM
    #53
    ARCHIVE
    Eric
    Thanks Jonny!
    cubie[QUOTED] likes this.
  14. Apr 25, 2020 at 4:55 PM
    #54
    ARCHIVE
    Eric
    Some more pics of Option 3- Archive Speed Bumps.
    I now have these under my Tacoma and 1G Tundra
  15. Apr 28, 2020 at 7:32 AM
    #55
    Dave-rass
    Dave-rass Well-Known Member
    2015 Tacoma
    Hey Eric,
    I ordered the super bumps option. Should I have ordered your bump stops? Is it too late to change my mind?
    Also, I’m debating ordering the deaver expedition leaf pack, but I currently have the Dakar heavy duty pack, will I have any issues installing these bump stops and cutting u bolts to fit Dakars and then having them fit the deavers later on? Or should I wait to install once I have the deavers?
    Thanks
    Thanks
  16. Apr 28, 2020 at 7:53 AM
    #56
    ARCHIVE
    Eric
    It depends, if you have really long shocks in stock location (compressed length over 15.5"), then you may want to stay with Option 4 Super Bumps.
    As for U-bolts, I wouldn't trim them, it will probably be nice fit without trimming. If there is a long time between the installs you mention, then you may want to get a fresh set of ubolts anyway, U-bolts are a wear item that ideally should be replaced after they get rusted or bent during torquing.
    Dave-rass[QUOTED] likes this.
  17. Apr 28, 2020 at 9:05 AM
    #57
    Dave-rass
    2015 Tacoma
    Thanks Eric!
    I do have ADS extended travel shocks in the stock location.
    ARCHIVE[QUOTED][OP] likes this.
  18. Apr 28, 2020 at 9:45 PM
    #58
    AY_ARONTRD
    AY_ARONTRD Well-Known Member
    Aaron
    Murrieta ,CA
    2019 DCLB Cement OR 4x4
  19. May 11, 2020 at 3:54 PM
    #59
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I made some 1/2" bump stop spacers for the rear that will sandwich between the u bolt flip plate and the bump stop itself. Just wanted a little extra margin of error to protect my shocks in the case of a hard bottom out. Just need to get some longer hardware and will bolt them on. These are for the archive garage bumps.
    drizzoh, DrFunker, Chris(NJ) and 2 others like this.
  20. May 11, 2020 at 4:28 PM
    #60
    AY_ARONTRD
    Aaron
    Murrieta ,CA
    What were those made out of?
