stealth wheels write up
Discussion in 'Wheels & Tires' started by tisher49, May 12, 2010.
  1. May 12, 2010 at 8:40 PM
    tisher49
    tisher49 [OP] Well-Known Member
    Alex
    Orange, Virginia
    '08 4.0L 4x4
    K&N Air Filter, Westin Bull Bar with PIAA fog lights, Retrax cover, Alpine Head unit with I-Pod interface, maglite mount, Color matched grill surround w/ Grillcraft mesh
    This past weekend I did the stealth wheels mod and it turned out great. I spent under $50 on all the supplies, took maybe 8-10 hours total spread out over 3 days, and most importantly it looks great. I got the idea from this thread my buddy showed me from an xterra forum (http://www.thenewx.org/forum/showthread.php?t=5067). I thought there was one like that here on TW but couldn't find it when I searched. I did find skistoy's write up on painting the stock rims really helpful and used that as a guide. It's essentially the same except I used Dupli-color bed liner instead of the flat black paint.
    Materials
    •medium grit sand paper (80 grit)
    •fine grit sand paper (180 grit)
    •painters tape
    •old card board boxes
    •rags/towels
    •acetone cleaner
    •2-3 cans of Dupli-Color spray-on bedliner
    •index cards
    •white out
    optional: sander or sanding block
    Here's a not so great shot of the materials I used. The Rockwell did make the sanding go by faster but it's not necessary.
    Prep
    Ok so pretty simple Prep which is done for both the wheels and hub caps. I'd recommend doing 2 things at a time like sanding both a wheel and hub cap and then you can paint them at the same time.
    1. Either wash the wheels or wipe them down with acetone before you start sanding.
    2.Before you remove the wheel weights, use the white out to mark the spot of the wheel weight on the tire (you can just scrape it off the tire after the bedliner has dried).
    3. Sand the wheels with the medium grit sandpaper (you can use a sanding block or electric sander/dremel here) making sure to do the inner part of the wheel right behind the rim as well.
    4. Wipe the wheel down with a rag doused in acetone.
    5. Repeat step three using fine grit sandpaper and repeat step 4.
    6. Wrap the stem with painters tape.
    The wheel is now ready to be painted. Mine looked like this to give you a reference. You can see the white out mark on the lower part of the tire.
    Painting
    Once you have prepped you are ready to paint. I found the best technique was always spraying while my hand was moving and in short but controlled bursts.
    1. Place the index cards in between the tire and wheel and this should be enough to keep spray off the tire. (NOTE: Keep a rag nearby just in case you spray the tire)
    2. Spray the inner side of the wheel nearest the rim first to get a nice coat inside the wheel.
    3. Start by spraying through the holes to get the visible parts of the inside of the wheel.
    4. Then spray around the rim almost parallel with the index cards. This gets that little outside lip of the rim which is tough to get later in the process.
    5. Hit the center of the wheel where the holes for the lug nuts are.
    6. Lightly spray the rest of the wheel. At this point not every spot has to be covered.
    7. Wait 5 minutes or longer depending on the drying conditions and give the wheel a second coat.
    8. With the second coat start by working outside in on the wheel spraying any of the spots not painted yet.
    9. Wait another 5 minutes and apply a third coat.
    10. Touch up any spots and let it dry for at least 12 hours.
    NOTE: When a can of duplicolor gets low it the can starts to spray heavier droplets which can mess up the nice smooth coat you've already laid down. Wiping the spray tip off with a rag helps but when I still got droplets I just started a new can.
    Here's a picture of my set up. 2 hub caps drying in front, my 14 year old yellow hangin out, and the cardboard set up with wheels ready to paint in the background.
    The result is:
    Looks a little shinier than it actually is because of the flash.
    Finish
    1. Once the wheels have dried for at least 6 hours, I waited 12 in case, look for any spots you missed and touch them up.
    2. Dry any thing you touch up for at least another 3 hours.
    3. Place any wheel weights you removed back in the spots marked with the white out.
    4. Remove the painters tape from the stems.
    5. Put the wheels back on (you can rotate them here if you want, I went front to back cuz i still have the OEM spare).
    6. Leave the hubcaps off for now.
    7. Once the truck is back on the ground make sure the lug nuts are tightened enough.
    8. At this point put the hub caps on.
    9. Scrub off the white out on the tires.
    10. Enjoy your new stealth wheels
    One final comment, I tried Rustoleum's spray on bed liner and it was more like a rubbery spray paint than bed liner. The duplicolor has a much more "bed-liner like" feel to it while the rustoleum leaves a smooth rubber coating. I also found that the rustoleum pooled up much more easily than the duplicolor did.
    More Shots:
    Let me know if you have any questions. Thanks for reading the write up and sorry it's a bit wordy but patience is also a key in this project.
  2. Nov 14, 2010 at 12:59 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Nice job man! they look great.
  3. Nov 14, 2010 at 1:03 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    nice job / writeup reps
  4. Nov 14, 2010 at 4:54 PM
    tisher49
    Alex
    Orange, Virginia
    '08 4.0L 4x4
    Thanks for the compliments and reps... It was rather painstaking but so worth it, especially considering how much I'd have to spend to get new black wheels.
  5. Nov 14, 2010 at 6:13 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Never heard of it being called "stealth wheels" but good writeup nonetheless.
  6. Nov 14, 2010 at 6:36 PM
    tisher49
    Alex
    Orange, Virginia
    '08 4.0L 4x4
    haha kinda makes it sound cooler than just black wheels i guess lol
  7. Nov 14, 2010 at 7:01 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '10 4x4 DC SR5
    WeatherTech liners, Kenwood Media Receiver, Alpine S 6x9 speakers, Sound Ordnance 8" Sub, OEM running boards, MK6 wheels, Dynapro ATs, Tint, Bed Mat, Avid Light Bar, Rigid 20" LED bar, Truxedo Lo Pro Tonneau Cover
    Is the bedliner for an extra-matte look or is it more durable than duplicolor paint?
  8. Nov 14, 2010 at 7:58 PM
    tisher49
    Alex
    Orange, Virginia
    '08 4.0L 4x4
    both for the look and durability...i never tried just a regular paint but i figured the bedliner would be a little more durable.
    the only place its chipped is on the lip right next to the tire since i couldnt sand that area as well. Next time I'm home I'm going to sand the lip and put another coat on it
  9. Jan 7, 2011 at 8:42 AM
    skb7527
    skb7527 Political Correctness Sucks!
    Scott
    McKinney, Texas
    2012 Pyrite Mica 4X4
    Toyo A/T Open Country II tires with America Outlaw Sheriff wheels, Bilstein 5100s all the way around, OME coils, Toytech AAL, debadged, removed pin stipe, chopped tail pipe, weather tech floor mats, Leer color match topper, Toyota bed mat, homemade eight ball gear shifter and cargo divider
    Those look awesome! How is the liner holding up on the plastic hub cover and to the rim when it gets hot as you drive? I'm sure if I prep my chrome rear bumper this liner should stick to that too...I tried putting rustoleum bedliner on my plastic grille and it chipped/pealed off.
  10. Jan 7, 2011 at 5:18 PM
    tisher49
    Alex
    Orange, Virginia
    '08 4.0L 4x4
    Thanks man. The plastic hub covers are holding up really well although I had some issues with them staying on at first. I had 2 fall off in a span of a week; lost one, saw the other one fall and picked it up a day later. But amazingly no scratches on it lol. I am thinking of doing the same thing to my bumper. Just sand a lot and clean it and it will work well. I'll probably put a rust coat down first as well. Duplicolor is the way to go. I'm about to try it with a brush but everything I've done so far has been with spray cans.
  11. Jan 8, 2011 at 5:39 AM
    skb7527
    Scott
    McKinney, Texas
    Now you have me wondering if the bedliner spray would stick the the lower front valance of the front bumper...I think it would look awesome. As for rolling/brushing it on, dont you think it might look a lumpy or not as clean as a spray finish...Once it warms up I'm gonna work on my rear bumper. Do you think etching primer should be used too when doing the rims/bumper?
  12. Jan 8, 2011 at 5:45 AM
    tisher49
    Alex
    Orange, Virginia
    '08 4.0L 4x4
    I don't see why it wouldn't. It stuck to the plastic handles in the truck with no sanding or prep whatsoever. It also stuck to my roll top which is a hard plastic so I would think as long as prepped the lower valence you'd be fine.
    As for spraying vs. brushing I had the same thoughts myself. The spray can be a little harder to control especially near the end of a can but it provides a nice even finish. I'm going to try touching up the lips of the wheels with a brush and see how that looks before I do anything else.
    I doubt the etching primer is necessary but I don't think it would hurt either.
