Stealthbox causing rattle? please help
Discussion in 'Audio & Video' started by jwj202, Nov 7, 2012.
  1. Nov 7, 2012 at 6:16 PM
    jwj202
    jwj202 [OP] Well-Known Member
    Joey
    Mississippi
    '10 silver TRD Offroad SR5
    I just purchased a jl audio stealthbox for my '10 DCSB and ever since i got it, something is rattling really bad every time the subs hit. Its not the subs hitting the back of the seat. I think its the plastic on the back. I was wondering if anyone else has experienced this and what they did to fix it.
  2. Nov 7, 2012 at 7:40 PM
    jwj202
    Joey
    Mississippi
    Anyone?
  3. Nov 7, 2012 at 7:42 PM
    42boxer
    42boxer Well-Known Member
    Brannon
    Mcguire AFB, New Jersey
    2000 Toyota Tacoma TRD
    Plenty to come
    Pry to play it and locate the sound better
  4. Nov 7, 2012 at 8:30 PM
    jwj202
    Joey
    Mississippi
    did this. im almost positive it is the black plastic behind the seat hitting something and if i press on it to secure it it somewhat stops then the vibration will just move. i cant find or think of a way to fix it..
  5. Nov 7, 2012 at 9:22 PM
    jwj202
    Joey
    Mississippi
    bump
  6. Nov 8, 2012 at 6:51 AM
    Madjik_Man
    Colorado Front Range
    There's a lot of plastic on metal contact in our trucks (I have a 1st gen, not exactly sure about the guts of your truck)
    I'm putting raam mat and ensolite on every interior wall (rear wall fully covered, quarter-wall strategically covered).
    That is going to cut down on a lot, if not all, rattles.
  7. Nov 8, 2012 at 6:02 PM
    jwj202
    Joey
    Mississippi
    Is that similar to dynamat? how much is it costing you
  8. Nov 8, 2012 at 6:32 PM
    Madjik_Man
    It's similar to dynomat for a fraction of the cost.
    I spent $150 (shipped) and I'm able to to my entire rear wall (doubling up on the most resonant areas), strategic areas of the quarter panels and both front doors entirely. That includes both the BXT II raam mat (dynamat equivalent) and the Ensolite (a foam that breaks up higher frequencies). When used together the results are great IMO
    FYI I have 98 Tacoma ext cab
    Here's a link to Rick's site: http://www.raamaudio.com/categories/Mat-and-Foam-Products/
  9. Nov 8, 2012 at 6:44 PM
    SoCalTacos
    SoCalTacos Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    I dynamated the entire back of my 2012 and all doors...still rattles when bass is up. removed the plastics in the rear of seats. You just have to accept that if you don't dynamat the ENTIRE truck...shits gonna rattle. I'm running the stealthbox as well.
  10. Nov 8, 2012 at 6:49 PM
    jwj202
    Joey
    Mississippi
    When you ripped the plastic out how did you fit the stealthbox in?
  11. Nov 8, 2012 at 7:37 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    You sure you didn't blow it? Thats what a speaker sounds like as its about to go out :)
    Not saying it IS the problem, but you could be chasing your tail because of this.
  12. Nov 8, 2012 at 7:43 PM
    deanbhula1
    deanbhula1 Well-Known Member
    I would take the black plastic off...the sub will sound better anyway cause the waves won't be canceling off the hard plastic
  13. Nov 8, 2012 at 8:41 PM
    jwj202
    Joey
    Mississippi
    I bought the box 2 weeks ago its not busted because if i press down on the black plastic it stops. But if you take the plastic out theres no where to put the stealthbox becasuse its made to fit in the black plastic?
  14. Nov 8, 2012 at 9:39 PM
    brian
    Elizabeth City, NC
    Get some vibration isolating tape then. Even so much as a little bit of the 3M double sided might work in areas where its rattling. The 3M kinda has the same spongy properties as vibe tape. Used this on someones POS car once, shit works miracles. You should be able to pull up an edge of the back plastic, chances are its rattling where the back wall pieces meet (I believe theres 3 in total).
  15. Nov 8, 2012 at 10:05 PM
    SoCalTacos
    socal
    My system was professionally installed so I didn't put it in myself. All I know is they cut out all of the plastic, including the child safety hangars. Dynamatted the rear of the cab, four doors. Amp and lc6i module are behind the driver rear seat.
    My headliner rattles now, may have to dyno the ceiling.
  16. Nov 9, 2012 at 11:55 AM
    Aw9d
    Aw9d That one guy
    Foam. You can fix all these stupid plastic rattles with shipping foam and some glue to hold it in place. Gotta be creative sometimes to make it work.
    Also Dynomat/fatmat, all stuff helps deaden sounds and won't always remove rattles. Plastic is the typical cause for rattles on the 2nd Gen Tacoma.
