Stearing Issue with Falken Wildpeak Load E Tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fendergeek, Jan 9, 2023.
  1. Jan 9, 2023 at 7:51 PM
    Fendergeek
    Fendergeek [OP] Active Member
    Denver, CO
    2013 Tacoma TRD
    Hi there, long-time reader, first-time poster.
    I have spent many evenings reading about similar issues on here--the closest I could find to my setup/issue was Flo Tacos post on the steering thread a few years ago. Basically I've had numerous issues with this setup starting with the balance on these Falken tires. Now my issue seems to be a bump stearing where the stearing jumps all over the road at speeds above 50 MPH. Things I've replaced within the last year for this and maintenance reasons include:
    Front bearings/hub, CV axles, front differential seals (ECGS spindle bearing delete), brake rotors/calipers/pads, inner/outer tie rod ends, upper intermediate steering shaft (with a rag joint that had 100k miles on it), passenger side LCA, driver LCA/ball joint is still in good shape.
    Some people want to point to the tires being heavier than recommended for Tacomas or the fact that I don't have a sway bar and I'm open to any and all suggestions. I've checked everything and it feels tight. Was going to replace the steering rack bushings but they seem to be in good shape. The truck is a 2013 with 290,000 miles.
    Thanks for your help!
  2. Jan 9, 2023 at 7:54 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Try rotating your tires from front to rear.
    Put the sway bar back on.
    What spring rate are the front coils?
    Got any photos of the truck/suspension/steering rack?
    Fendergeek[OP] likes this.
  3. Jan 9, 2023 at 8:00 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Do you happen to have your alignment #?
    drizzoh and Fendergeek[OP] like this.
  4. Jan 9, 2023 at 8:03 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Are the alignment cams at 100 lb/ft?
    What's the tire pressure?
  5. Jan 9, 2023 at 8:14 PM
    Fendergeek
    Denver, CO
    2013 Tacoma TRD
    Yeah, they're at:
    3.77 degrees Left, 3.59 degrees Right -- Positive camber
    .24 Left, .29 Right -- Caster
    .07 Left, .08 Right -- Toe
    I will check that. Have the SPC cam tabs/bolts.
    Tire pressure is 42 in the back, 38 front.
  6. Jan 9, 2023 at 8:30 PM
    Fendergeek
    Denver, CO
    2013 Tacoma TRD
    Yeah, working on the sway bar. I deleted it semi-permanently, like an idiot.
    I believe the springs are the 600 lb but I need to confirm.
    Will try to post some pictures tomorrow.
  7. Jan 9, 2023 at 8:35 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Any weight in the bed? That's pretty high tire pressure. Try airing down to around 30-32 and see if it helps
  8. Jan 9, 2023 at 8:36 PM
    Bishop84
    Bishop84 Well-Known Member
    You have caster and camber reversed. But they look good.
    Has anyone checked the lower ball joints properly? are they original? Steering rack?
    drizzoh, Fendergeek[OP] and TnShooter like this.
  9. Jan 9, 2023 at 8:39 PM
    Fendergeek
    Denver, CO
    2013 Tacoma TRD
    I contacted Falken and that's what they recommended based on the factory numbers. Yeah, haven't figured out these tires yet so I'll try airing down. Do typically have some weight in the back with a topper and tools. Front Prinsu access cab rack but no armor, bumpers, winches, etc up front.
    Ball joints are good. I forgot to mention I replaced the passenger LCA but not the driver side. Ball joints seem solid. Steering rack bushings are old but firm. No play really. I plan to replace them because of age. Also, I replaced the upper intermediate shaft with the rag joint but the one I put in has about 100k miles on it. Definitely helped to stiffen up the steering a bit but the bump steer seems to be a separate issue?
  10. Jan 9, 2023 at 8:42 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    E rated tires are for full size pickups. They will only cause your taco to ride rougher and behave worse on the road, that pressure it too high also, 35 psi is good. Sounds like you’ve got a few things combining and causing a noticeable issue
  11. Jan 10, 2023 at 5:11 AM
    flatt-taco15
    flatt-taco15 Well-Known Member
    2015 DCSB TRDOR
    RCI full set steel skid plates 4x Innovations Sliders Rough Country 2" front spacer 1" rear steel block spacer Bird Dawg TechDeck
    What is the offset of your wheels? Are you running wheel spacers? Both these can lead to bump steer.
  12. Jan 10, 2023 at 11:41 AM
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Having just gone from P rated Toyo AT3s to Motomaster in LT rated, ride is def harsher over bumps, but my truck is pretty smooth on the highway. Also E rated tires need much higher air pressure to cary the same load as P rated. I believe 40psi is the minimum for our trucks. Based on most of the forum comments around tire PSI, I suspect there are a lot of people driving around on under inflated LT tires...
  13. Jan 10, 2023 at 1:51 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Drop E rated PSI to 32-35. That's as good as your E load tires will get.
    I'd bet it's mostly the front shocks are just tuned to be too sporty. How much lift/preload on the coilovers? Could try turning the DSCs all the way down soft to experiment. Mine were a bit like that before breaking in and dialing down the DSCs. I still need to revalve mine to be optimal.
  14. Jan 10, 2023 at 2:46 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    I've been running e tires on my truck since I bought it I have 32 psi in them and no issues.
    BPfishing and Fendergeek[OP] like this.
  15. Jan 10, 2023 at 2:49 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
  16. Jan 10, 2023 at 5:55 PM
    Fendergeek
    Denver, CO
    2013 Tacoma TRD
    Offset:0mm
    Backspacing:4.750
    No spacers
  17. Jan 10, 2023 at 6:01 PM
    Fendergeek
    Denver, CO
    2013 Tacoma TRD
    I have the high speed dialed all the way down and the preload is set to stock height for the Fox shock. Firmer valving feels more solid at speed but the issue seems to be coming from something in the steering wheel/rack because I feel every bump jerking the wheel as the road irregularities are being transmitted up from the tires. Do people that run the load E tires change anything with the steering rack/column?
    Looks like Falken was wrong for PSI, I ran the numbers through that calculator and should be at 35 for front, 36 for rear. I'll dial in these adjustments and report back.
    Thanks you all. Got some more things to try.
  18. Jan 10, 2023 at 6:07 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Try setting the tires down to 30-32. Seriously it's not going to hurt anything. Part of the benefit of 10 ply tires is you can air them way down and they'll be fine
  19. Jan 10, 2023 at 6:15 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I can't agree with this enough.
    wi_taco and tacomataco2 like this.
  20. Jan 10, 2023 at 6:33 PM
    BPfishing
    BPfishing Well-Known Member
    Brian
    Central Texas
    2019 Tacoma TRD OR
    Your tires being load range E is not your problem.
    jaymac10 likes this.
