Stearing turns left but nothing when it comes back
Discussion in 'Technical Chat' started by Bigcarl 23, Dec 12, 2012.
  1. Dec 12, 2012 at 7:25 PM
    Bigcarl 23
    Bigcarl 23 [OP] New Member
    Me and my gf have a 06 Tacoma whe. She turns left it's ok but when it comes back to straight there's no power stearing but it turns right and comes right back ? Any ideas I'm a jeep guy not sure what's going g on pump? Stearing rack?
  2. Dec 12, 2012 at 7:32 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    On most rack and pinion systems, there's typically a rotary valve on the rack that ports fluid to the correct side of the piston in the rack. If certain parts of the valve is leaking or clogged, this could happen. Probably looking at a rack replacement then.
    Power steering fluid level OK?
    Another possibility is no suspension caster in one corner. Did you buy the truck used? When was the last time an alignment was done? Is there a lift installed?
  3. Dec 12, 2012 at 7:44 PM
    Bigcarl 23
    No lift it has 126k on it it's been awhile since it had a alinment there nothing lose I just did the oil change and checked the front end good so other than it doing that idk the fluid is good too
  4. Dec 12, 2012 at 7:57 PM
    KenLyns
    Belly of the Beast
    Rack bushings OK? You can check by turning the steering wheel back and forth while the truck is parked with engine running. See if the rack body shifts (it shouldn't).
    If that's OK, then a replacement rack is probably needed. Reman'd units are available on Rock Auto for $270 plus $150 core charge.
