stearing wheel wobble STILL
Discussion in '1st Gen. Tacomas (1995-2004)' started by RGosen, Mar 28, 2013.
  1. Mar 28, 2013 at 8:05 PM
    RGosen
    RGosen [OP] Well-Known Member
    Christ would now agree, don't get yourself nailed to a tree
    Kamloops B,C CANADA
    2000 toyota tacoma 4x4 2.7
    Cold air intake
    So I have changed my tires and rims three times now and had one set balenced But still the same back and forth about an inch when doing around 90-110 kms. What is going on here lol driving me madly crazy...I even went to a smaller tire this time thinking maybe it was from big 31s causing the issue but nope still doing the same thing. new tires different rims three times and the same thing still there. done re allighnment twice, all my front end and shocks and struts are new nothing has stopped this issue from happening..anyone els ever have this ?:mad:
  2. Mar 28, 2013 at 8:09 PM
    Mossy
    Mossy Mechanic for Honda
    billy
    san antonio, TX
    ProComp lift Borla exhaust Borla air filter Nfab bars
    are these tire shops checking for road force when they balance these tires?
  3. Mar 28, 2013 at 8:25 PM
    RGosen
    Kamloops B,C CANADA
    Cold air intake
    Nope but its pretty uncanny how every set I get before and after a balence its still the exact same wobble and after three sets of rims and tires ive sold due to this and every set is exactly the same wobble which had no wobble on other vehicles. I even drove the last set on another 96 tacoma and they were just fine no wobble..get them on mine and once again the same thing
  4. Mar 28, 2013 at 8:31 PM
    taco terror
    taco terror got 5VZFE?
    Austen
    North Carolina
    Non-Turd Gen
    AR Baja wheels, 33 BFG ATs, 4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, Line-x
    Can someone please come up with a solution for this, mine does the same thing.
  5. Mar 28, 2013 at 8:51 PM
    chich2000
    chich2000 Well-Known Member
    AK
    Tacoma 4WD TDR
    Doesn't sound like its a problem with the wheels/tires, but instead on the truck side. Maybe something in the steering system is loose or worn out?
  6. Mar 28, 2013 at 9:01 PM
    cottontop
    cottontop Active Member
    Alabama
    10 DCSB 4x4 TRD OR
    ARB Bumper 8000lb Warn
    maybe should check the bushings. Add a steering stabilizer:)
  7. Mar 28, 2013 at 9:03 PM
    taco terror
    Austen
    North Carolina
    Non-Turd Gen
    I don't see how at 88,000 miles my bushings could be the problem.
    OP might be a different story.
  8. Mar 28, 2013 at 9:10 PM
    cottontop
    Alabama
    10 DCSB 4x4 TRD OR
    I had an 87 that did same thing. I added an aftermarket steering stabilizer and it went away. With your mileage it seems tire related. Goodyear has been known to cause wobble on fords and dodges
  9. Mar 28, 2013 at 11:06 PM
    RGosen
    Kamloops B,C CANADA
    Cold air intake
    I did put in steering rack bushings as well. maybe I should allso try the stablizer as well ,,its just one more thing to knock of the list thats not been done to this truck lol
  10. Mar 29, 2013 at 4:48 AM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    88,000 miles normally wouldn't be a big deal....however, your truck is 17 years old....bushings dry rot.
  11. Mar 29, 2013 at 5:14 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser
    Stuff
    Check out the bushings, maybe do the steering column tack weld mod, check the rod ends, grease driveline
    . First I would get them road force balanced. The other thing to make sure of is that the place doing the balancing has the toyota adapter for the wheels. Toyota's have a specific adapter that needs to be used when balancing, using a universal one doesn't always work.
  12. Mar 29, 2013 at 5:15 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    07 FJ Cruiser
    Stuff
    This. And even at 88,000 miles they could still wear out. Depends on a lot of variables. if you wheel the piss out of it, take corners like a race car driver, etc.. they will wear out faster. Even if you don't do those things, afte 17 years they're likely in need of replacement.
  13. Mar 31, 2013 at 10:54 PM
    RGosen
    Kamloops B,C CANADA
    Cold air intake
    When you mean the bushings you mean the steering rack bushings right ? I did put new ones in didnt change a thing. What is the steering column tac weld ? I will give that a shot but cant find how to on here. I had the whole front end checked out at a shop when they found out my clutch was shot they put in the steering rack bushings and oils all around. altho I dont thing its the steering rack as there is no play in it.
