Steel Cable or Synthic Rope
Discussion in 'Technical Chat' started by RDNK TAZ, Dec 16, 2012.
  1. Steel Cable
    15 vote(s)
    19.5%
  2. Synthic Rope
    62 vote(s)
    80.5%
  1. Dec 22, 2012 at 4:44 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Synthetic every day of the week and twice on Sunday.
    It's lighter, it's safer, it's a million times easier to re-spool, it's just as strong. Only downside is it less resilient to be scraped along a rock/tree, but cable doesn't handle that all that well either. That's where straps, sleeves, and snatch blocks come in.
  2. Dec 23, 2012 at 6:48 PM
    RDNK TAZ
    RDNK TAZ [OP] Well-Known Member
    Chad
    Marion, SC
    '11 Silver Streak Mica DCSB TRD 2x4
    Ok, besides the safety issue. Its there anyone on here that has synthetic rope on theirs that doesn't use their winch on an every day bases. More like maybe once a month if that. How well has it held up and have you cleaned it like it should be?
  3. Dec 23, 2012 at 10:20 PM
    MHS2846bg8
    MHS2846bg8 Experienced Noob
    Nate
    South Coast of Oregon
    21 Tacoma TRD Off-Road Dbl Cab 4x4
    4WP Factory Front Bumper w/Warn VR EVO 10-S Winch, AuxBeam 8-Switch Controller, Redarc Trailer Brake Controller, ARE CX-Evolve Cap, Bedrug Liner, Ditch Pod Lights, Aftermarket LED (OEM) Bed Lights, Console Vault
    My buddy has synthetic rope and a very good point on it is that it is a hell of a lot easier to wrap back up than steel cable. I don't know about his maintenance routine though, he barely uses it.
  4. Dec 24, 2012 at 4:27 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    We had it on our jeep for years and only used it when needed. Probably once a month or less. It never really got dirty....other than regular usage. We may have sprayed it off with a hose after being submerged in mud.
    Don't over-think it. If it were that complicated to deal with, nobody would recommend it.
  5. Dec 24, 2012 at 8:59 AM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    I use steel but I use the winch on my runner for tree removal for my buddies business as well for wheeling. Otherwise I would use synthetic.
  6. Dec 24, 2012 at 8:50 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Absolutely no question.
    Synthetic winch line.
    Take care of it, wash it every once in a while.
  7. Dec 24, 2012 at 9:12 PM
    Tenmile Tacoma
    Tenmile Tacoma IG: tenmile_tacoma
    Nate
    Colorado
    2016 DCLB TRD Sport 4x4
    F&R locked on 33s
    I've heard cable is better for work. For instance, it is great for plowing. But, when it comes to off roading I've heard synthetic is awesome. As the others said, it doesn't fray and just falls to the ground when it breaks. I am running cable on my winch on my atv and literally hate it. I am switching to synthetic when I have time to take the winch off my quad and replace the cable with the rope. I don't like the cable for a couple reasons: Kinks, frays, bends, it's heavy and snaps when broken, which is sooo dangerous.
  8. Dec 25, 2012 at 1:17 AM
    Mikehole
    Mikehole Well-Known Member
    SF Bay Area
    '12 4x4 Short Bed TRD Off Road
    TRD Supercharger, Toytec 3" Ultimate Lift w/ 285/75/16s and planning on OBA for sometime in the future. Also thinking about the HWMS and a Warn 8000 for it.
    Warn's "winching techniques" on the M8000 page tells you to lay a heavy mover's blanket on the center point of the non-tensioned cable.
    http://www.warn.com/truck/winches/images/1842/62885A6_Domestic-read.pdf
    page 10
    I went with synthetic, due to the front end weight being less. Haven't used it yet, because I'm in the process of installing my bumper and winch, and haven't even bothered to do the initial spooling, yet.
  9. Dec 25, 2012 at 1:48 AM
    stewartx
    stewartx Well-Known Member
    Huntsville AL
    2012 Silver DC SB TRD Off-Road
    Winch, front hitch, step bars, bed extender, bed step, gull-wing toolbox, tailgate lock, security system, cb radio, etc.
    Synthetic rope is my choice as well. It's safer, easier to drag out or re-spool, floats on water, and just a lot less hassle overall. My winch is less than a year old and has already been used several times (to pull a car out of the ditch, pull down a brick column at an old house for fun, etc) with no problems.
    My plan is to replace the winch cable (synthetic rope) about once every two~three years, or earlier if visibly damaged.
    I tape (waterproof duct tape) black plastic (unopened garbage bag) tightly around the rope itself to keep the sun off. The plastic comes off easily when I need to use the winch and is eventually replaced when I get around to it afterwards.
