Steel Core vs Case
Discussion in 'Guns & Hunting' started by =jesse=, Jan 5, 2011.
  1. Jan 5, 2011 at 7:06 AM
    =jesse=
    =jesse= [OP] Active Member
    Jesse
    VA
    TRD Sport
    afe cai, trd catback, billies, spidertrax, bullbar
    Can someone please shed some light on this for me?
    I bought a thousand rounds of 7.62x39 for my wasr10. I bought steel cased hollow points. When I went to my range, it stuck to the magnet and they wanted to break open a round to see if it was steel core. It ended up not being a problem because a manager came up and said the ammo was fine since it was hollow point. It worked out fine, but I got pretty nervous thinking I just bought a thousand rounds that I couldn't put down range.
    Does FMJ equate to Steel Case? Does Steel Case mean Steel Core?
  2. Jan 5, 2011 at 7:09 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    i dont know but i shot some of these rounds through a old military spec gun with a bayonet on the end.....the gun was light as hell and was a wicked sumbish
  3. Jan 5, 2011 at 7:23 AM
    =jesse=
    Jesse
    VA
    TRD Sport
    I like it. It's got a pretty mean kick but its a good gun for the money. I know a lot of people on here are more for AR's, but it's more than I wanted to spend, it's durable, fun, and chances are I won't need to make long distance shots that my life depends on on a daily basis.
  4. Jan 5, 2011 at 7:33 AM
    98tacoma27
    Ben
    Not Beech Creek
    Steel case normally means the case is steel in stead of brass, not the bullet. What brand did you buy? And FMJ just means the core is encased in a "one piece" metal jacket. It has no designation for the metal material.
  5. Jan 5, 2011 at 7:39 AM
    =jesse=
    Jesse
    VA
    TRD Sport
    Good info, thanks. I bought some Russian Brown Bear. It was pretty cheap considering the quantity I got. I've gone through about 300-400 rounds so far and haven't had any jams or ftf's.
  6. Jan 5, 2011 at 7:41 AM
    98tacoma27
    Ben
    Not Beech Creek
    Ah, Russian ammo. Same as Wolf pretty much. It's the cases that are steel. It's why they're painted green. Do not reload the cases.
  7. Jan 5, 2011 at 7:45 AM
    Dimonback
    Dimonback Well-Known Member
    Patrick
    Austin, Tx, from all over hell and back
    Geezer double cab w/ shell
    The steel case is/was cheaper than brass. Steel case ammo is not meant to be reloaded (hard on dies, harder to re-form and size, and often the primer is not replaceable). I've done it just out of curiosity, but it's not meant to be.
  8. Jan 5, 2011 at 7:47 AM
    98tacoma27
    Ben
    Not Beech Creek
    The case necks often split also. Usually after the first shot with new ammo.
  9. Jan 5, 2011 at 8:12 AM
    =jesse=
    Jesse
    VA
    TRD Sport
    I'm not worried about reloading the cases. The ammo is cheap enough to just buy more and I'm not proficient enough with ammunition to take that task on anyway.
  10. Jan 5, 2011 at 8:16 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    ive seen where some ranges dont allow russian/steel case ammo. Dont know why though
  11. Jan 5, 2011 at 8:17 AM
    98tacoma27
    Ben
    Not Beech Creek
    I'm guessing because of reclaiming the brass. It would take a lot time to sort that stuff.
  12. Jan 5, 2011 at 8:27 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
  13. Jan 5, 2011 at 9:37 AM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    Steel core is armor piercing.
    Some ranges don't allow it for liability reasons.
  14. Jan 5, 2011 at 7:44 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    FMJ = full metal jacket. The bullet core (either lead or steel) is encased in a copper jacket to glide down the barrel easier.
    Some ranges don't allow steel core bullets because they are harder on the backstops.
    FMJ and hollowpoint (abbreviated JHP) are mutually exclusive. A hollowpoint bullet by definition cannot be steel core because there is no core.
  15. Jan 6, 2011 at 5:04 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    Couldn't they just use a magnet to remove the steel cases?
  16. Jan 6, 2011 at 5:25 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yes, but then they are left with a shit ton of steel to get rid of. Granted they could recycle it with the brass but it doesn't pay for the effort.
  17. Jan 6, 2011 at 8:48 AM
    thinkingman
    redmond WA
    Most HP's have a core
