Steel or Aluminum axle shims?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mts, Mar 7, 2016.
  1. Mar 7, 2016 at 7:49 AM
    mts
    mts [OP] Well-Known Member
    Lexington, KY
    2007 TRD Sport-TRD Supercharger
    Picking up a set to see if I can get rid of my slight drivetrain vibration with the Dakars and noticed there are steel/zinc and aluminum ones offered for roughly the same price at wheelersoffroad. Any reason to pick one over the other? Hate that I didn't do this on the initial install. Oh well.
  2. Mar 7, 2016 at 8:11 AM
    I leak oil
    I leak oil Member
    2013 TRD
    Get the zinc. Steel will corrode, aluminum will corrode badly when in constant contact with steel.
  3. Mar 7, 2016 at 6:05 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Nope. Zinc is what the OP asked about and that is actually farther from mild steel on the galvanic chart (more corrosion potential in the presence of salt water) than any series of aluminum. http://www.preservationscience.com/materials/metals/PGC.html.
    Edit - and to be honest I'm not sure why that is the case :(
  4. Mar 7, 2016 at 6:07 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Did you check to see if a carrier bearing drop kit would help first? 5 minute install to check and see.
  5. Mar 8, 2016 at 4:23 AM
    mts
    Lexington, KY
    Already done the carrier drop. Helped, but not enough.
