steel tube rear bumper?
Discussion in '1st Gen. Tacomas (1995-2004)' started by DaytonLax14, Apr 16, 2011.
  1. Apr 16, 2011 at 3:50 PM
    DaytonLax14
    DaytonLax14 [OP] Well-Known Member
    Corey
    Ohio
    98 extended cab TRD Off Road
    Who's made a rear bumper by just stacking 2 layers of steel tube? I have a nasty dent in my rear bumper and I like the look of the metal ones anyway. I drove around the farm today and I found some good tubing that will work. Post up some pics of you have any. thanks
  2. Apr 16, 2011 at 3:57 PM
    Tacoma of Souls
    Tacoma of Souls Member
    Nova Scotia, Canda
    me and a buddy from school made a front bumper for an 83 4runner while we were in the welding shop... turned out pretty awesome. we used a length of galvanized steel fence tubing (don't weld that.. LOL) and it turned out great. we cut the top just a hair shorter than the bottom and welded the top tube about half the diameter towards the truck. chopped the ends off at 20 or 30 degrees, can't really remember. took the 6 or 8 inch ends, flipped them around and re-welded them to get the angle around the fenders and slightly upwards. looked bad ass. rear bumpers are pretty simple if you're just gonna stack the tubes, but i personally like having a bit of space between the tubing. mine has about 3" in between the tubes with 1/4" plate shackle mounts welded in between. also have little reverse lights stuck in there somewhere. looks wicked.
  3. Apr 16, 2011 at 8:02 PM
    DaytonLax14
    Corey
    Ohio
    I'm probably not gonna have any space between the tubes but thanks for the info/input. has anyone else done this?
  4. Apr 17, 2011 at 8:47 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    like those shittybuilt ones they use on jeeps?...
  5. Apr 18, 2011 at 12:16 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Im about to start my front bumper build out of 2" schedule 40 steel pipe and if I have enough afterwards, I might build a rear bumper also.
