Steel vs Aluminum
Discussion in 'Wheels & Tires' started by DylanS4x4, Jun 23, 2022.
  1. Jun 23, 2022 at 7:05 AM
    DylanS4x4
    DylanS4x4 [OP] Well-Known Member
    Maybe need direction to another thread.
    Was looking at getting new tires, possibly new rims to replace aluminum alloy.
    Concerned at the possibility of corrosion on the alloy and looking at added strength and ability to repair on the steel rim.
    Downside seems to be additional weight. Any input or recommendation? Looking at either 16" or 17".
    six5crèéd likes this.
  2. Jun 23, 2022 at 7:10 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Weight savings is worth it for the aluminum imo. Strength and repair ability of wheels is very rarely a concern.
    OmahTako, Key-Rei and six5crèéd like this.
  3. Jun 23, 2022 at 7:14 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Your frame will rot before the rims. Go aluminum :D
  4. Jun 23, 2022 at 7:20 AM
    DylanS4x4
    Normally I'd agree, but the area I live in has poor road conditions. Many friends in the area have cracked rims due to highway potholes.
  5. Jun 23, 2022 at 7:21 AM
    DylanS4x4
    I sure hope not with the fluid film each year, but darn this salt :/
    six5crèéd[QUOTED] likes this.
  6. Jun 23, 2022 at 7:24 AM
    0xDEADBEEF
    What kind of tires? I could see that with the lower profile stuff, but anything with a decent amount of sidewall should have no issue
    OmahTako and Key-Rei like this.
  7. Jun 23, 2022 at 7:25 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    Aluminum corrosion is relatively harmless, are steel wheels really stronger? Obviously the material is but they are designed very differently.
    Key-Rei likes this.
  8. Jun 23, 2022 at 7:28 AM
    DylanS4x4
    One was a low pro, the other just a stock sedan 17" rim, not sure on the tire size. Not sure if it just hit poorly along the side. for reference when I say pothole, it was a good 4" deep and as wide / wider than the tire
  9. Jun 23, 2022 at 7:29 AM
    DylanS4x4
    I assume more aluminum is used, but just dependent on the design, that's why I was looking for any recommendations. For steel I was looking at American racing, not sure on an alloy.
  10. Jun 23, 2022 at 7:36 AM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    I think Aluminum would be stronger then a stamped sheet metal wheel, just a hunch not sure. I recently ordered wheels from RRW I got the RR6-H. Everything depends on budget.
  11. Jun 23, 2022 at 7:42 AM
    0xDEADBEEF
    Yeah, even a 17 on a truck is going to have a lot more sidewall cushion than those. You’d really have to screw up to break an aluminum wheel on one of these if you’re running something like a 70 aspect ratio
  12. Jun 23, 2022 at 7:44 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    do you live in PA?
  13. Jun 23, 2022 at 7:49 AM
    DylanS4x4
    NW PA yea
  14. Jun 23, 2022 at 7:56 AM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    Steelies give a noticeably better ride over rough roads and potholes.
  15. Jun 23, 2022 at 7:57 AM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    yea, those roads are awful. my condolences.
  16. Jun 23, 2022 at 10:04 AM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    We wanted to chime in as well. As others noted, with enough sidewall the wheel would be protected.
    Unfortunately your area is notorious for horrible roads, and although they may take a toll on all vehicles, only the short sidewalls are really in danger of damaging a wheel.
    For corrosion resistance, fully painted wheels will fair far better than a polished or machine finish. We can help further, pm on the way.
    AxisCab likes this.
  17. Jun 28, 2022 at 6:34 PM
    AxisCab
    AxisCab Well-Known Member
    Dave
    Bumville, or some dam place
    2018 2.7L 2WD Auto6, utility Axis Cab
    firewood scratches, Labrador hair/slobber, American flag sticker, Total Chaos bed stiffener, Scepter H20 can, onboard air
  18. Jun 28, 2022 at 6:38 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    If damaged steel can be repaired. Aluminum usually cannot be repaired. I've been driving for a long time and never had a problem with either. Generally speaking I think most aluminum looks better. Not enough difference in weight to matter on a Tacoma.
