Steel wheels on 3rd gen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sandycheeks4x4, Aug 23, 2017.
  1. Aug 23, 2017 at 11:37 AM
    Sandycheeks4x4
    Sandycheeks4x4 [OP] Well-Known Member
    Northeast Ohio
    2017 Tacoma DCSB TRD Sport
    Goatee removal, plasti derp
    I tried searching google and all over the forum without any results.
    I'm looking for a more rugged style of wheel and I like the idea of non stock steelies. Has anyone installed cragar or vision steelies? (Or any othe brand for that matter). I love the look but I'm not sure if there would be any issue with brake clearance on the 3rd gen. Most of what I've found is -12 offset which is most likely too aggressive for my taste so I would want to try to find something 0 offset.
    Something like this in 6 bolt obviously:
  2. Aug 23, 2017 at 1:56 PM
    Jeff1795
    Jeff1795 Well-Known Member
    Panama City FL
    LT 2017 TRD Sport 4x4 Access Cab 6-Speed
  3. Aug 23, 2017 at 6:52 PM
    Sandycheeks4x4
    Northeast Ohio
    Good to know thank you! Since it's more labor intensive would you say that you don't even need the rear spacers to clear the drums?
  4. Aug 23, 2017 at 6:56 PM
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport 4x4
    Stock
    Love the way they look on my 2nd gen.
  5. Aug 23, 2017 at 7:04 PM
    Jeff1795
    Panama City FL
    @Sandycheeks4x4 no I only used spacers in the front. I just wanted the front and back to match. Plus I loved the stud through the lug nut look!
  6. Aug 23, 2017 at 7:08 PM
    vrod671
    Brandon
    2022 TRD Sport 4x4
    Stock
    I like that look too.
  7. Aug 23, 2017 at 7:08 PM
    Sandycheeks4x4
    Northeast Ohio
    Gotcha that makes sense. Thanks for that info! I think I'd like to track down a set
  8. Aug 23, 2017 at 7:09 PM
    Sandycheeks4x4
    Northeast Ohio
    I think so too!
  9. Aug 23, 2017 at 7:25 PM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    The only bad thing is they are so so heavy imo.
  10. Aug 23, 2017 at 7:30 PM
    Sandycheeks4x4
    Northeast Ohio
    I did consider that, but the truck is already pretty slow and mileage isn't amazing anyways so I figure the effects will be more or less negligible.
    1bad2k[QUOTED] likes this.
  11. Aug 23, 2017 at 8:40 PM
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    LOL that is true. I've pretty much come to that same idea for when I'm ready to get some new all-terrain tires.
  12. Aug 24, 2017 at 4:05 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    I like the look but don't want to run spacers. Might check out the FJ Cruiser steelies or running spare steel wheels.
  13. Aug 24, 2017 at 4:15 AM
    Jeff1795
    Panama City FL
    @Woodrow F Call i didn't want to run them either which is why I did the ARP studs
  14. Aug 24, 2017 at 8:49 AM
    dtraill27
    dtraill27 Well-Known Member
    I'm looking to do a set with AT tires before winter. Wasn't impressed with the stock TRD sport tires in the snow last winter. Any thoughts on these? I'm kind of a noob when it comes to to wheel fitment. Will these fit a 17 sport? https://goo.gl/r9dFfj
  15. Aug 24, 2017 at 8:51 AM
    Sandycheeks4x4
    Northeast Ohio
    With the shape of the face on those it looks like it would be more likely to clear without spacers, but I don't know from experience. Worst case scenario you can order them and you may need to add spacers like @Jeff1795 did
  16. Oct 6, 2018 at 9:08 PM
    VelociRaider
    VelociRaider New Member
    Patrick
    I know this is an old thread, but can someone confirm whether or not the Cragar "Series 342 D Window" black steel wheels (Part No. 3427760) will fit a 3rd Gen TRD Off Road without any modification? Here are the specs on the Cragars:
    - Size: 16x7
    - Bolt Pattern: 6-5.5
    - Offset: 0
    - Rear Spacing: 4"
    - Center Bore: 4.28
    Product Link: https://www.cragarwheel.com/wheels/wheelsdetails/productname/series-342-d-window
    Thanks!
    Patrick
