"steel wheels will not fit tacomas" - help
Discussion in 'Wheels & Tires' started by Swashbuckler, Feb 13, 2009.
  1. Feb 13, 2009 at 12:43 PM
    Swashbuckler
    Swashbuckler [OP] Well-Known Member
    So I ordered some wheels and tires from 4wheelparts.com. I'm about to go pick em up. The guy says on the phone
    him - "do you plan on running spacers?"
    me- "no, why?"
    him - "steel wheels will not fit on tacomas, because the rub on the caliper.You're going to need atleast a 1/4" spacer."
    here's the setup I'm going to run:
    stock suspension
    Rockcrawler series 97
    15x8
    3.75 in backspace
    wrapped in:
    BFG Mud Terrain KM2
    31x10.50R15 (more or less equivalent to 265/75R15)
    is he right?
  2. Mar 13, 2009 at 12:47 AM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    i dont "think" they will but dont take my word on that
    but i would get the spacer just in case and if u dont need it id still but it on for a litle more wider wheel stance
    but any way a free bump 4 ya
  3. Mar 13, 2009 at 3:59 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What size wheels are you replacing? What truck do you have?
    The only way you're gonna know for sure - is to install them.
    Take notice to have they clear the brake calipers & such.
    Then - post back and let us know if the guy was full of shit (or not).
  4. Mar 13, 2009 at 4:30 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    what year your tacoma is makes a big difference...
  5. Mar 13, 2009 at 4:55 AM
    headhunter247
    headhunter247 Well-Known Member
    St. Louis, MO area
    18 Taco Double Cab TRD
    5100's all around, OME 888 and Dakars. ProComp Series 05. Cooper SST Maxx 275s.
    I know for an 05+ 16X8 with 4.5" backspacing requires spacers...Ive been looking at those exact wheels. I do know that wheelersoffroad.com had 15" steelies that will fit the taco.
  6. Mar 13, 2009 at 5:17 AM
    JimBeam
    JB
    2015 Tundra
    15" wheels will NOT fit any 05+ tacomas...SOME 15" wheels will fit 95.5-04 tacomas with the right backspacing
  7. Mar 13, 2009 at 5:26 AM
    FUN4YOU
    FUN4YOU Well-Known Member
    Fredericksburg VA
    09 regular cab 4x4
    leer cap,nerf bars and hitch.
    Just was wondering what size steelies with fit my 09 4x4 regular cab thanks FUN4YOU. I herd alot of people say to go to 17s. I guess my question is would it be cheeper to keep the 16s or go with a 17 inch wheel I would like to run the 265/75/16 or 17 M/Ts.[​IMG]
  8. Mar 14, 2009 at 11:03 AM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    just buy some used trd off road wheels which are 16's and put 265/70/16 and you will be ok. if you go 17's you will have to run a lower tire and you might have slight rub without a lift, or you can paint your stock wheels and just put new rubber on. I just got my wheels and tires at 4wheelpart, pro comp 7069 or something like that with bfg at for 1400 otd.
  9. Mar 17, 2009 at 3:34 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    You have 16" steel wheels now, are you looking for a different steel wheel like the rockcrawlers? You can not get 15's, some 16's fit and 17's do fit.
    You can fit 17's without a lift, TRD sports come stock with 265/65/17.
