Steelies or Aluminum wheels?
Discussion in 'Wheels & Tires' started by tmat, May 28, 2009.
  1. May 28, 2009 at 2:46 AM
    tmat
    tmat [OP] Well-Known Member
    Treavor
    Cypress, CA
    07 Regular Cab, PreRunner
    BHLM, de-badged, custom Manoukian flowmaster exhaust system, Bilstein 5100 front adjustable shocks set at 1.75", "smoked" foglights, Satoshi grille mod, 265/75r16 BFG T/A KO tires, AFE Pro Dry S air filter, solid rear window, Weathertech floor liners and painted grill surround
    So I was talking with a buddy of mine about wheels today. I told him how I wanted to get the Konig countersteer offroad wheels and I was boasting how much they weigh and that they're aluminum and what not when he told me that steel is better then aluminum When it comes to offroading. He said that aluminum will just break (because it is more brittle)but steel will bend. Is this true? And if it is then why don't I see steelies on every truck? They're cheap and strong???? help
  2. May 28, 2009 at 3:03 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    If you go offroading a lot -I'd go with some black rockcrawler wheels. Various companies make them and they're only like $60 each. You can thrash them around, rub 'em up againest rocks & such and not worry about ruining a good expensive set of wheels.
    I've had the same set of rockcrawler wheels on my jeep. They've been on my jeep for like 6 years and they've been beat to hell. I've had to replace 2 of them - one had a minor bend in it (bent at center) to cause a vibration at 60mph and the other was bent extremely at the center (along with a bent axle flange & twisted splines on my axle shaft). I've also had one that got dented in pretty good - a few good whacks with sledge hammer put it back into shape.
    The whole point with the steal wheels (especially the black rockcrawlers), is because they're CHEAP to replace when you ruin 'em.
  3. May 28, 2009 at 11:48 AM
    tmat
    Treavor
    Cypress, CA
    so what is the downside of aluminum wheels offroading? Even if they're the Konig Countersteer OFFROAD I'm just curious if my friend knows what he's talking about.
  4. May 28, 2009 at 3:45 PM
    Janster
    Jandy
    Lancaster, PA
    I dunno, never had alluminum wheels for offroading.
    What type of offroading do you do? Are you climbing around on rocks & rocky terrain?
    If you're running around on rocks & stuff - the only downside to alluminum wheels that I know of - is the chance of scratchin 'em up, gouging the edges, etc. It'll be hard to keep them looking 'nice' and expensive to replace if you ruin one.
    Did you ever think about getting a second set of wheels/tires for offroading?
    Keep a good alluminum (or whateve) set of wheels/tires for the street and get a cheap-ass set of steal wheels with mud tires for offroading.
  5. May 28, 2009 at 5:42 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    Entirely depends on how well said rim is made. Steel wheels can crack just as easily as aluminum ones can if they're using a crappy method to manufacture them.
  6. May 28, 2009 at 5:47 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Also aluminum is supposedly stronger but it breaks instead of bends. Steel is supposedly weaker but you can pound it back into shape.
    Here is a question I have been wondering about. I know from experience with our farm equipment that if you heat the steel up to bend it back, it loses some strength. Is that the case with pounding bent steel back or no.
  7. May 28, 2009 at 11:39 PM
    tmat
    Treavor
    Cypress, CA
    alright so basically Steel wheels are the ones that are just the run of the mill black or chrome ones that don't look special, weigh a bunch and they can be bent back into shape given that they are well made. Aluminum wheels are the ones that look really cool, are lighter but are much more expensive and can break and not be bent back into shape?
    So is this (generally speaking) a true statement? And if it is then I'm going steel baby!
  8. May 29, 2009 at 1:09 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    yeah, aluminum is more expensive, lighter, and looks better, but they can be easily gouged on rocks and stuff and would crack if you tried to pound a flattened lip back, etc. Steelies are cheap, dont look as good, but you can beat on a flattened edge until its back into shape.
    If they're going a rig intended to spend alot of time offroad, then i'd get steel, if the truck spends the majority of the time on the street and looks are important, then get alumimum and just be a little careful not to gouge/scrape them on rocks.
  9. May 29, 2009 at 1:29 AM
    snowtaco
    snowtaco Well-Known Member
    Cali and Pa
    2006 single cab
    Replaced head unit, tint, blacked out tail lights, 10in sub, billet grill, 3 in front lift, led halo projector lights, camper shell.
    unless your goin all out off roading you could make it on alum and because they are lighter they will help with mpg thats how i see it.. it sucks that steel is so much cheeper tho
  10. May 29, 2009 at 4:22 AM
    Janster
    Jandy
    Lancaster, PA
    If you want a good cheap offroad wheel...I highly recommend a black rockcrawler wheel.
    15x8
    $60
    Search around, for better prices. There's a few manufacturers that make the same type.
  11. May 29, 2009 at 9:37 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    I thought 16 was the smallest we could go on 2nd gen... due to the caliper size.
    Otherwise, yea pretty much what 'they' said.
  12. May 29, 2009 at 11:07 AM
    tmat
    Treavor
    Cypress, CA
    I'm actually getting this exact wheelset, but 16x7 and white for $260
  13. May 29, 2009 at 11:10 AM
    headhunter247
    headhunter247 Well-Known Member
    St. Louis, MO area
    18 Taco Double Cab TRD
    5100's all around, OME 888 and Dakars. ProComp Series 05. Cooper SST Maxx 275s.
    $260 for the set? or a piece?
  14. May 29, 2009 at 11:24 AM
    tmat
    Treavor
    Cypress, CA
    The set.
  15. May 29, 2009 at 9:52 PM
    blknblubkrdude
    blknblubkrdude Well-Known Member
    Gillette, WY
    96 Taco. 4X4, 5MT, 2.7
    Oil field truck with 250k miles...original powertain. Wheelers 881's/5-pack, Energy bushings throughout.
    The only advantage a steel wheel has over an alloy wheel is the cost.
    Breaking an aluminum wheel when wheeling is a non-issue. Don't even think about it.
    You are more likely to get stuck on the trail with a flat if you use steel wheels. The lip on the steel wheels are much more likely to be damaged and let the air out.
    An alloy wheel will save you a lot of unsprung weight, which will increase the performance and longetivity of your truck in all ways.
  16. May 30, 2009 at 6:42 AM
    Janster
    Jandy
    Lancaster, PA
    That's a non-issue.
    1) Spare tire
    2) If you carry a good set of tools/equipment/onboard air, it can be fixed.
    I've dented mine plenty of times - nothing a good whack with a mallet can't fix. One paticular dent/bend that I experienced, required dismounting the tire and several good whacks with a mallet. Ratchet strap to help mount it and onboard air to pop it into place. I've also had big chunks of wood shoved into the bead of my wheels/tire - and they still held air. The wheel/tire combo I had was VERY forgiving.
  17. May 30, 2009 at 7:17 AM
    blknblubkrdude
    Gillette, WY
    Yes, the wheel can be repaired or replaced with a spare, but you are still considered "stuck" until you repair it.
    If you are wheeling in deep powder, in the winter, that is one of the last things you want to happen. It is a very dangerous situtation.
    Just fork out the extra money for alloys and you won't have to worry about pounding out the dents.
  18. May 31, 2009 at 2:50 AM
    tmat
    Treavor
    Cypress, CA
    um...if I had a spare what difference would this make? I think I'm going with the steelies
  19. May 31, 2009 at 5:21 AM
    Rippin101
    Rippin101 Well-Known Member
    Jax Beach, FL
    2014 TRD Sport 4x4
    -Nitto G2 265/70/17 -Level 8 MK6 Wheels -Katzkin Leather Black on Black -BHLM -Weathertech -Extang Solid Fold -Bedlight LEDs -TRD Skid
    Thats what I have ;)
  20. May 31, 2009 at 6:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    My $0.02.......Personally, on our trucks, Im happy with aluminum. I have been beating aluminum wheels for over 10 years with no issues. The Konigs are a quality wheel, and many people run them off road with no problems. If you hit any wheel on the rocks, issues are bound to arise.
