Steep Downhill in Snow/Ice - Advice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TodyBee, Dec 27, 2020.
  1. Dec 28, 2020 at 11:34 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    As others said studded snow tires, 4x4, and selecting a low gear will all help.
    Imo the 'easiest' and cheapest solution would be a big drum of sand/gravel. Apply heavily to the hill as needed.
    Also consider the surroundings. If you've got a nice snow bank on either side of the road to catch you and no trees, then maybe its not such a big deal. If no snow bank and/or lots of trees to crash into, that could turn out poorly
    Sig45 and 69 Jim like this.
  2. Dec 28, 2020 at 11:36 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Studded winter tires. /thread
  3. Dec 28, 2020 at 1:58 PM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    I live in the Cascade Mtns, "driveway" is 17% grade with two 90° turns. Snow over ice is common. 4WD means four wheels spinning instead of two. Studded snow tires, wear out quickly and help in snow, smaller help on ice. Chains are best bet. Sometimes I only need them to get to and from the paved county road. I hate tire chains. Then there's black ice, all bets are off.
  4. Dec 28, 2020 at 3:19 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Normally the edge of the road next to the ditch (and in town next to the curb or sidewalk and in the centerline) has uncompacted snow. If you can keep two tires on the uncompacted stuff its much easier to maintain traction and stop.
    GilbertOz and Marc70 like this.
  5. Dec 28, 2020 at 5:12 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    OP could you post some pictures of the road and the curve etc. I think it would help us to make appropriate suggestions. Also how far is it from top to bottom?
    Marc70 likes this.
  6. Jan 1, 2021 at 1:04 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    OP if you lose traction going down hill drop it to a lower gear and stay mostly off the brakes. Braking (especially downhill) uses mostly front brakes. If you are braking and the front are locking up you have zero steering. If your rear tires are dragging but your front tires aren’t locked up, at lest you can steer. When you’re pointed where you want to point, start feathering the brakes again.
    best advice is great winter tires, LOTS of weight in the rear, and start the hill slow and low. Chains if conditions warrant it, are always faster and more convenient than dealing with the aftermath of a crash.
    doublethebass likes this.
  7. Jan 1, 2021 at 1:12 PM
    Truks4elk
    Truks4elk Well-Known Member
    3rd gen 4x4 OR crew LB
    Dead slow in 4 lo, locked diff if you have it, locked in lowest possible gear if your transmission allows. Stay off the brakes. Ideally you’ll be off all the pedals. Plus traction tires or chains if needed.
  8. Jan 1, 2021 at 3:54 PM
    PlatinumCloud
    PlatinumCloud Jameson Drinker
    Sarver
    2015 off-road pkg
    chains. studded tires maybe. also kitty litter. works on ice for traction. as does ash from say a wood stove. Good luck and keep the rubber down!
  9. Jan 1, 2021 at 4:28 PM
    TacoTuesday1
    FL
    Ima Get Me Some Old Bald Summer Tires Shift Into High Gear N Slam The Brakes In 4HI
  10. Jan 1, 2021 at 5:21 PM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    :rofl::rofl::rofl:
  11. Jan 1, 2021 at 7:14 PM
    Crow Horse
    Crow Horse Well-Known Member
    Central NY
    2012 DCSB TRDOR
    Studded tires. I had an 800 foot driveway that was steep and had one off camber turn. On 2 separate occasions, in different vehicles, in low range no throttle, I managed to do 180°'s and slide down backwards. Not fun. When possible I tried to keep one side of the truck in the snowy edges. It was still dicey at times.... Cinders and sand help. Salt is not recommended....Driveway Ice.jpg WS Pax stuck1.jpg WS Pax stuck2.jpg Luge Run 002.jpg
  12. Jan 1, 2021 at 7:31 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    When the tires begin to slide.......you're screwed.
    Consider parking at the bottom and walking.
    4Lo, 4Hi, 2wd, studs, chains.........all good suggestions, but may not be practical.
    Chains would need to be removed/installed each time. You can't run chains on clear paved roads.
    Studs are not allowed in many states. Sure you could swap tires each time, just like the chains.
    4Lo, 4Hi, 2wd.....when the tire slides = no traction = no control.
    You could spread dirt or sand. Only problem is keeping the pile from freezing into a solid lump.
    You could consider occasionally spreading crushed limestone. Not as likely to freeze into a solid lump.
    Sprig likes this.
  13. Jan 1, 2021 at 9:01 PM
    TacoTuesday1
    FL
    I wonder which chains are best for the Tacoma
    and if studded tires are worth it
    it'd be cool to at least keep some good fitting chains stored in the truck if they're ever needed
    or to show proof if an area requires having them legally
    at least good fitting ones that don't fling off and bash the fender well
    for example Colorado
    bi-polar weather. It might snow a day or two. Then not for 2 weeks. So you'd be tearing up streets and making noise with studs. Which is legal.
    And spending $800 on a second set of tires for a snowy Monday then listening to them make noise on dry road when right after for 2 weeks it's not snow...
    people seem to prefer snow-rated A/T's for that reason, like Duratracs
    Truks4elk likes this.
  14. Jan 1, 2021 at 9:33 PM
    neverstuck
    Guido
    Lebanon
    13 DCLB sport
    Snowflake rated all terrains are not winter tires. It takes next to nothing to qualify for that symbol. A dedicated winter snow/ice tire is an amazing thing for traction in winter. They’re far safer in winter. For highway driving in winter I’d take a camry with blizzaks over a 4wd Tacoma with duratracs.
    Running a set of dedicated winter tires (unstudded blizzaks for instance) on a set of $400 take-off factory wheels will cost you about 1400 bucks the first year. They will last for several seasons and will extend the life of your all seasons. It’s a pretty insignificant expense if you plan on keeping your truck for several years and drive on snow and ice in winter. For a couple hundred bucks a year I can make myself and my family much safer on the roads. It’s a no brainer.
    I may have gotten off track here. Sorry. My point is that studless winter tires are amazing and I think they outperform studded all terrains all day every day. You can run them on their own set of wheels in winter, and many problems are immediately solved.
  15. Jan 1, 2021 at 9:40 PM
    #35
    Sprig
    Ken
    This^^ . As I said in my first post here once you start sliding on ice down hill you are up shit creek. Ain’t nothing going to save you other than luck. Your best option is to park at or near the bottom and walk. If too far consider getting a snowmobile to go up and down the hill.
  16. Jan 1, 2021 at 9:59 PM
    #36
    DaveB.inVa
    DaveB.inVa Well-Known Member
    SWVa
    2015 AC SR5 4x4 V6 AT MGM
    Oil Catch Can, OIl Pressure and Temp Gauges, Falken Wildpeak A/T3W 265/70R16
    The last part of my driveway is very steep with a turn at the end.
    My method is put it in 4x4 then roll down in neutral controlling speed by braking. Being in 4x4 is essential as it keeps everything rolling, locking up only the front or rear wheels in a case like this and you're done.
    2WD is particularly bad in a situation like this while in gear because sometimes traction is so low that any braking can lock the fronts but you have engine power keeping the rears turning.
    I also have an ABS disable button and use it during this situation.
    GilbertOz likes this.
  17. Jan 1, 2021 at 10:48 PM
    #37
    neverstuck
    Guido
    Lebanon
    13 DCLB sport
    Uh.... What?
    you put it in 4wd, then in neutral, and only use brakes?? What is it you think 4wd is doing if you’re in neutral?
    Too Stroked likes this.
  18. Jan 2, 2021 at 1:04 AM
    #38
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    It's been my experience that doing this is a recipe for disaster. Low range, 1st gear and foot off the brake. Let engine compression be your brakes....
    There are situations that no matter what you do, you're gonna be screwed. Assess the conditions. If significantly sketchy, then turn back inside, have another cup of coffee, and call your employer and tell them you won't be in today....
    SilverBulletII and Truks4elk like this.
  19. Jan 2, 2021 at 6:33 AM
    #39
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    ^^^ I absolutely agree with the above. I'm also convinced that there are folks that have driven on Blizzaks (or something similar) and those that have not. Those that have not have no idea how much better a true studless Ice & Snow tire really is. I ran all sorts of snow tires on my cars for years. I was even running 4 snow tires back when people told me I'd "ruin my front end" by running shows in front. (My reply was always, "They're round aren't they?") Until I ran Blizzaks, I thought they were all marketing hype. They're not. I currently run four Blizzak DM-V2's on my Tacoma and will never run anything else.
    doublethebass and SilverBulletII like this.
  20. Jan 2, 2021 at 7:53 AM
    #40
    DaveB.inVa
    SWVa
    Reread the post, actually stated why in there.
    I agree and I've tried that here and it does work. Part of my reason is due to this prevents me making another shift into 4HI to go the rest of the way. It's a section that's maybe 30 yards or so. It hasn't ever been a concern and I've never had any problems but if I lose it on one side I go into my grandmothers yard and the other into a field, no fences or anything either way here. I shouldn't have said anything originally or provided a better explanation. Sorry for any confusion.
