Steering cable TSB...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hubs, Jul 23, 2012.
  1. Jul 23, 2012 at 3:42 AM
    Hubs
    Hubs [OP] Well-Known Member
    Took my 2008 Tac DBLC to get steering cable replaced as per TSB. Service Advisor said that TSB is NOT a recall, but for service info only. He asked me if any of my air bag lights had turned on. I said no. Based on that, no worked was needed to be performed.
    He said Toyo engineers were working on a fix for above and that I would receive letter from Toyo when fix was found.
    I am confused by this! Can you give me any guidance?
  2. Jul 23, 2012 at 7:51 AM
    shawnd2
    shawnd2 Well-Known Member
    Shawn
    Toronto, Ontario, Canada
    08 Tacoma Access Cab 4x4 TRD Offroad
    Just like yhe dealer said, I'm not sure when/if the recall will be coming out, but you will receive a letter and then you can bring your truck in for the fix.
    Prior to that if you have nothing wrong, then the dealer will not replace anything of there is no reason.
    As discussed many times on here, a TSB just assists the dealer in resolving a specific issue, once the issue is present. The TSB fix may or may not be covered under warranty.
    Shawn.
  3. Jul 23, 2012 at 8:01 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I got a recall letter and it said basically what the service rep told you. In short, this is what the recall letter said:
    -We have a problem with the clockspring cable and it will be a safety recall
    -We don't know how to fix it just yet, we're working on it
    -If your air bag light is on, bring in your truck and we'll replace it with a new faulty part to get you on your way until we figure out a more permanent fix
  4. Jul 23, 2012 at 12:04 PM
    raskal
    raskal Well-Known Member
    B.C.
    2013 DCLB TRD MGM
    My airbag came on recently, but my el-cheapo code reader says no codes found.
    could this be the issue?
  5. Jul 23, 2012 at 12:08 PM
    Pugga
    Massachusetts
    Not sure but it sure sounds like it.
  6. Jul 23, 2012 at 12:59 PM
    raskal
    B.C.
    2013 DCLB TRD MGM
    SRS as in Safety Restraint Systems?
    my code reader will read airbag codes on other vehicles
    Is there a certain reader that is recommended for our trucks?
  7. Jul 23, 2012 at 1:20 PM
    raskal
    B.C.
    2013 DCLB TRD MGM
    yes it reads all ODBII and CAN codes, it has always found a code, sometimes it's a generic message, but always has found one.
    I just hate taking it to a shop, $100 just to read the codes :(
  8. Jul 23, 2012 at 2:29 PM
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    O'Rileys Auto Parts has code readers you can use for free.
  9. Jul 23, 2012 at 2:33 PM
    raskal
    B.C.
    2013 DCLB TRD MGM
    No O'Reilly's in Canada :(
  10. Jul 23, 2012 at 8:21 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I don't have the letter I received in front of me right now, but I don't think they used the term TSB. They said there is a safety RECALL. They also said they are planning to send another letter out once they have the fix-it parts available.
    I am not aware of a TSB for the airbag system, just the recall on the spiral cable.
    Sounds to me like you and your dealer just had a problem with terminology. If your light isn't on, just wait for the recall notice that says they have the parts in, then make an appointment, using the word RECALL.
    TSB=Information for the mechanic to fix your truck, not necessarily free of cost.
    RECALL=Free repair to prevent a possible safety problem from occuring.
  11. Jul 23, 2012 at 8:23 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Oreilly can't read SRS codes.
    Spiral cable is part of the SRS (airbag) system.
    Not steering cable... Spiral cable -- clock spring
  12. Jul 24, 2012 at 3:21 AM
    Hubs
    Okay, thanks for clearing this up. Oh, indeed, it is the SPIRAL cable not the steering cable! I'll wait for the official recall letter OR when my lite turns on...!
