Steering column final fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tom84ford, May 10, 2013.
  1. Jul 11, 2016 at 3:23 AM
    njcoma
    njcoma Well-Known Member
    California
    2017 Accord Sport Special Edition
    Previous: 2006 Tacoma SR5 Prerunner: 2010 4Runner sr5 Rims, TSB rear leafs, Wetokole neoprene seat covers, JVC LED color matched head unit, scanguage II, Flowmaster 40 cat back exhaust, hankook dynapro atm tires, Class 4 Uhaul Hitch. Kicker 12 inch sub and amp. Focal speakers. jba offroad UCAs.. Detroit truetrac rear end... bilstein 5100 rear and 6125 front coilovers. Nfab front bumper with KC apollo lights, bed lights, bluesea systems fuse box....lots of painted stuff.
    Just did this mod..... didn't realise that you cant just cut the original posts and knock out the rivet caps....also thought the original posts were hollow.....
    12 hours later...... :(
    Finished it at 3:30 am...... before a workday at 6..
  2. Jul 11, 2016 at 6:46 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    I think we have all had a similar problem repair or two. I feel your frustrations.....
    But - Did it work ??
  3. Jul 11, 2016 at 7:01 AM
    njcoma
    California
    Yes.. absolutely.. I also discovered that it helped my 65 mph shake (knock on wood)..
    When I was first pulling the shaft out.. I noticed that as the shaft flexed at the rubber disk.. it forced the u joint above it to flex to compensate..which in turn forced it to spin.. causing the steering wheel to "shake"..
    Only time will tell if that is actually the bane of all of our shakes... but it's definitely a factor..
    In the future I'd like to get another one of these joints from toyota.. and have the machinists at work use the drill press to widen the holes professionally so I can run bigger bolts for this mod for peace of mind.. I have 1/4 bolts in there now... which im sure are strong enough... but I'd rather use 10mm bolts to ensure they don't ever snap from any twisting off-road...
  4. Jul 11, 2016 at 9:22 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Friendly suggestion: Make sure you use locktite and lock nuts! You don't want that to come apart when driving.
  5. Jul 11, 2016 at 5:19 PM
    njcoma
    California
    I definitely did.. used locktite and coated all the nuts and washers in locktite glue where they meet the bolts.. my own concern is whether or not 1/4 inch bolts will hold up to offroading.. part of me wants to order a new rag joint.. do this same mod.. but enlist the help of the machinists at work.. take my time.. and use 10mm bolts to hold the entire assembly together.. for peace of mind..
    I also considered jb welding the central shaft to the upper u joint part.. just for some extra grip... just in case...
    But anyhow.. steering is definitely tighter... shimmy is still there on certain roadway pavement types.. but it's definitely manageable instead of severe and violent... truck feels "controlled" now.
  6. Jul 13, 2016 at 4:49 AM
    Canufixit
    New England
    NABeast and 327 like this.
  7. Jul 13, 2016 at 8:07 PM
    mrlee
    mrlee I like crunchy Tacos!!
    2013 TRD Sport (Yeah, it's gotta skewp, Haterz gonna hate)
    Bed rug, ARE bed top, Weathertechs. Little goodies here and there!
    My other car, 88 Monte, also had a rag shaft. However, instead of modifying it, a jeep shaft was/is compatable. It also gave more room for headers. Picked up one from a boneyard, cleaned it up, etcc.. Very easy install. Remove and replace. Cheap mod.
    Wonder if there is a compatible shaft out there for the taco?
    Biscuits likes this.
  8. Aug 14, 2016 at 7:30 AM
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
  9. Aug 26, 2016 at 4:32 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I literally just did this fix maybe 10 minutes ago. Fuck them for using that bullshit soft bushing they did. They could had at least used a polyurethane bushing in place of squishy rubber. Steering feels nice and solid now.
  10. Aug 26, 2016 at 5:15 PM
    ImpulsedComa
    ImpulsedComa Well-Known Member
    NJ
    05 Double Cab 4x4 SR5 V6
    I have a slight clunk in certain road condition bumps after i installed ny 884's. I inspected my rag joint and found movement in it. I installed the zip tie which tightened it up and went for a ride. The clunk is still there with no improvement... Do you guys think moving the shaft down as stated on page one is mt next move? Why would the movement and slack be tightened by the zip tie not fix the clunk? Very frustrating
  11. Dec 4, 2016 at 4:23 PM
    njcoma
    California
    Sorry to revive an old thread.. but my clunking is still there.. but I found movement on the piece above the rag ujoint... the lower part of the telescope column actually has some play.. and it clunks when it slides upwards into the telescope housing under/behind the steering wheel.
    Anyone else found this? or a fix?
  12. Dec 10, 2016 at 2:50 PM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    ImMrYo mirror bracket. A/C, P/W, Tilt, Cruise, AM/FM CD
    Ok I'm attempting a repair. I noticed when you wiggle the joint it has a lot of play and clunks,I figured this is the noise I'm hearing. Anyway I cut up a coke can and made shims,slid them in and sprayed some grease on it. I then wiggled the joint and it feels a lot tighter. I'm going wheeling tomorrow so I'll report back.
  13. Dec 10, 2016 at 8:34 PM
    Taco'09
    Taco'09 Well-Known Member
    ^^I hope you have better luck that I did trying that same fix. Mine came out because the center shaft constantly has axial movement. I was going to try it again but bend or otherwise secure the alum pieces better but gave up and bought and installed the TSB shaft instead.
    NABeast likes this.
  14. Dec 11, 2016 at 4:13 PM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    Seemed a lot better off-road,I'll have to check and see if the inserts are coming out yet. At least I know how to fix it, now to figure out how to keep them in.
  15. Dec 11, 2016 at 5:17 PM
    #35
    TakeNoteS
    TakeNoteS Well-Known Member
    Luke
    Kalama Washington
    2022 Silver Taco SR5 LB 4X4
    When I go over bumps I hear clunking and it sounds like suspension bottoming out but It is not.... Is this the type of experience every one is having? It seems to be a different issue for everyone.
  16. Dec 11, 2016 at 5:19 PM
    #36
    Taco'09
    You do know about using zip ties in there? A lot of guys seem to give the zip tie(s) thumbs up.
    Another guy and I went after the looseness and clunks in a serious way a couple of years back.
    Both our trucks were new at the time so we could not attribute things to worn out steering parts, but both of us found slop in the center plastic bushing of the rag joint so we replaced the upper intermediate shaft with the TSB one. This certainly helped but did not completely cure the problems.
    We found two additional sources of looseness and clunk that transmit both noise and feel back up through the steering column. The first has to do with the preload on the steering rack between the rack and the pinion. Wiggle the steering wheel just a little and check for freeplay where the shaft enters the rack. There really should be none. Mine had a lot and I made some tools to adjust (o-so-slightly tighten) the preload.
    The second was we discovered that there was wide variance at the time of manufacture from truck-to-truck in the amount of axial preload of the upper and lower intermediate shafts. We adjusted this at the steering yoke (this is the coupling part with (2) 12mm bolts between the lower shaft and the upper). This modification involves loosening those two bolts and either pushing the upper shaft a little ore into the yoke, or pulling the shafts away from each other (both of us used pushing) and then tightening the two bolts on the yoke. You will see that the rubber disc in the rag joint flexes one way or another depending on which of the techniques you use and takes some of the axial play out.
  17. Jan 13, 2019 at 3:17 PM
    #37
    grubburg
    grubburg Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    How did you get the shaft and coupler twisted correctly to fit back together?
  18. Jun 30, 2019 at 8:06 PM
    #38
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I have had a buzz driving over textured roads for a while now and I couldn't figure out where the hell it was coming from, it has been driving me absolutely nuts. I thought for the longest time that the issue was actually a buzz coming front the dash, but it turns out it is originating from the steering wheel linkages directly. Thanks to your post I went out there just now and wiggled the shaft to check for slop. I found there was some originating from just above the intermediate shaft collar or sleeve due to it being a little too low on the shaft. I am going to loosen both bolts a bunch then force the sleeve up further up the shaft. Retighten and then recheck. Thanks for the advice! Phew! At least I know what direction I need to take this now.
    grubburg likes this.
  19. Jul 1, 2019 at 5:08 AM
    #39
    Taco'09
    :eek::eek:
    Oh, um, yea, and I hope the steering thing improves too!
    Also some of the clunk that others may experience can originate from the steering rack guide within the steering rack. It a real pain to tighten up the rack guide but can be done.
  20. Nov 6, 2023 at 5:50 PM
    #40
    Fendergeek
    Fendergeek Active Member
    Denver, CO
    2013 Tacoma TRD
    Has anyone tried the 1st Gen tacoma steering column weld? Or is that not possible with a 2nd Gen because it's a telescoping steering column? Really wish I could figure out the sloppy feeling above 60 MPH. It sounds exactly like the issue 1st Gen users have with it needing constant correction and hearing the rattle but I replaced both sections of the upper intermediate shaft and tried putting a shim between the rag joint. Still the issue persists. Thinking it's something in the steering column now.
